Topic: Crossfader DSP limitation (Read 329 times) previous topic - next topic
Tested different scenarios of crossfading from one codec to another with clean install of fb1.6.5b5 and built-in crossfader DSP.
FLAC, MP3, M4A works well in all different combinations I have tested. Opus works well as fine with opus, but fails crossfading with all other codecs I tested (FLAC, MP3, M4A) in both directions (e.g. opus->m4a and m4a->opus).
Is there anything I can do to fix opus crossfading with other codecs?
Re: Crossfader DSP limitation
Sounds like it's failing to crossfade files of differing sample rates.
Use resampler in DSP chain before crossfader.
@kode54  @Rollin : you are right, its a sample rate problem! Opus was at 48 kHz (as provided by youtube), all other at 44,1 kHz. Resampler solved the problem! Thanks very much!
