Topic: Hiding Empty Fields (Read 222 times) previous topic - next topic
Hiding Empty Fields
I have a panel that displays composers, however I only use the field for my favourite artists and as a result have many songs that have an empty composer field. These empty fields are still being displayed though and I would like to hide it. I'm still new to foobar so I'm not very familiar with the functions that would go about doing this. I'm just using [%<composer>%] right now.
(It is technically a drop down so the full line is [%<composer>%]|%<album artist>%|[%album%]|[[%discnumber%.]%tracknumber%] [%track artist% - ]%title%| but the main issue is with the composer field).
Re: Hiding Empty Fields
What is the panel / component you are using?
It's a Spider Monkey Panel, but its just acting as an album list that I've customized with a composer view.  The different views seem to use normal foobar syntax and functions so I assume it's not an issue?
These are the different views in the panel properties, but I'll only be using composers for this panel.
I see. If you only want it to show tagged composers, wrap the entire view pattern in an $if statement -
$if(%composer%,%<composer>%|%<album artist>%|[%album%]|[[%discnumber%.]%tracknumber%] [%track artist% - ]%title%)
Of course you'll be missing tracks not tagged with composers, so it would not be a complete list of your library.
Alternatively, you could put a "(No Composer)" entry instead (where you had a blank space before) to list all tracks -
$if2(%<composer>%,'(No Composer)')|%<album artist>%|[%album%]|[[%discnumber%.]%tracknumber%] [%track artist% - ]%title%
Or, you might prefer to setup a filter instead (assuming Library Tree script, with filter button top right) so you can click the filter on and off to show tagged composers or complete library -
%composer% PRESENT
(Under "View Filters" in Panel Preferences)
Cheers
Thank you, the first statement was what I was looking for, and I appreciate the alternative options.
I was messing around with an $if statement but couldn't format it properly, so thanks for the help!
