Topic: Library viewer stuck at Monitoring and doesn't add new files (Read 310 times) previous topic - next topic
I want Foobar to automatically display all music files under specific directory but it seems to be stuck and it doesn't add any new files.
When I drag and drop the directory to a New Playlist it lists more files that I currently have under Library Viewer Selection.
I'm using v.1.6.4.
Re: Library viewer stuck at Monitoring and doesn't add new files
Does it say anything in the console?
View > Console
Media Library is supposed to say "Monitoring" once it has finished initial scanning and it's indeed monitoring for possible changes.
Library Viewer Selection shows a selection you have made from a library viewer, a feature that is nowadays off by default because it has been too confusing for people.
Try selecting "Library" -> "Album List", then right click on "All Music" and select "Create Autoplaylist". You now have a playlist that will always contain all the tracks in your media library.
Thanks @Case ! It works now in "All Music" tab, it updates the list as soon as I add any new file to directory, it doesn't update in Library Viewer Selection though but it's fine, I can use "All Music" tab instead. I could swear it used be simpler 10 years ago when I last used this feature ;)
