Topic: FLAC v1.3.3 (Read 115688 times) previous topic - next topic
Re: FLAC v1.3.3
Reply #125
Here I go reading and answering the question, without noticing that the front-end was mentioned.
@gilibaus , beware the front-end; I had it eating my files: post 116 up here, or https://hydrogenaud.io/index.php?topic=99803.msg921798#msg921798
I don't know what it does wrong, but I never had the CLI do this. Does the front-end rename even incompletely converted temp files to overwrite the original?
Rather, use e.g. foobar2000,, bitcompare to the original and only then delete.
Re: FLAC v1.3.3
Reply #127
I’m curious what happened to 1.3.4... it seems we went backwards to 1.3.3 again?
Re: FLAC v1.3.3
Reply #128
Following.  Doing some CD rips and want to make sure I'm staying up to date with these things. Currently using the 1.3.2 that ships with EAC.
