I'm using foo_customdb v0.1.0_beta1 with foobar2000 v1.0.1 and it crashes almost every time when playback advances from one track to the next. Anybody else having these sorts of crashes? Here's an example crash report:
1. Use codebox-tag when posting crash-reports.
2. I think you might want to review your settings. I'm using the latest versions with no problem, but customdb can be quite picky if you didn't configure it properly. If you post your settings, I'll try to test them on my system
OK, I've discovered that the crash occurs when using foo_customdb in conjunction with foo_playlist_tree_mod. I have defined a foo_customdb field called RATING. Then, with foo_playlist_tree_mod, I have created the following query:
Source: @database
Criteria: %rating% GREATER -1
If you refresh this query, about 1 in 3 times foobar will crash. I have spoken to the author of foo_playlist_tree_mod and he says the fault lies within foo_customdb according to the crash report (below):
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01A01945h
Access violation, operation: read, address: 00000000h
Last win32 error: 2
Call path:
entry=>app_mainloop=>titleformat_object::run
Code bytes (01A01945h):
01A01905h: C7 06 14 59 A8 01 89 75 F0 89 46 04 89 46 08 89
01A01915h: 46 0C FF 75 0C 89 45 FC FF 75 08 89 46 10 E8 7E
01A01925h: 00 00 00 8B 4D F4 8B C6 5E 64 89 0D 00 00 00 00
01A01935h: C9 C2 08 00 33 C0 39 44 24 08 76 11 8B 4C 24 04
01A01945h: 80 3C 08 00 74 07 40 3B 44 24 08 72 EF C3 E9 E1
01A01955h: FF FF FF 56 8B 74 24 10 85 F6 76 13 8B 4C 24 08
01A01965h: 8B 44 24 0C 2B C1 8A 14 08 88 11 41 4E 75 F7 5E
01A01975h: C3 56 57 8B 7C 24 10 8D 47 01 50 8B F1 E8 BB 01
Stack (0012EF4Ch):
0012EF2Ch: 7750051A 0158F7E0 0158F7E0 77DDEDF1
0012EF3Ch: 00000000 0158F800 00000000 00000000
0012EF4Ch: 01A015DB 00000000 FFFFFFFF 01A9A3A0
0012EF5Ch: 01A06C9E 01AB4398 01A1FA61 01AB4398
0012EF6Ch: 01A0157E 0012F034 01A84248 FFFFFFFF
0012EF7Ch: 0012F040 01A5DE6A 00000000 FFFFFFFF
0012EF8Ch: 6E4136DD FFFFFFFE 01AB2660 02CFA598
0012EF9Ch: 01AB2660 7C91B24B 0001041C 01AB5730
0012EFACh: 0012EF08 0001F0D0 0012EFF4 7C900030
0012EFBCh: 7C910060 FFFFFFFF 7C91005D 01A70146
0012EFCCh: 01AB0000 00000000 01A70165 6E413699
0012EFDCh: 00000000 0012F070 00000008 0012F08C
0012EFECh: 0012EFD8 00407B87 0012F080 00000000
0012EFFCh: 01A858DC 01AB4428 00000002 00000002
0012F00Ch: 00000001 01A858DC 01AB7BC8 0000005F
0012F01Ch: 00000080 0000005E 00000064 01AB7C88
0012F02Ch: 01A9A3A0 01474F3F 0012F080 01A833E3
0012F03Ch: 00000002 0012F08C 01A5E229 00000008
0012F04Ch: 02D01110 0012F06C 6E413611 0012F068
0012F05Ch: 0012F04C 01A9A3A0 01A9A394 0012F04C
Registers:
EAX: 00000000, EBX: 00000008, ECX: 00000000, EDX: 01A01574
ESI: 0012F06C, EDI: 0012F0D0, EBP: 0012EF7C, ESP: 0012EF4C
Crash location:
Module: foo_customdb
Offset: 1945h
Loaded modules:
foobar2000 loaded at 00400000h - 005BA000h
ntdll loaded at 7C900000h - 7C9B2000h
kernel32 loaded at 7C800000h - 7C8F6000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F59000h
USER32 loaded at 7E410000h - 7E4A1000h
SHLWAPI loaded at 77F60000h - 77FD6000h
DSOUND loaded at 73F10000h - 73F6C000h
ole32 loaded at 774E0000h - 7761D000h
VERSION loaded at 77C00000h - 77C08000h
WINMM loaded at 76B40000h - 76B6D000h
UxTheme loaded at 5AD70000h - 5ADA8000h
SHELL32 loaded at 7C9C0000h - 7D1D7000h
shared loaded at 10000000h - 1002B000h
imagehlp loaded at 76C90000h - 76CB8000h
dbghelp loaded at 59A60000h - 59B01000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LPK loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
PowerMenuHook loaded at 003A0000h - 003B3000h
WINTRUST loaded at 76C30000h - 76C5E000h
CRYPT32 loaded at 77A80000h - 77B15000h
MSASN1 loaded at 77B20000h - 77B32000h
wdmaud loaded at 72D20000h - 72D29000h
msacm32 loaded at 72D10000h - 72D18000h
MSACM32 loaded at 77BE0000h - 77BF5000h
midimap loaded at 77BD0000h - 77BD7000h
msctfime loaded at 755C0000h - 755EE000h
foo_cdda loaded at 00AF0000h - 00B3E000h
foo_input_std loaded at 00F40000h - 0108E000h
foo_dop loaded at 01090000h - 0123C000h
SETUPAPI loaded at 77920000h - 77A13000h
gdiplus loaded at 4EC50000h - 4EDFB000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
QUARTZ loaded at 74810000h - 7497E000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_ui_std loaded at 01290000h - 0139E000h
MSIMG32 loaded at 76380000h - 76385000h
foo_rgscan loaded at 013C0000h - 0140F000h
foo_jesus loaded at 01450000h - 01477000h
foo_playlist_tree_mod loaded at 01480000h - 01500000h
libmzsch360_000 loaded at 10400000h - 105D0000h
WSOCK32 loaded at 71AD0000h - 71AD9000h
libmzgc360_000 loaded at 01520000h - 015C4000h
foo_audioscrobbler loaded at 01610000h - 01643000h
foo_dsp_std loaded at 01670000h - 016B9000h
foo_albumlist loaded at 016E0000h - 0173C000h
foo_skip loaded at 01760000h - 01781000h
foo_converter loaded at 017B0000h - 01821000h
foo_ui_columns loaded at 01850000h - 019DB000h
foo_customdb loaded at 01A00000h - 01AA5000h
foo_fileops loaded at 01AC0000h - 01B08000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
CFNetwork loaded at 05500000h - 05599000h
WININET loaded at 3D930000h - 3DA16000h
Normaliz loaded at 021B0000h - 021B9000h
urlmon loaded at 78130000h - 78263000h
iertutil loaded at 3DFD0000h - 3E1B8000h
CoreFoundation loaded at 055A0000h - 0566A000h
MSVCR80 loaded at 056C0000h - 0575B000h
pthreadVC2 loaded at 021D0000h - 021E0000h
objc loaded at 05860000h - 0587C000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
icuin40 loaded at 05980000h - 05A7D000h
icuuc40 loaded at 05D20000h - 05E01000h
icudt40 loaded at 4AD00000h - 4BA5B000h
ASL loaded at 05E60000h - 05E70000h
SQLite3 loaded at 05E80000h - 05EE3000h
zlib1 loaded at 05F00000h - 05F13000h
iphlpapi loaded at 76D60000h - 76D79000h
iTunesMobileDevice loaded at 062D0000h - 063E9000h
mswsock loaded at 71A50000h - 71A8F000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
Stack dump analysis:
Address: 01A015DBh (foo_customdb+15DBh)
Address: 01A9A3A0h (foo_customdb+9A3A0h)
Address: 01A06C9Eh (foo_customdb+6C9Eh)
Address: 01A1FA61h (foo_customdb+1FA61h)
Address: 01A0157Eh (foo_customdb+157Eh)
Address: 01A84248h (foo_customdb+84248h)
Address: 01A5DE6Ah (foo_customdb+5DE6Ah)
Address: 7C91B24Bh (ntdll+1B24Bh), symbol: "RtlpWaitForCriticalSection" (+8Ch)
Address: 7C900030h (ntdll+30h)
Address: 7C910060h (ntdll+10060h), symbol: "RtlFreeHeap" (+133h)
Address: 7C91005Dh (ntdll+1005Dh), symbol: "RtlFreeHeap" (+130h)
Address: 01A70146h (foo_customdb+70146h)
Address: 01A70165h (foo_customdb+70165h)
Address: 00407B87h (foobar2000+7B87h)
Address: 01A858DCh (foo_customdb+858DCh)
Address: 01474F3Fh (foo_jesus+24F3Fh)
Address: 01A833E3h (foo_customdb+833E3h)
Address: 01A5E229h (foo_customdb+5E229h)
Address: 01A9A394h (foo_customdb+9A394h)
Address: 01A83409h (foo_customdb+83409h)
Address: 0047510Eh (foobar2000+7510Eh)
Address: 0052CD18h (foobar2000+12CD18h)
Address: 00474FC9h (foobar2000+74FC9h)
Address: 7C9101DBh (ntdll+101DBh), symbol: "RtlAllocateHeap" (+117h)
Address: 7C9100C4h (ntdll+100C4h), symbol: "RtlAllocateHeap" (+0h)
Address: 0052F808h (foobar2000+12F808h)
Address: 004752DEh (foobar2000+752DEh)
Address: 004749D6h (foobar2000+749D6h)
Address: 00550C34h (foobar2000+150C34h)
Address: 004C84D5h (foobar2000+C84D5h)
Address: 0057A960h (foobar2000+17A960h)
Address: 00554FD4h (foobar2000+154FD4h)
Address: 004C978Dh (foobar2000+C978Dh)
Address: 0052D088h (foobar2000+12D088h)
Address: 004C9710h (foobar2000+C9710h)
Address: 00559FD0h (foobar2000+159FD0h)
Address: 005331D9h (foobar2000+1331D9h)
Address: 004754CAh (foobar2000+754CAh)
Address: 7C810687h (kernel32+10687h), symbol: "CreateRemoteThread" (+1BBh)
Address: 00550C2Ch (foobar2000+150C2Ch)
Address: 0057A980h (foobar2000+17A980h)
Address: 00550D3Ch (foobar2000+150D3Ch)
Address: 7C910222h (ntdll+10222h), symbol: "RtlAllocateHeap" (+15Eh)
Address: 7C90E920h (ntdll+E920h), symbol: "strchr" (+113h)
Address: 0044E580h (foobar2000+4E580h)
Address: 00517311h (foobar2000+117311h)
Address: 7C8106F9h (kernel32+106F9h), symbol: "CreateThread" (+22h)
Address: 7C910228h (ntdll+10228h), symbol: "RtlAllocateHeap" (+164h)
Address: 7C91019Bh (ntdll+1019Bh), symbol: "RtlAllocateHeap" (+D7h)
Address: 004C9584h (foobar2000+C9584h)
Address: 00531BABh (foobar2000+131BABh)
Address: 005304ECh (foobar2000+1304ECh)
Address: 004C9687h (foobar2000+C9687h)
Address: 7C9100B8h (ntdll+100B8h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C910041h (ntdll+10041h), symbol: "RtlFreeHeap" (+114h)
Address: 00534481h (foobar2000+134481h)
Address: 004B71FDh (foobar2000+B71FDh)
Address: 00517330h (foobar2000+117330h)
Address: 004BB599h (foobar2000+BB599h)
Address: 0051B0F0h (foobar2000+11B0F0h)
Address: 004ED4EDh (foobar2000+ED4EDh)
Address: 7C90DF5Ah (ntdll+DF5Ah), symbol: "ZwWaitForSingleObject" (+Ch)
Address: 0058888Dh (foobar2000+18888Dh)
Address: 7C90DC2Ah (ntdll+DC2Ah), symbol: "ZwSetEventBoostPriority" (+Ch)
Address: 7C91B2A9h (ntdll+1B2A9h), symbol: "RtlpUnWaitCriticalSection" (+22h)
Address: 7C901046h (ntdll+1046h), symbol: "RtlEnterCriticalSection" (+46h)
Address: 0057D7C4h (foobar2000+17D7C4h)
Address: 00474F3Fh (foobar2000+74F3Fh)
Address: 0053814Eh (foobar2000+13814Eh)
Address: 00475323h (foobar2000+75323h)
Address: 004B72A2h (foobar2000+B72A2h)
Address: 004B9277h (foobar2000+B9277h)
Address: 0052C090h (foobar2000+12C090h)
Address: 004B9804h (foobar2000+B9804h)
Address: 0148AF80h (foo_playlist_tree_mod+AF80h)
Address: 00579684h (foobar2000+179684h)
Address: 014D34E0h (foo_playlist_tree_mod+534E0h)
Address: 005305EAh (foobar2000+1305EAh)
Address: 004B951Eh (foobar2000+B951Eh)
Address: 0054B958h (foobar2000+14B958h)
Address: 01488937h (foo_playlist_tree_mod+8937h)
Address: 0057A724h (foobar2000+17A724h)
Address: 0112F7CCh (foo_dop+9F7CCh)
Address: 01494D04h (foo_playlist_tree_mod+14D04h)
Address: 01490D23h (foo_playlist_tree_mod+10D23h)
Address: 0149EB5Fh (foo_playlist_tree_mod+1EB5Fh)
Address: 0149DD0Fh (foo_playlist_tree_mod+1DD0Fh)
Address: 014DC73Ch (foo_playlist_tree_mod+5C73Ch)
Address: 014DC5C8h (foo_playlist_tree_mod+5C5C8h)
Address: 014D4DD8h (foo_playlist_tree_mod+54DD8h)
Address: 01489941h (foo_playlist_tree_mod+9941h)
Address: 7E428EABh (USER32+18EABh), symbol: "DefWindowProcW" (+18Bh)
Address: 7E44048Fh (USER32+3048Fh), symbol: "DeregisterShellHookWindow" (+1CFh)
Address: 7E428EB0h (USER32+18EB0h), symbol: "DefWindowProcW" (+190h)
Address: 7E428EECh (USER32+18EECh), symbol: "DefWindowProcW" (+1CCh)
Address: 7C90E473h (ntdll+E473h), symbol: "KiUserCallbackDispatcher" (+13h)
Address: 7E428E53h (USER32+18E53h), symbol: "DefWindowProcW" (+133h)
Address: 7E4194BEh (USER32+94BEh), symbol: "GetWindowLongA" (+61h)
Address: 7E42C174h (USER32+1C174h), symbol: "SetPropW" (+BBh)
Address: 014D4E7Eh (foo_playlist_tree_mod+54E7Eh)
Address: 014CC1FBh (foo_playlist_tree_mod+4C1FBh)
Address: 7E42B326h (USER32+1B326h), symbol: "MoveWindow" (+88h)
Address: 7E42B330h (USER32+1B330h), symbol: "MoveWindow" (+92h)
Address: 7E4278D0h (USER32+178D0h), symbol: "GetWindowTextLengthW" (+9Ah)
Address: 7E4278E0h (USER32+178E0h), symbol: "GetWindowTextLengthW" (+AAh)
Address: 018B3870h (foo_ui_columns+63870h)
Address: 7E42B341h (USER32+1B341h), symbol: "MoveWindow" (+A3h)
Address: 7E46CF6Eh (USER32+5CF6Eh), symbol: "TrackPopupMenuEx" (+Ch)
Address: 7E465339h (USER32+55339h), symbol: "TrackPopupMenu" (+1Bh)
Address: 014D26F6h (foo_playlist_tree_mod+526F6h)
Address: 014CCC74h (foo_playlist_tree_mod+4CC74h)
Address: 01484194h (foo_playlist_tree_mod+4194h)
Address: 014CC360h (foo_playlist_tree_mod+4C360h)
Address: 7E41882Ah (USER32+882Ah), symbol: "GetDC" (+163h)
Address: 7E428EA0h (USER32+18EA0h), symbol: "DefWindowProcW" (+180h)
Address: 003A1860h (PowerMenuHook+1860h)
Address: 7E428EFCh (USER32+18EFCh), symbol: "DefWindowProcW" (+1DCh)
Address: 014CCD4Ch (foo_playlist_tree_mod+4CD4Ch)
Address: 014F06F4h (foo_playlist_tree_mod+706F4h)
Address: 01496F3Fh (foo_playlist_tree_mod+16F3Fh)
Address: 01494DAFh (foo_playlist_tree_mod+14DAFh)
Address: 01494E4Dh (foo_playlist_tree_mod+14E4Dh)
Address: 014DBCE4h (foo_playlist_tree_mod+5BCE4h)
Address: 014D276Dh (foo_playlist_tree_mod+5276Dh)
Address: 0148B278h (foo_playlist_tree_mod+B278h)
Address: 014D9410h (foo_playlist_tree_mod+59410h)
Address: 003A1420h (PowerMenuHook+1420h)
Address: 7E4318D1h (USER32+218D1h), symbol: "UnhookWinEvent" (+25h)
Address: 7E43E1ADh (USER32+2E1ADh), symbol: "User32InitializeImmEntryTable" (+E18h)
Address: 7E43E18Ah (USER32+2E18Ah), symbol: "User32InitializeImmEntryTable" (+DF5h)
Address: 7E41970Eh (USER32+970Eh), symbol: "IsChild" (+0h)
Address: 014D4AE8h (foo_playlist_tree_mod+54AE8h)
Address: 7E418734h (USER32+8734h), symbol: "GetDC" (+6Dh)
Address: 7E418816h (USER32+8816h), symbol: "GetDC" (+14Fh)
Address: 7E418830h (USER32+8830h), symbol: "GetDC" (+169h)
Address: 7E4189CDh (USER32+89CDh), symbol: "GetWindowLongW" (+127h)
Address: 7E4191C6h (USER32+91C6h), symbol: "GetMessageW" (+0h)
Address: 7C90FE30h (ntdll+FE30h), symbol: "RtlRestoreLastWin32Error" (+0h)
Address: 7E4189F0h (USER32+89F0h), symbol: "GetWindowLongW" (+14Ah)
Address: 7E418A10h (USER32+8A10h), symbol: "DispatchMessageW" (+Fh)
Address: 7E41929Bh (USER32+929Bh), symbol: "PeekMessageW" (+0h)
Address: 004646DBh (foobar2000+646DBh)
Address: 004654C4h (foobar2000+654C4h)
Address: 0054F5E8h (foobar2000+14F5E8h)
Address: 0055A2ACh (foobar2000+15A2ACh)
Address: 00400000h (foobar2000+0h)
Address: 0055A290h (foobar2000+15A290h)
Address: 0051F52Ch (foobar2000+11F52Ch)
Address: 0051D514h (foobar2000+11D514h)
Address: 7C91027Fh (ntdll+1027Fh), symbol: "RtlAllocateHeap" (+1BBh)
Address: 00517E02h (foobar2000+117E02h)
Address: 10002778h (shared+2778h), symbol: "uPrintCrashInfo_OnEvent" (+B0h)
Address: 0054F238h (foobar2000+14F238h)
Address: 00537D77h (foobar2000+137D77h)
Address: 00465707h (foobar2000+65707h)
Address: 00517B01h (foobar2000+117B01h)
Address: 005420B8h (foobar2000+1420B8h)
Address: 0057F090h (foobar2000+17F090h)
Address: 0053FCE0h (foobar2000+13FCE0h)
Address: 004157A6h (foobar2000+157A6h)
Address: 00517B15h (foobar2000+117B15h)
Address: 0053817Dh (foobar2000+13817Dh)
Address: 00518F46h (foobar2000+118F46h)
Environment:
App: foobar2000 v1.0.1
OS: Windows 5.1.2600 Service Pack 3 x86
CPU: Intel® Pentium® D CPU 3.20GHz, features: MMX SSE SSE2 SSE3
Audio: HTO STRIKER 7.1 Audio Device
UI: Columns UI 0.3.8.5
Components:
Core (2010-03-06 13:44:16)
foobar2000 core 1.0.1
foo_albumlist.dll (2010-03-06 13:42:18)
Album List 4.4
foo_audioscrobbler.dll (2010-02-07 16:16:48)
Audioscrobbler 1.4.6
foo_cdda.dll (2010-03-06 13:42:14)
CD Audio Decoder 3.0
foo_converter.dll (2010-03-06 13:42:12)
Converter 1.4
foo_customdb.dll (2010-03-04 13:10:54)
Custom Database 0.1.0_beta1
foo_dop.dll (2010-04-02 18:09:34)
iPod manager 0.6.7.4
foo_dsp_std.dll (2010-03-06 13:42:26)
Standard DSP Array 1.0
foo_fileops.dll (2010-03-06 13:41:12)
File Operations 2.1.2
foo_input_std.dll (2010-03-06 13:42:00)
Standard Input Array 1.0
foo_jesus.dll (2010-01-03 13:41:18)
Autosave & Autobackup 8
foo_playlist_tree_mod.dll (2010-01-09 15:37:50)
Playlist Tree Mod Panel 3.0.6.3 Scheme [Jan 9 2010 - 15:37:18]
foo_rgscan.dll (2010-03-06 13:41:56)
ReplayGain Scanner 2.0.9
foo_skip.dll (2010-01-16 15:43:34)
Skip Track 0.7
foo_ui_columns.dll (2010-03-21 00:43:13)
Columns UI 0.3.8.5
foo_ui_std.dll (2010-03-06 13:42:34)
Default User Interface 0.9.5
Recent events:
Custom Database: Initialize
Custom Database: table quicktag already exists (1)
Custom Database: table database_version already exists (1)
Custom Database: index url_idx already exists (1)
Custom Database: Completed
Startup time : 0:07.007730
iPod manager: Listening for Apple mobile devices.
