Topic: foo_run (Read 607808 times) previous topic - next topic
Re: foo_run
Reply #750
I can't start the program auCDtect Task Manager with parametrs "$if(%__referenced_file%,$directory_path(%path%)\%__referenced_file%,%path%)" - as a result, only one track is transferred to the program, despite the fact that I select everything in the playlist (trackwise)
Re: foo_run
Reply #752
It would be great to have a proper batch mode in this. I cannot run parallel processes on thousands of files because it will slow down Foobar2000 tremendously. There should be an option to run them one after the other.
