Topic: Foobar will no longer start after updating to version 1.6 (Read 1048 times) previous topic - next topic
So far I could update my Foobar (with adapted skin from Br3tt without problems: Xchange-360 ). Unfortunately Foobar does not start at all after the update to 1.6. There are no error messages at all.
Here I have uploaded a portable version of my version, where the same phenomenon occurs when updating to version 1.6:Xchange 360 mod portable
I would be very grateful for an idea, because the skin used covers exactly my needs.
Many greetings :-\
Rolf
Re: Foobar will no longer start after updating to version 1.6
It's probably a duff version of JScript Panel which has a bug preventing fb2k v1.6 from starting. The latest version has the bug fixed...
https://github.com/marc2k3/foo_jscript_panel/releases
You might need to open the fb2k-component file with a program like 7-zip or similar to manually extract and overwrite the old files if you can't install components normally.
That sounds promising. I'll try it out tomorrow. For now, thanks for the tip!
Best regards
Rolf ;D
That was indeed the problem! Many thanks for this!
Now only a message concerning the JScript "Library Tree" appears:
Spoiler (click to show/hide)
Or is there now a script for "Library Tree" adapted to JScript version 2.4.1.2?
Many greetings
Rolf
Hello @snotlicker
I have now switched to "Spider-Monkey-Panel" because @WilB offers good enhancements for "Library Tree" here.
Thanks again for the great support!
