Topic: Opus 1.2 is out! (Read 19663 times) previous topic - next topic
  • francesco
Re: Opus 1.2 is out!
Reply #50
hi
just downloaded opus 1.2 from the homepage , and i want to upgrade my encoder
do I need only opusenc.exe or libopus-0.dll & libopusfile-0.dll too?
thanks for the new update
  • IgorC
Reply #51
francesco
Just use any of 1.2.1 binaries posted in this topic.
https://hydrogenaud.io/index.php/topic,114234.msg941208.html#msg941208
https://hydrogenaud.io/index.php/topic,114234.msg941283.html#msg941283
https://hydrogenaud.io/index.php/topic,114234.msg941312.html#msg941312
https://hydrogenaud.io/index.php/topic,114234.msg941462.html#msg941462
https://people.xiph.org/~jm/opus/opus-1.2/
Comparing Opus to MP3 only?
When Opus has outperformed LC-AAC, HE-AAC, Vorbis at 64-96 kbps.
I have also tested Opus 1.2 alpha vs  state of the art HE-AACv2 encoder ( ~32 kbps, VBR, FhG) .  https://hydrogenaud.io/index.php/topic,111798.msg930611.html#msg930611
Opus 1.2 alpha was already better than HE-AACv2 at 32 kbps in my test and 1.2 release contained quality improvements too comparing to alpha/beta.
You can throw in comparison with Opus literally any available codec.
  • Last Edit: 08 July, 2017, 12:56:40 PM by IgorC
  • francesco
Reply #52
francesco
Hi @IgorC
thanks IgorC
  • Makaki
Reply #53
What happened to the official FLAC support on the Mozilla builds? Was working fine on opus-tools-0.1.9-win32 and then poof, it's gone. I tried both opus-tools-0.1.10-win32 and ...-win64
Error parsing input file: song.flac
I did notice the 3rd party compiles by users of the forums, Was curious of the official status.
  • RiCON
Reply #54
The CI of the MSVC projects doesn't include FLAC, that's just it.
  • bandpass
Reply #55
Given the quality improvements (which are great!), shouldn’t the Opus line be moved (or tilted) up accordingly here:
  • ziemek.z
Reply #56
You're right, I noticed the same some time ago. Now fullband is being supported down to 14 kbps.
sox -e float -b 32 -V4 -D gain -1 rate -v 48000 norm -1
opusenc --bitrate 96
Reply #57
Why no AAC <40 kbps on this graph?
  • saratoga
Reply #58
Has anyone actually done that comparison with Opus?
Reply #59
  • Kamedo2
Reply #60
Yes, and move down the MP3 128kbps a tiny bit, to the quality of Vorbis 96kbps.
This is according to the 2014 public multiformat listening test.
  • polemon
Reply #61
Someone should re-do the graph and make it really, really crude. Like with pencil on the inside cardboard of a cereal box or something. Couple mistakes and also use an eraser each time something makes.
My thinking is, this would epitomize the approximate nature of the graph. Bonus points for fitting the entire graph inside a 8x8cm box, and use crayons to draw the lines.
  • jmvalin
  • Developer
Reply #62
Actually, that figure started off pretty much like what you're describing when presented at an IETF meeting (see slide 15).
  • polemon
Reply #63
Yeah, that's pretty much what I kinda thought of. Although a part of me wants to make this diagram a bit more complete, and update it with things like patents that have expired, like G.729.
That, and adding "unfinished" or "experimental" codecs, like Codec2.
  • Kamedo2
Reply #64
My improvement idea (work in progress)
  • Opus tilted up
  • MP3 tilted down around the 128kbps area
  • AAC extended to 32 kbps
  • Color altered for color blind friendliness
  • Legend color area enlarged for color blind friendliness
  • SVG source code cosmetics for better readability and smaller size
Original: https://opus-codec.org/static/comparison/quality.svg
My rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality5.svg
  • eahm
Reply #65
Kamedo2, I see the same graph there.
  • Kamedo2
Reply #66
  • smok3
  • Moderator
Reply #67
On Debian Stretch I did
apt install opus-tools
wget https://archive.mozilla.org/pub/opus/opus-1.2.1.tar.gz
unp opus-1.2.1.tar.gz
cd to there
./configure
make
sudo make install
sudo ldconfig
opusenc --version
opusenc opus-tools 0.1.10 (using libopus 1.2.1)
Copyright (C) 2008-2017 Xiph.Org Foundation
Would that be ok?
  • Last Edit: 13 September, 2017, 04:09:41 PM by smok3
  • eahm
Reply #68
Better to ask here I guess: how do I put Opus in a CAF container with foobar2000?
  • polemon
Reply #69
My rework: https://ss1.coressl.jp/listening-test.coresv.net/img2/quality6.svg
Is the lower contrast intentional?
Also, when it comes to fullband mono and fullband stereo, there's no smooth transition as such. There should be some clarity that there's an overlap, or even better: make two different diagrams altogether.
I'd love to add some more codecs, though. Especially AMR-WB+, AC3, Atrac, G.729, and G.729.1 (recently expired patents).
  • kode54
  • Administrator
Reply #70
FFmpeg will likely add this to its CAF muxer* in the near future, if it hasn’t already. Combined with lib opus encoding, this should be able to target iOS 11 devices.
*By add, I mean to its list of supported codecs.
  • Kamedo2
Reply #71
Yes, intentional. Many modern color designs are like that.
Please consider uploading your version of graph(s). It will be a great help to me.
  • kode54
  • Administrator
Reply #72
afconvert -d opus -f caff -q 127 -b 48000 -s 3
Manages to produce mono Opus streams on macOS High Sierra developer beta 9, I have yet to test on the GM seed, which I am about to install over my stable Sierra installation.
I also made a 3 line patch to avformat / {caf,cafenc}.c, which enables muxing the Opus codec into CAF containers. I have verified that a stereo stream plays back properly on High Sierra, same version, and will upload to my iCloud Drive and verify whether it plays on my iOS 11 GM device.
  • LithosZA
Reply #73
Sorry, updated.
Maybe AAC could also be extended to go below 32Kbps? The only problem is that quality and bandwidth is mixed, so it might be a straight line extending to the left.
I think a better graph would be a graph that nearly looks the same, but with the 'narrowband, wideband etc.' sections removed and the color of the line determines the bandwidth.
Like 'Yellow = Narrowband, Orange = Wideband, Fullband = Green etc.'
  • Kamedo2
Reply #74
Indeed. The quality and bandwidth is mixed, and it's a tricky problem.
Adding a footnote for the Opus at 14 - 32kbps may be a better idea.
Footnote: Opus at 14 - 32kbps is actually a fullband, but the quality is comparable to that of other wideband encode.
