Hi there,
I've got all my cds on my computer as flac files. There is one flac file for each cd and a cue sheet with the track information in it. I want to be able to convert the flac files to ogg files but at the same time splitting the ogg file into individual tracks, tagged and ready to play on my portable player. I've found applications that will do the converting, and applications that will do the splitting, but none that will do them both at the same time and add the tags from the cue sheet. Any suggestions for something i could try?
You could use the most awesome program ever!!!, It does everything except clean out the cat's litterbox (and i'm not so sure)!!!.
Seriously though, Foobar2000.
foobar2000 (http://www.foobar2000.org/) for GUI use.
ACDIR (http://nyaochi.sakura.ne.jp/xoops/modules/mydownloads/viewcat.php?op=&cid=1) for command line use.
