Topic: set sample rate???? (Read 576 times) previous topic - next topic
set sample rate????
my foobar says "could not set sample rate to 176400Hz" hardware problem or what? pls help me, thanks
peoblem picture is down below
  • Last Edit: 17 April, 2017, 06:53:50 AM by somebody123
  • Case
  • Developer (Donating)
Re: set sample rate????
Only speculation on my part but you have set output PCM samplerate to 176400 Hz in Preferences -> Tools -> SACD and your soundcard doesn't actually support the rate. If that's the case you can easily fix it by setting the sample rate to 44100 Hz.
i found a way to solve the problem, thank you anyway
  • Klaus1189
What did you do, let us know, too.
as I expected, it's hardware problem, my device is too old to run ASIO components so I returned to how it were.What a pity!
