Topic: [useless] From: Listing cue tracks in library? (Read 734 times) previous topic - next topic
Basically this is the situation: I have a lot of albums lossless in FLAC and APE. In some the tracks are ripped as separate files and some as a single file with cue file. Is there a way to show the tracks from the cue files in the media library instead the big file?
I know I can drop the cue file manually to see and select individual tracks but it will be much easier if the library lists the separate tracks from the cue (if present) instead the big file.
I searched the forum and did not found a answer. If there is no suck feature isn't it something worth implementing in the feature releases?
->i think there is no solution to this, but right click -> Utilities -> Edit Cuesheet / or
-->right click -> Run service -> Send to CUETools .. :,)
