Topic: Eac+ CMD/lame Converter or CUETools+CUERipper (Read 3943 times) previous topic - next topic
It's been a couple of years since i last checked here but I was wondering if i may get some assistance.
Software:
Exact Audio Copy V1.0 beta 3
CueTools 2.1.5
LAME 3.99.5 using libsndfile 1.0.25
So previously I've been using Eac and a cmd script with lame to rip cd's to flac and convert them to mp3 when i needed to do so (for media players ie ipod)
I've been using settings as follows.
Eac i was using this to rip cd's to flac
-8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" %source% -o %dest%
My CMD batch file to convert to mp3 is as follows:
@echo off
"K:\Programs\Exact Audio Copy\Flac\flac.exe" -dc %1 | K:\Programs\Lame3.99.5\lame.exe -V 0 --vbr-new - %1.mp3
echo.
So i was browsing/reading through and came across Cuetools which seems to be a nice all in one solution.
Testing out the converter part and i noticed that it had a smaller file size than the method i used previously
I also had the same file size when i placed Lame3.99.5 - lame.exe into the plugins folder for Cuetools.
So a few questions:
1) Are the commands/commandline arguments I'm using currently the best i can get or have better ones come out
2) Is Cueripper better than Eac for CD to flac ripping or pretty much equivalent?
3) What would cause the file size discrepancy between the script and cuetools?
3a) is it using the same command because as far as i can tell it is?
4) Is there a better freeware i should look into for a ripper and/or converter?
Too much for a single topic.
3) check Tags / CoverArt.
3a) yes
korth
For EAC? That looks fine, although you could pass some additional tagging fields if you like. Here's a more complex encoding command line that I've seen:
-V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "PERFORMER=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "ALBUMARTIST=%albumartist%" -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" -T "COMMENT=%comment%" %source% -o %dest%
Personally, I have no use for things like lyrics or the PERFORMER field. You could pick and choose from this if you wanted to add things like DISCNUMBER or TOTALTRACKS. The most important addition that I think you could make would be ALBUMARTIST, as this is commonly used by many music players and library managers.
For the conversion to MP3 using LAME, I believe --vbr-new is now the default, so that's no longer necessary. You may want to reconsider using -V0 if this is only for portable players. The space savings you could get from using, say, -V2 or -V3 or lower would be significant. Test and see where you find the sound quality acceptable.
I still use EAC and haven't used CUETools very much, so couldn't say.
Your script doesn't transfer tagging to the MP3 files, does it? That's probably the difference.
The encoding parameters may be the same, but it's probably also passing the tagging data along on the command line.
You could use foobar2000 or dbpoweramp Music Converter for the conversion. Both freeware, and they'll both transfer the tagging from the FLAC files to the MP3s.
Yes, CUETools passes to TagLib# (aka taglib-sharp) for ID3 tagging.
korth
