Topic: Can not rip to flac in foobar2000 (Read 2108 times) previous topic - next topic
Hi everyone
! im new to aduio and foobar. When i try to convert to flac in the new foobar it tells me i need the flac encoder 1.2.0. And the problem is i cant find or download this program to make it work. I would really appreciate some help!
Re: Can not rip to flac in foobar2000
Easiest way is to install the Free Encoder Pack.
 hi download this:
http://flacfrontend.sourceforge.net/
after download open foobar ,start to convert the files like before,.
foobar will ask for flac-encoder: go to the downloaded flac-encoder,klick on it foobar starts to convert.
dsd
Download works flawlessly for me. Maybe try again/a different PC. I also added a copy of the one I just downloaded to this post, you can try that too. If it still doesn't work message me directly and I can get it to you via dropbox or something.
I realize this post is old but it was the most applicable for my situation and wanted to re-open the thread with the error code and the solution
When trying to Convert to FLAC within Foobar 1.42 I was getting this same error on various CD's
---------------BEGIN----------------------
Source: "cdda://012A21B9" / index: 1
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "N:\Music\Shocking Blue\01. Blow Wind Blow.flac"
  Additional information:
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Program Files (x86)\AutoFLAC\flac.exe" -s --ignore-chunk-sizes -0 - -o "267688F9-180E-4471-B54F-A6D0BE173251.flac"
  Working folder: C:\Users\User\AppData\Local\Temp\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
After reviewing the above I opted to investigate:  C:\Program Files (x86)\AutoFLAC\flac.exe
It turns out this was an older copy of EAC.  Once I uninstalled this version, downloaded the newer version (with Foobar closed), re-opened FooBar this issue went away and the FLAC file ripped perfectly.  Side Note:  the entry that lists "Working Folder" is an optional feature within Foodbar
