Topic: Library Tree Discussion (Read 132728 times) previous topic - next topic
Re: Library Tree Discussion
Reply #600
^ I've noticed after changing the Options > Behavior tab > Playlist Sort Order box, that you have to reload the panel for changes to take effect correctly.
If that does not work...
Are track filenames starting with %discnumber%.%tracknumber% ? (for %path_sort% to sort correctly)
What happens if you put a custom sort order in that box, like -
%album artist%|%date%|%album%|%discnumber%|%tracknumber%|%title%
Reply #601
I filled in [ %path_sort%] and restarted fb2k to take effect.Or as you say, reloaded panels can work.
For this sort, click OK in the settings panel does not take effect immediately, Wilb, is there any way to improve?
Reply #602
Happens the same to me with .CUE of FLAC or APE files, shows duplicated. I use the component "Cue Fixer", so in the playlists the albums shows correctly.
Cue Fixer don't work with library :(  (only with playlist view).  Any ideas on how to find a way out?
X
I will try add additional command to callbacks.js:
function on_playlist_items_added(playlistIndex) {
window.Reload();}
 It works, but the panels refresh 2 times and blinks. Maybe someone has some better ideas?
Reply #603
Not an easy task but if you were prepared to rename your files something like...
blah.cue
blah.cue.flac
You could prevent *.cue.flac from being indexed at File>Preferences>Media Library>File types>Exclude.
edit: references inside cue files would obviously need updating. What fun.
Reply #604
Not an easy task but if you were prepared to rename your files..
I don't want to rename, because all files are seeding in "transmission")
Maybe I can add additional update command in the right place in the code?
Reply #605
I found a solution!
1. I made a clone of the original package.
2. I added to populate.js in the section
load(list, isArray, add, autoPlay, def_pl, insert) {....}
creating an additional playlist with name "Library folder cache"
let np_item = -1;
let pid = -1;
const pl_stnd = ppt.libPlaylist.replace(/%view_name%/i, panel.viewName);
let pl_stnd_idx = plman.FindOrCreatePlaylist(pl_stnd, true);
        let cache_2nd_pl = plman.FindOrCreatePlaylist("Library folder cache", true);//my solution
if (!def_pl && plman.ActivePlaylist != -1) pl_stnd_idx = plman.ActivePlaylist;
else if (ppt.activateOnChange) plman.ActivePlaylist = pl_stnd_idx;
if (autoPlay == 4 && plman.PlaylistItemCount(pl_stnd_idx) || autoPlay == 3 && fb.IsPlaying) {
autoPlay = false;
add = true;
const items = isArray ? this.getHandleList() : list.Clone();
this.sortIfNeeded(items);
this.selList = items.Clone();
this.selection_holder.SetSelection(this.selList);
const plnIsValid = pl_stnd_idx != -1 && pl_stnd_idx < plman.PlaylistCount;
const pllockRemoveOrAdd = plnIsValid ? plman.GetPlaylistLockedActions(pl_stnd_idx).includes('RemoveItems') || plman.GetPlaylistLockedActions(pl_stnd_idx).includes('ReplaceItems') || plman.GetPlaylistLockedActions(pl_stnd_idx).includes('AddItems') : false;
if (!add && pllockRemoveOrAdd) return;
if (fb.IsPlaying && !add) {
if (ppt.actionMode == 1) {
const pl_playing = `${ppt.libPlaylist} (playing)`;
const pl_playing_idx = plman.FindOrCreatePlaylist(pl_playing, false);
if (plman.PlayingPlaylist == pl_stnd_idx) {
plman.RenamePlaylist(pl_stnd_idx, pl_playing);
plman.RenamePlaylist(pl_playing_idx, pl_stnd);
plman.SetPlaylistSelection(pl_playing_idx, $.range(0, plman.PlaylistItemCount(pl_playing_idx) - 1), true);
plman.RemovePlaylistSelection(pl_playing_idx, false);
plman.InsertPlaylistItems(pl_playing_idx, 0, items, false);
plman.MovePlaylist(pl_playing_idx, pl_stnd_idx);
plman.MovePlaylist(pl_stnd_idx + 1, pl_playing_idx);
                    plman.SetPlaylistSelection(pl_stnd_idx, $.range(0, plman.PlaylistItemCount(pl_stnd_idx) - 1), true);//my solution
                    plman.RemovePlaylistSelection(pl_stnd_idx, false);//my solution
                    plman.InsertPlaylistItems(pl_stnd_idx, 0, items, false);//my solution
                    plman.ClearPlaylist(cache_2nd_pl);//my solution
        plman.InsertPlaylistItems(cache_2nd_pl, 0, items);//my solution
} else {
} else if (fb.GetNowPlaying()) {
np_item = items.Find(fb.GetNowPlaying());
let pl_chk = true;
let np;
if (np_item != -1) {
np = plman.GetPlayingItemLocation();
if (np.IsValid) {
if (np.PlaylistIndex != pl_stnd_idx) pl_chk = false;
else pid = np.PlaylistItemIndex;
if (pl_chk && pid == -1 && items.Count < 5000) {
if (ui.dui) plman.SetActivePlaylistContext();
const start = Date.now();
for (let i = 0; i < 20; i++) {
if (Date.now() - start > 300) break;
fb.RunMainMenuCommand('Edit/Undo');
if (np.IsValid) {
if (pid != -1) break;
if (pid != -1) {
plman.ClearPlaylistSelection(pl_stnd_idx);
                    plman.ClearPlaylistSelection(cache_2nd_pl);//my solution
plman.SetPlaylistSelectionSingle(pl_stnd_idx, pid, true);
                    plman.SetPlaylistSelectionSingle(cache_2nd_pl, pid, true);//my solution
plman.RemovePlaylistSelection(pl_stnd_idx, true);
                    plman.RemovePlaylistSelection(cache_2nd_pl, true);//my solution
const it = items.Clone();
items.RemoveRange(np_item, items.Count);
it.RemoveRange(0, np_item + 1);
if (plman.PlaylistItemCount(pl_stnd_idx) < 5000) plman.UndoBackup(pl_stnd_idx);
plman.InsertPlaylistItems(pl_stnd_idx, 0, items);
plman.InsertPlaylistItems(pl_stnd_idx, plman.PlaylistItemCount(pl_stnd_idx), it);
                    plman.InsertPlaylistItems(cache_2nd_pl, plman.PlaylistItemCount(pl_stnd_idx), it);//my solution
} else {
plman.ClearPlaylist(pl_stnd_idx);
} else if (!add) {
plman.SetPlaylistFocusItem(pl_stnd_idx, 0);
//plman.SetPlaylistFocusItem(cache_2nd_pl, 0);//my solution
} else {
plman.InsertPlaylistItems(pl_stnd_idx, !insert ? plman.PlaylistItemCount(pl_stnd_idx) : plman.GetPlaylistFocusItemIndex(pl_stnd_idx), items, true);
            plman.InsertPlaylistItems(cache_2nd_pl, !insert ? plman.PlaylistItemCount(pl_stnd_idx) : plman.GetPlaylistFocusItemIndex(pl_stnd_idx), items, true);//my solution
const f_ix = !insert || plman.GetPlaylistFocusItemIndex(pl_stnd_idx) == -1 ? plman.PlaylistItemCount(pl_stnd_idx) - items.Count : plman.GetPlaylistFocusItemIndex(pl_stnd_idx) - items.Count;
plman.SetPlaylistFocusItem(pl_stnd_idx, f_ix);
plman.EnsurePlaylistItemVisible(pl_stnd_idx, f_ix);
if (autoPlay) {
const c = (plman.PlaybackOrder == 3 || plman.PlaybackOrder == 4) ? Math.ceil(plman.PlaylistItemCount(pl_stnd_idx) * Math.random() - 1) : 0;
plman.ExecutePlaylistDefaultAction(pl_stnd_idx, c);
3. In the 1st panel I added a moded panel: source=library (view by folder structure), in behaviour tab set default playlist=Library artist cache (mode=browser).
4. In the 2nd panel - original panel: source=playlist "Library folder cache", in behaviour tab set default playlist="Library artist cache"  (mode=browser).
5. In the 3d panel - original panel: source=playlist "Library artist cache", in behaviour tab set default playlist="Library album cache"  (mode=browser).
Now Cue_fixer works fine with CUE & view by folder structure: clicking in the 1st panel creates 2 playlists: "Library folder cache" and Library artist cache. The 2nd panel is linked to the "Library folder cache" playlist. The 3rd panel is linked to the "Library artist cache" playlist. Clicking in the 3rd pane creates an independent "Library album cache" playlist.
X
P.s. Maybe the author will do a better job in the next update!
Reply #606
I would appreciate to be able to identify the current branch in a secondary node.
In my scenario, I tag tracks with the birth place and, sometimes, the background of people (with the three-letter-code for Regor's World-Map) as follows:
%composer-iso3166% ("SVN; Slovenia" for Hugo Wolf)
%composer-iso3166-b% ("AUT; Austria" for Hugo Wolf)
%lyricist-iso3166% ("BRA; Brasil" for Alfredo Le Pera)
%lyricist-iso3166-b% ("ARG; Argentina" for Alfredo Le Pera)
%artist-iso3166% ("USA; United States of America" for Cathy Berberian)
%artist-iso3166-b% ("ARM; Armenia" for Cathy Berberian)
%group-iso3166% ("FRA; France" for Orange Blossom)
%group-iso3166-b% ("EGY; Egypt" for Orange Blossom)
%producer-iso3166% ("DZA; Algeria" for Hector Zazou)
%producer-iso3166-b% ("FRA; France" for Hector Zazou)
And I'm trying to set some branches:
Country
   Composers & Lyricists
   or
   Performers & Producers
      By their birthplace
      or
      By their background
         Name
            Album
but I'm loosing track of where I am in each step because tracks are indeed filtered including maybe a composer of the "right" country performed by an artist of a different one, so I'd need to know which is the right country to further filter tracks (so that these tracks get listed under the composer's name but the performer's name doesn't get highlighted as for the same nationality).
Spoiler (click to show/hide)
I've also tried to write all nodes at once, when parsing tracks in the topmost filter, but failed when going for successive criteria because all "¦" must be resolved before any "|", I guess:
%country%|'Composers & Lyricists'|'By their birthplace'|%composer%|%album%|%<track>%
%country%|'Performers & Producers'|'By their birthplace'|%artist%|%album%|%<track>%
Thanks in advance!
Reply #607
I recently switched from the old facets to library tree. I'm getting used to it, trying to recreate my old setup with this new tool.
I use several library tree panels as facets, linked together as explained in the help. It's working as intended.
One thing I miss, is being able to reorder my views by number of sub-items.
For example, I use a lot of different Genre tags, and sometimes I want to browse my facet panel alphabetically, sometimes I want to order by the number of albums in that genre. There is no such option in the "sort selected view" submenu. Is there some tweak to make it possible?
X
Thank you for your help, and thanks to the amazing work you're all doing!
