I don't want to assume it's foobar2k but it just so happens that it happened again some 10 minutes ago and the last thing I did was switch to foobar2k.
Issue- Lockup. The current song will continue to play but after it finishes it'll stop (remains 'locked' during this whole time except for mouse - read below)
- Mouse seems to work (can move it around, clicking does nothing).
- Keyboard does not respond (pressing NUM LOCK does not turn ON/OFF the LED; ALT-TAB, WINDOWS KEY, WINDOWS KEY+Another Key, etc does not work).
- I haven't just let it sit for more than 1minute to see what would happen, I assume it would remain in that state so I just perform hard reboot.
- Has happened about 3~4 times (since I last installed SP2, don't recall it happening when I was SP1).
- Event Manager does not detect anything, Windows does not reports anything.
How to reproduce (or at least I think these are the steps that leads to it).
Basically switching to and from (last crash was switching to) foobar2k locked my system up. Programs that I was using when I switched: Azureus and eMule variant (VeryCD). The last crash I switched from eMule to foobar2k (switching meaning, I was messing around with eMule then I clicked foobar2k in taskbar). foobar2k will come up but after that the above happens. A previous crash I think involved Azureus and I want to say that I was switching from foobar2k to Azureus but I can't say for sure. I haven't really been able to find the steps to guarantee a crash. Things that are always running when this occur (and are usually running anyways): Azureus, Firefox, MSN Live Messenger. Please let me know if I should try to find the exact steps (I really don't want to do it but will if that's the only way to narrow down the possible cause).
Possible Causes (or I think are possible causes or at least places to start)
foo_scheduler (2.2.1 should be latest according to this post on page . But I'm not sure what switching to foobar2k has to do with this component. This is the newest component I've added though and I did not have this issue previously on SP1 (did not have this lockup issue nor foo_scheduler). I have had similar lockup issues with MSN Live Messenger but I don't think they occurred on SP1 (I have used foo_toaster with SP1 and am currently using it). The issue with MSN Live Messenger is that when it changes what I'm playing it would lockup (typically only happens as I'm signing in and just loaded up foobar2k but this hasn't happened in a while - or at least I've stopped doing something that leads to it happening specifically, now I always open Azureus, foobar2k, (wait for both to load up), then Firefox and sign in to MSN Messenger (last two in no particular order).
Since being on SP2, I have probably switched to v0.9.x at least twice (or at least tried to switch) and found that it really didn't do what I was used to do with the older version (I'm completely dependent on masstagger which seems to perform the same, freedb which doesn't seem to be quite the same, and some other features I'm sure I've forgotten). Perhaps I need to completely un-install foobar2k? If so can I just un-install, reboot, install, add the 2 component (including iconv.dll), replace new "\Application Data\foobar2000\foobar2000.cfg" with old one?
Component List
06/27/2004 02:30 PM 32,768 foo_abx.dll
04/24/2004 06:25 AM 69,632 foo_ac3.dll
07/21/2004 03:00 PM 34,304 foo_albumlist.dll
06/29/2004 07:11 AM 114,688 foo_ape.dll
02/25/2004 10:29 AM 24,576 foo_apl.dll
06/27/2004 02:30 PM 19,968 foo_bitcompare.dll
01/22/2004 12:46 PM 36,864 foo_burninate.dll
06/27/2004 02:30 PM 33,792 foo_cdda.dll
06/27/2004 02:32 PM 30,208 foo_clienc.dll
06/27/2004 02:30 PM 14,336 foo_console.dll
04/03/2004 02:58 AM 301,568 foo_convolve.dll
06/13/2004 01:22 PM 87,552 foo_dbsearch.dll
06/13/2004 03:59 AM 8,868 foo_dbsearch_help.html
06/27/2004 02:30 PM 59,904 foo_diskwriter.dll
02/25/2004 10:29 AM 10,240 foo_dsp_crossfade.dll
11/22/2003 12:23 PM 9,216 foo_dsp_crossfeed.dll
06/27/2004 02:31 PM 76,800 foo_dsp_extra.dll
02/25/2004 10:29 AM 12,288 foo_dsp_nogaps.dll
04/24/2004 06:28 AM 9,728 foo_dsp_pause.dll
02/25/2004 10:29 AM 9,216 foo_dsp_skip_silence.dll
02/28/2004 05:28 PM 33,280 foo_dsp_soundtouch.dll
02/25/2004 10:29 AM 13,824 foo_dynamics.dll
05/16/2004 01:21 AM 192,000 foo_faac.dll
09/05/2004 07:41 AM 158,208 foo_festalon.dll
09/12/2004 01:32 AM 100,352 foo_flac.dll
05/16/2004 03:19 AM 78,848 foo_flaccer.dll
10/29/2003 07:36 AM 180,736 foo_freedb.dll
08/31/2004 12:56 PM 51,200 foo_history.dll
09/09/2004 12:13 AM 181,248 foo_id3v2.dll
02/18/2004 01:18 PM 58,368 foo_infobox.dll
09/04/2004 10:21 AM 553,984 foo_input_std.dll
02/25/2004 10:31 AM 16,896 foo_lpac.dll
06/30/2004 07:58 PM 63,488 foo_masstag.dll
07/21/2004 10:25 AM 265,216 foo_matroska.dll
09/09/2004 01:49 AM 24,064 foo_mod.dll
09/05/2004 02:11 AM 100,352 foo_monkey.dll
03/18/2004 01:58 PM 157,184 foo_mpeg4u.dll
04/24/2004 07:11 AM 139,264 foo_nez.dll
02/25/2004 10:31 AM 10,240 foo_null.dll
05/01/2004 10:28 AM 12,800 foo_ofr.dll
06/12/2004 09:26 AM 1,022,976 foo_oggpreview.dll
06/27/2004 02:32 PM 20,480 foo_output_std.dll
06/27/2004 02:32 PM 20,480 foo_out_dsound_ex.dll
06/27/2004 02:31 PM 31,232 foo_out_ks.dll
05/17/2004 01:16 AM 61,440 foo_playlistgen_ex.dll
05/23/2004 08:04 AM 47,104 foo_pphsresample.dll
08/23/2004 12:38 AM 145,408 foo_psf.dll
06/27/2004 02:32 PM 24,064 foo_read_http.dll
06/14/2004 05:51 PM 42,496 foo_rgscan.dll
12/04/2004 02:09 PM 73,216 foo_scheduler.dll
06/13/2004 05:29 AM 12,800 foo_scroll.dll
06/27/2004 02:32 PM 16,896 foo_search_ex.dll
06/06/2004 08:08 AM 49,152 foo_shn.dll
02/24/2004 06:35 PM 279,040 foo_sid.dll
06/27/2004 02:32 PM 54,272 foo_spc.dll
05/16/2004 01:28 AM 89,088 foo_speex.dll
10/28/2003 09:15 AM 28,160 foo_tfmx.dll
03/04/2005 11:29 PM 110,592 foo_toaster.dll
08/30/2004 08:33 AM 20,480 foo_tta.dll
08/30/2004 08:37 AM 19,968 foo_tta_old.dll
09/04/2004 06:38 AM 180,736 foo_ui_columns.dll
06/27/2004 02:32 PM 83,968 foo_ui_std.dll
06/27/2004 02:32 PM 164,864 foo_unpack.dll
08/23/2004 12:29 PM 57,856 foo_utils.dll
06/27/2004 02:32 PM 15,360 foo_vis_manager.dll
11/10/2003 02:01 AM 24,064 foo_vis_simple_spectrum.dll
08/08/2004 01:15 AM 1,095,168 foo_vorbisenc.dll
08/04/2004 08:30 AM 61,952 foo_wavpack.dll
09/05/2004 02:42 AM 90,624 foo_wma.dll
04/24/2004 07:08 AM 57,344 foo_xa.dll
The only other component that is "new" to a clean install would be foo_toaster (hopefully that's the only new one).
Windows XP SP2 (I have been keeping up with updates to the best of my knowledge)
DirectX 9.0c
ASUS P4P800E-Deluxe (using built-in sound card)
NVIDIA FX 5700LE
NOD32
User Interface Module: Default User Interface
Output Method: waveOut
Please let me know if I have omitted important information. I don't really think it's foobar2k and I'm hoping that's the answer I'll get but I really don't know what's causing the problem.
