HydrogenAudio
CD-R and Audio Hardware => Audio Hardware => Topic started by: tahaa7 on 2012-07-14 20:24:06
Title: S/PDIF output from PC to DAC?
Post by: tahaa7 on 2012-07-14 20:24:06
I'm considering getting the Musical Fidelity M1 DAC, and I have one important question upon which my purchase depends.
Since M1's USB input is actually quite bad for the price, in that it only supports up to 16-bit/48kHz signals, I've been considering connecting the DAC to my PC's onboard S/PDIF optical out. Now: how much does the quality of S/PDIF out depend on the quality of the (onboard) soundcard and the motherboard in general? Will there be additional jitter and/or interference caused by my PC's circuitry?
I have a Realtek ALC888 chip, and the motherboard is MSI K9N2 Platinum.
Thanks for help.
Post by: kiit on 2012-07-15 01:18:18
no, that works best.
Post by: Light-Fire on 2012-07-15 05:25:18
... it only supports up to 16-bit/48kHz signals...
That should be more than enough resolution for you. Here is a very informative article about high resolution audio:
http://people.xiph.org/~xiphmont/demo/neil-young.html (http://people.xiph.org/~xiphmont/demo/neil-young.html)
Post by: Porcus on 2012-07-15 10:13:08
FWIW, http://www.musicalfidelity.com/m1dac/ (http://www.musicalfidelity.com/m1dac/)  claims these specs:
1x XLR AES balanced digital input
1x RCA coaxial connector SPDIF 32-192 kbps (16-24 bit stereo PCM)
1x TOSLINK optical connector 32-96 kbps (16-24 bit stereo PCM)
1x USB type ‘B’ connector for computer/PDA - 16-24 bits, 32-96 kbps (Determined by source file/computer settings)
(Edit: of course your dealer might be pushing an old one ... hoping you'll never notice the difference  )
Post by: skamp on 2012-07-15 10:36:38
Someone should tell them that confusing kilohertz with kilobits per second looks awful on a website that features exclusively hi-fi equipment…
Post by: Porcus on 2012-07-15 10:57:19
Haha. My mental repair-on-the-spot left that mistake totally unnoticed.
Post by: tahaa7 on 2012-07-15 13:40:39
Yeah, an audio(phile) company that makes digital audio products doesn't know the difference between kbps and kHz... Makes me kinda not want to buy their DAC
Post by: JJZolx on 2012-07-15 21:14:31
Here's cult hero Monty making the same "mistake".
http://xiphmont.livejournal.com/58294.html (http://xiphmont.livejournal.com/58294.html)
Is there really a difference, other than 'kbps' is the more common terminology?
Edit:
Wow, what was I thinking? There is a big difference.
192 kHz is correct, while 192 kbps would be completely wrong. The sampling rate of CD audio is 44100 samples per second, or 44.1 kHz. At 2x16-bits per sample, the bitrate of CD audio is 1411.2 kbps.
When speaking of 24-bit/192 kHz they are indeed talking about the sampling rate, not the bitrate. I think the confusion arises from thinking about lossy encoding, which is typically expressed in kbps and 192 kbps happens to be a common CBR for Mp3 encoding.
Post by: phofman on 2012-07-16 06:52:31
Well, I would understand an end user being confused, but for a manufacturer to present such bummer on its presentation web page...
Post by: Porcus on 2012-07-16 10:55:15
That's just a sign that the electrical engineers have so much pride that they outright refuse to even read the marketing department's mumbojumbo snakeoil spin
Well seriously, I could have read the same thing over and over again without noticing it. If you don't notice it first or second time, you read it as you remember it.
Post by: JJZolx on 2012-07-16 11:10:24
"192 kHz" is not wrong. You are the ones who are confused.
Post by: Mark7 on 2012-07-16 11:57:39
Funny thing is that Musical Fidelity makes the same mistake more than once, for example:
http://www.musicalfidelity.com/m1clic/ (http://www.musicalfidelity.com/m1clic/)
http://www.musicalfidelity.com/products/vSeries/v-dacii/ (http://www.musicalfidelity.com/products/vSeries/v-dacii/)
Post by: LithosZA on 2012-07-16 12:24:24
Strange, it seems that they use Khz in the 'DESIGN + BUILD' section, but then use 'kbps' in the 'SPECIFICATIONS' section.
The M1 CLiC happily handles the following formats: FLAC (up to 24bit/192kHz wired; 24bit/96kHz wireless); WMA/9 (up to 16bit/48Hz); AAC and HE-AAC (up to 24bit/96Hz); LPCM (up to 24bit/192kHz wired; 24bit/96kHz wireless); Ogg vorbis (up to 16bit/32kHz) and MP3 (up to 16bit/48kHz).
Only up to 16bit/32kHz for Ogg Vorbis? Why???
Post by: Porcus on 2012-07-16 13:28:06
Now you are reading the wrong article again
Post by: Arnold B. Krueger on 2012-07-16 15:37:45
Also pretty horrific from a price/performance viewpoint.
For the price of he MF M1 DAC, one would hope that it has good jitter resistance.
Jitter might be audio's  bogey man, a fable told to naive people to scare them.
Here's some online tech tests (I translated from Russian using Chrome)
Audio Rightmark ALC 888 on MSI system board (http://www.ixbt.com/mainboard/msi/rmaa/x48c-platinum-alc888.htm)
Really look pretty darn good to me!
What sounds bad about this setup now?
Post by: nagual on 2012-07-16 19:01:16
Thanks for help.
From the experience with my rig (Asus A8V-X onboard S/PDIF -->Asus Toslink bracket -->Optical cable -->Fiio D3 (dac) -->RCA cable (Belkin) -->Edifier M3400 (2.1 speakers),  I believe there´s some kind of interaction between the  internal EMI/RFI of the PC and the Toslink connector,  generating audible noise from the speakers.
Post by: pdq on 2012-07-16 19:43:02
I somehow doubt that. You should run RMAA to verify.
Post by: mixminus1 on 2012-07-16 21:06:33
The only way noise from the PC could end up in a TOSLink S/PDIF stream is if the mobo audio chip was doing a D/A->A/D conversion...highly unlikely.
Much more likely is that the interference is occurring on the USB power that the D3 is running on.
Post by: Arnold B. Krueger on 2012-07-17 00:00:34
Thanks for help.
What is the nature of the noise? When do you hear it?
Post by: nagual on 2012-07-17 01:56:54
Hiss.
First, I took off a 120mm fan that was at the back of the case.  Later I´ve wrapped up the toslink  bracket, five or six times, with tinfoil, just making holes to pass the cables.  After that, not only the hiss is  gonne, but sound quality increased so much, that is difficult to me stop listenning to jazz at Grooveshark...
Well, maybe  it´s all in my mind, I don´t know, but definetly I´m enjoyng it !
P.S.: I believed optical connections were noiseless, until I read this post, that seemed to make sense to me:
"EMI/RFI will not travel down an optical link."
(reply)
"EMI/RFI will not travel down the optical link. However, the timing of the optical pulses is affected by EMI/RFI inside the source box and when the pulses are reconverted to electrical signals at the DAC this EMI/RFI will be resurrected, albeit in an altered form."
Tony Lauck  at http://www.audioasylum.com/cgi/vt.mpl?f=pcaudio&m=109574 (http://www.audioasylum.com/cgi/vt.mpl?f=pcaudio&m=109574)
(any misunderstandings are due to my ignorance in electricity and in english, so forget)
Post by: uart on 2012-07-17 15:46:40
Hiss.
Wrapping an optical cable in tinfoil will do absolutely nothing to improve the signal or reduce jitter. So yeah it's all in your mind.
You might not care whether or not the "improvement" is placebo, but most others here won't appreciate fud like this being spread. So please either show some measurements of the reduced noise level (if you can hear it then RMAA will definitely show it) or stop violating TOS8.
Post by: Arnold B. Krueger on 2012-07-17 16:26:10
Hiss.
(reply)
The foil isn't making any differences in the timing of the pulses.  Removing any possible effects of minor pulse timing variations is the job of the DAC.
I would have to see some reliable tests to confirm what I've seen so far.  I've been working with TOSLink for about decade and never saw or heard anything like this.
Post by: nagual on 2012-07-17 19:23:03
From: http://www.digikey.com/Web%20Export/Suppli...df?redirected=1 (http://www.digikey.com/Web%20Export/Supplier%20Content/Toshiba_264/PDF/Toshiba_BCE0037_catalog.pdf?redirected=1)
Precautions for Using TOSLINK
The case for the TOSLINK (simplex) optical receiving module and (duplex) optical transceiver module is made of conductive
plastic.
The case is designed to provide shielding against noise when the reinforcing pin at the front of the module is grounded. When the
module is used, this pin should be connected to the signal ground.
Since the case for the optical receiving module and optical transceiver module has a resistance of several tens of ohms, ensure that the
case does not touch the power line or any other circuits.
Generally, the use of optical transmission devices is considered to improve noise resistance.
While optical fibers are certainly not affected by noise, optical modules, particularly receiver modules, are comparatively easily affected
by noise because they handle such minute current signals.
To improve noise resistance, the TOSLINK case is treated to make it conductive. However, since the signal output from the optical
receiving modules photodiode is a minute current signal, in some environments simply shielding the case will not protect against noise.
When using a TOSLINK device, conduct live tests to check noise resistance.
A simple noise filter is mandatory for the power lines for the TOSLINK optical receiving module and optical transceiver module.
However, in the case of significant power supply ripples, further filter reinforcement is also necessary
. In addition, when the optical
module is placed in a location susceptible to emission noise, Toshiba recommends covering the optical module and power supply filter
with a metal cover to enhance the shielding.
Of course this not means that there´s noise interacting with my optical connection, or that it is audible.  On the other hand, I´ll try to make the RMAA tests,  whatever they be, and post them here (but only if they confirm my suspicions...)
Post by: pdq on 2012-07-17 19:44:43
Please post the results regardless of what they confirm.
Post by: uart on 2012-07-17 19:55:27
plastic.
The case is designed to provide shielding against noise when the reinforcing pin at the front of the module is grounded. When the module is used, this pin should be connected to the signal ground.
The passage refers to the electrical shielding (in noisy environments) of the *receiver*  (where the optically generated *electrical* currents really are initially very small at the detector front end). You are trying to shield the transmitter - a totally different scenario.
Download RMAA here: http://audio.rightmark.org/download.shtml (http://audio.rightmark.org/download.shtml)
Ok that is just being silly. Unless that's a joke then it shows that you have no interest at all in disseminating the truth, and a on the contrary, no qualms as all about spreading FUD!.
Post by: Arnold B. Krueger on 2012-07-17 21:29:27
If I tried to pull a self-serving  trick like that, people of the "24 bits is audibly superior" persuasion would be screaming for my head!
BTW, when did intellectual honesty die?
Post by: mzil on 2012-07-17 23:59:27
I think (I hope) he means, "I'll post the results unless it turns out I was just imagining things as has been suggested, in which case I'll freely admit my error, but wont bother to waste forum space by posting two nearly identical sets of results."
