Topic: foo_uie_wmpvis (Read 68292 times) previous topic - next topic
foo_uie_wmpvis
Okay I see for example :
Menu:
- Alchemy  -> Random
- White cap -> Random
- Untermalende Farben (don't know what the english translantion is)->Nordlichter
        -> Einskristalle
        -> and so on...
Window edge -> None etc.
[checkmark or not]  Active Window
Config
My first idea that I can click on config.
Now am I right that the context item will show if the vis has a config dialog?
So if not the "config" will appear but won't work?
I thought that the "->" is already the config options
I am confused
Okay now I get it I installed the twisted pixel thing
result -> when choosing twisted pixel the opens a config box.
When I choose anonther vis i can see config but no results when clicking.
foo_uie_wmpvis
if you have at least one vis available, you'll see a SEPARATOR LINE after the last one.
everything above the separator line are specific to the wmp vis available.
under it, they are specific to my component, with only one exception, "config".
this item is for configuring the current vis (more specific, the current preset setting of the current vis).
ok, if the current one has a config dialog, the item will be enabled, and when you click it, it will show the dialog.
if it doesn't have a config dialog, the item will be disabled.
you need to understand the WMP vis, give you an example:
if there's only one vis called V and it has 3 presets V1, V2, V3, what you see when you right click is:
V
  -> V1
  -> V2
  -> V3
Window Edge
Always Active
Config
foo_uie_wmpvis
Thanks for this, the new version seem to be working well for me, it is much appreciated.
Feature suggestions:
1)I would like store a visualisation name for a track in a tag and have that visualisation selected whenever that track is played.
I'm not sure whether this is a difficult or easy request.
Maybe you could provide these functions in your component and/or expose the name of the current visualisation and the context menu so thay can be used in panels_ui.
2)visualisation menu commands which can be linked to buttons etc. in panels_ui
e.g. next visualisation, previous visualisation, random visualisation....
foo_uie_wmpvis
Finally! Poor visualization support was the only thing I didn't like about Foobar. I still can't get G-Force to work, though. For some reason, it just doesn't recognize when Foobar's playing, whether it be using the stand-alone or this. All the other visualizations work fine though.
foo_uie_wmpvis
I just got this crash log right when I changed songs:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0043F7A9h
Access violation, operation: write, address: 00000000h
Call path:
entry=>app_mainloop=>on_playback_stop=>play_callback_manager::unregister_callback
Code bytes (0043F7A9h):
0043F769h:  89 0D 00 00 00 00 C9 C2 0C 00 B8 59 64 4A 00 E8
0043F779h:  2F 6A 06 00 83 EC 0C 68 8C 25 4C 00 8D 4D F0 FF
0043F789h:  15 C4 44 4B 00 83 65 FC 00 B9 4C E4 4D 00 E8 14
0043F799h:  AF FC FF 84 C0 74 09 80 3D FD 18 4E 00 00 74 07
0043F7A9h:  C6 05 00 00 00 00 00 A1 1C ED 4D 00 8B 0D 24 ED
0043F7B9h:  4D 00 56 57 8D 34 01 33 FF 85 F6 76 25 8B C7 B9
0043F7C9h:  1C EC 4D 00 E8 80 04 00 00 8B 00 3B 45 08 74 07
0043F7D9h:  47 3B FE 72 E8 EB 0B 8D 45 E8 50 8B C7 E8 5D 00
Stack (0012EFBCh):
0012EF9Ch:  00000000 EF596DD8 EF596AB4 7FFDE6CC
0012EFACh:  EF596B74 804E2490 804E5760 FFFFFFFF
0012EFBCh:  0012F1F4 05C8E7AB 00000025 0012F1E8
0012EFCCh:  004A6459 00000000 0012F1F4 05C86A6E
0012EFDCh:  05CA81BC 00000000 00000000 00000000
0012EFECh:  00000000 00000000 00000000 00000000
0012EFFCh:  00000000 00000000 00000000 00000000
0012F00Ch:  00000000 020A0014 00000000 00000000
0012F01Ch:  00FFFF00 00000000 00000000 0012F098
0012F02Ch:  00000000 020A0014 7FFDEC00 00003608
0012F03Ch:  00000000 7C915707 00020000 0012F064
0012F04Ch:  0012F064 0012F064 00000002 00000002
0012F05Ch:  0012F09C 7C90EFE3 00000000 00003608
0012F06Ch:  0012F1D4 0012F10C 0012F1D4 7C915A00
0012F07Ch:  0012F0C0 7FFDEBF8 0025BAC8 7C915A65
0012F08Ch:  7C916924 7C97C2C0 00252570 00000000
0012F09Ch:  7FFDEBF8 0012F230 00000000 0012F288
0012F0ACh:  00000000 0012F2B8 00000000 0012F130
0012F0BCh:  00000000 00000000 00000000 020A0014
0012F0CCh:  7FFDEC00 00000000 0012F100 00000000
Registers:
EAX: 00000001, EBX: 004C25E8, ECX: 004DE44C, EDX: 00000001
ESI: 00000000, EDI: 00000002, EBP: 0012EFD4, ESP: 0012EFBC
Crash location: "foobar2000", loaded at 00400000h - 004F3000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
MSCTF                            loaded at 74720000h - 7476B000h
foo_abx                          loaded at 00A20000h - 00A54000h
foo_albumlist                    loaded at 00A60000h - 00AA7000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_audioscrobbler              loaded at 00AC0000h - 00AF8000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 00B20000h - 00B50000h
foo_browser                      loaded at 00B70000h - 00BA9000h
foo_burninate                    loaded at 00BD0000h - 00C07000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00C30000h - 00C66000h
foo_cleartype                    loaded at 00C90000h - 00CAA000h
foo_cmd_playlist                loaded at 00CD0000h - 00CE8000h
foo_common                      loaded at 00D10000h - 00D43000h
foo_converter                    loaded at 00D70000h - 00DD9000h
foo_convolve                    loaded at 00E00000h - 00E51000h
foo_cuesheet_creator            loaded at 00E80000h - 00EAD000h
foo_cwb_hooks                    loaded at 00ED0000h - 00F05000h
foo_dbsearch                    loaded at 00F30000h - 00FA0000h
foo_dbsearch_api_demo            loaded at 00FC0000h - 00FE1000h
foo_default_videoplayer          loaded at 01010000h - 0101D000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_discogs                      loaded at 01040000h - 010BA000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dop                          loaded at 01160000h - 011BD000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_dsp_continuator              loaded at 011E0000h - 01212000h
foo_dsp_crossfader              loaded at 01240000h - 0124D000h
foo_dsp_delta                    loaded at 01260000h - 0127E000h
foo_dsp_silence                  loaded at 012A0000h - 012C9000h
foo_dsp_skip_silence            loaded at 012F0000h - 012FA000h
foo_dsp_soundtouch              loaded at 01310000h - 0131F000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_dsp_ssrc                    loaded at 01330000h - 01363000h
foo_dsp_ssrc_sse2                loaded at 01380000h - 013B6000h
foo_dsp_std                      loaded at 013D0000h - 01411000h
foo_dsp_vlevel                  loaded at 01440000h - 01464000h
foo_dsp_winamp                  loaded at 01490000h - 014B3000h
foo_dsp_xbass                    loaded at 014E0000h - 014FE000h
foo_dts                          loaded at 01520000h - 01557000h
foo_freedb2                      loaded at 01570000h - 015B0000h
foo_fullscreen                  loaded at 015D0000h - 015EB000h
foo_gasazip                      loaded at 01610000h - 01663000h
foo_gep                          loaded at 01690000h - 01728000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_highlightplaying            loaded at 01750000h - 01771000h
foo_infobox                      loaded at 017A0000h - 017E0000h
foo_input_awma                  loaded at 01800000h - 01819000h
WMVCore                          loaded at 15110000h - 1536A000h
WMASF                            loaded at 11C70000h - 11CA9000h
foo_input_mslive                loaded at 01830000h - 018A6000h
libmmd                          loaded at 018C0000h - 01B71000h
foo_input_reverse                loaded at 01B90000h - 01BBA000h
foo_input_shorten                loaded at 01BD0000h - 01BFD000h
foo_input_std                    loaded at 01C20000h - 01D34000h
foo_lnk                          loaded at 01D60000h - 01D79000h
foo_masstag                      loaded at 01DA0000h - 01DF0000h
foo_masstag_addons              loaded at 01E10000h - 01E1E000h
foo_masstag_replace              loaded at 01E30000h - 01E61000h
foo_menu_addons                  loaded at 01E90000h - 01EAF000h
foo_minimize_on_close            loaded at 01EC0000h - 01ED6000h
foo_navigator                    loaded at 01F00000h - 01F31000h
foo_notaskbar                    loaded at 01F60000h - 01F76000h
foo_notitlebar                  loaded at 01FA0000h - 01FA8000h
foo_out_ks                      loaded at 01FC0000h - 01FEB000h
foo_playcount                    loaded at 02010000h - 02038000h
foo_playcount_mod                loaded at 02060000h - 02075000h
foo_playlist_manager            loaded at 02090000h - 020D4000h
foo_playlist_tree                loaded at 02100000h - 02175000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 021A0000h - 02244000h
foo_pqview                      loaded at 02290000h - 022AB000h
foo_prettypop                    loaded at 022D0000h - 0231D000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_preview                      loaded at 047C0000h - 047E1000h
foo_random                      loaded at 04880000h - 048BD000h
foo_rgscan                      loaded at 048E0000h - 04928000h
foo_rg_trn                      loaded at 04950000h - 0496B000h
foo_run                          loaded at 04990000h - 049BB000h
foo_runcmd                      loaded at 049E0000h - 04A0F000h
foo_scrobblecharts              loaded at 04A30000h - 04A63000h
WININET                          loaded at 771B0000h - 7725A000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_sic                          loaded at 04A90000h - 04AE9000h
foo_skip                        loaded at 04B10000h - 04B2B000h
foo_snap                        loaded at 04C60000h - 04C76000h
foo_timebomb                    loaded at 04CA0000h - 04CCA000h
foo_tlbRC                        loaded at 04CF0000h - 04D10000h
foo_trackpos                    loaded at 04D30000h - 04D4F000h
foo_tradersfriend                loaded at 04D70000h - 04DAA000h
foo_uie_albumart                loaded at 04DD0000h - 04E0C000h
foo_uie_bookmarks                loaded at 04E30000h - 04E7D000h
foo_uie_console                  loaded at 04E90000h - 04EAC000h
foo_uie_explorer                loaded at 04ED0000h - 04F0C000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_uie_lyrics_panel            loaded at 04F30000h - 04F99000h
foo_uie_queuemanager            loaded at 04FC0000h - 04FF9000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 052E0000h - 05328000h
foo_uie_single_column_playlist  loaded at 05330000h - 0537C000h
foo_uie_tabs                    loaded at 05380000h - 053AA000h
foo_uie_trackinfo                loaded at 053D0000h - 053FE000h
foo_uie_trackinfo_mod            loaded at 05420000h - 05476000h
foo_uie_vis_projectm            loaded at 05490000h - 054DA000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_uie_wmpvis                  loaded at 05C80000h - 05CBB000h
foo_ui_columns                  loaded at 05CD0000h - 05D68000h
foo_ui_std                      loaded at 05D90000h - 05DE7000h
foo_unpack                      loaded at 05E10000h - 05E3E000h
foo_utils                        loaded at 05E60000h - 05E98000h
foo_utils_playback              loaded at 05EC0000h - 05ED9000h
foo_version                      loaded at 05F00000h - 05F26000h
dbghelp                          loaded at 59A60000h - 59B01000h
foo_whatsnew                    loaded at 06050000h - 06080000h
foo_winamp_spam                  loaded at 060A0000h - 060D0000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
PopUpIcons                      loaded at 06430000h - 06436000h
appHelp                          loaded at 77B40000h - 77B62000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
MPR                              loaded at 71B20000h - 71B32000h
drprov                          loaded at 75F60000h - 75F67000h
ntlanman                        loaded at 71C10000h - 71C1E000h
NETUI0                          loaded at 71CD0000h - 71CE7000h
NETUI1                          loaded at 71C90000h - 71CD0000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
NETRAP                          loaded at 71C80000h - 71C87000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
davclnt                          loaded at 75F70000h - 75F79000h
gasazip                          loaded at 0A900000h - 0A9D4000h
URLMON                          loaded at 7E1E0000h - 7E282000h
olepro32                        loaded at 5EDD0000h - 5EDE7000h
Wship6                          loaded at 58D40000h - 58D47000h
shdocvw                          loaded at 7E290000h - 7E401000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
Secur32                          loaded at 77FE0000h - 77FF1000h
SXS                              loaded at 75E90000h - 75F40000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
wshbth                          loaded at 751D0000h - 751EE000h
mdnsNSP                          loaded at 16080000h - 16099000h
Iphlpapi                        loaded at 76D60000h - 76D79000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
mslbui                          loaded at 605D0000h - 605D9000h
DesktopSearchSystem2526          loaded at 0FE70000h - 0FE77000h
msi                              loaded at 105D0000h - 10896000h
TwistedPixel                    loaded at 10240000h - 10307000h
d3d8                            loaded at 6D9A0000h - 6DAC8000h
d3d8thk                          loaded at 6D990000h - 6D996000h
mpvis                            loaded at 10310000h - 1034E000h
wa_avs                          loaded at 10350000h - 10391000h
vis_avs                          loaded at 10AA0000h - 10B1B000h
MSVFW32                          loaded at 75A70000h - 75A91000h
AVIFIL32                        loaded at 73B50000h - 73B67000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
DSOUND                          loaded at 73F10000h - 73F6C000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
Stack dump analysis:
Address: 05C8E7ABh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 004A6459h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 05C86A6Eh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 05CA81BCh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 020A0014h, location: "foo_playlist_manager", loaded at 02090000h - 020D4000h
Address: 7C915707h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlHashUnicodeString" (+000002A2h)
Address: 7C90EFE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+000002E2h)
Address: 7C915A00h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+0000025Dh)
Address: 7C915A65h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+000002C2h)
Address: 7C916924h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+00000209h)
Address: 7C97C2C0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C916999h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+0000027Eh)
Address: 7C9169A5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+0000028Ah)
Address: 7C90EF43h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000242h)
Address: 7C91691Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+00000202h)
Address: 7CBB7B10h, location: "SHELL32", loaded at 7C9C0000h - 7D1D5000h
Address: 7C9C1D04h, location: "SHELL32", loaded at 7C9C0000h - 7D1D5000h
Symbol: "Ordinal517" (+00001D04h)
Address: 7C80B400h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameW" (+0000002Bh)
Address: 77C10280h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Address: 77D48B26h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 004DED54h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 05CA81ACh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 05C9F468h, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 05C9B075h, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 05C9AEB8h, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4C63Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 77D4E905h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallWindowProcA" (+0000001Bh)
Address: 103631A1h, location: "wa_avs", loaded at 10350000h - 10391000h
Address: 1036199Ch, location: "wa_avs", loaded at 10350000h - 10391000h
Symbol: "DllCanUnloadNow" (+000002DAh)
Address: 77D4B4C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B50Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D4B473h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D4DAF6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 10AE1FA1h, location: "vis_avs", loaded at 10AA0000h - 10B1B000h
Address: 10ADFD39h, location: "vis_avs", loaded at 10AA0000h - 10B1B000h
Address: 10ADFD41h, location: "vis_avs", loaded at 10AA0000h - 10B1B000h
Address: 1036461Dh, location: "wa_avs", loaded at 10350000h - 10391000h
Address: 10AEF9F8h, location: "vis_avs", loaded at 10AA0000h - 10B1B000h
Address: 05C83ADEh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 0040BC26h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C24ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 05CA81B4h, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 05C8DA9Fh, location: "foo_uie_wmpvis", loaded at 05C80000h - 05CBB000h
Address: 0043F137h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E18FDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A7FCAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440468h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440402h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A7D8Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044058Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440F1Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF178h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004544C5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A78CDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 053334D8h, location: "foo_uie_single_column_playlist", loaded at 05330000h - 0537C000h
Address: 004DEDF8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 06431917h, location: "PopUpIcons", loaded at 06430000h - 06436000h
Symbol: "HookProc_GetMsg" (+00000097h)
Address: 77D618F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D4B3A7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D4EA9Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 77D4EAADh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 77D4B3B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D4EAB0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 77D4EBF3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 77D4EC03h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 05338650h, location: "foo_uie_single_column_playlist", loaded at 05330000h - 0537C000h
Address: 0536A237h, location: "foo_uie_single_column_playlist", loaded at 05330000h - 0537C000h
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0533871Ah, location: "foo_uie_single_column_playlist", loaded at 05330000h - 0537C000h
Address: 00470046h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 05338695h, location: "foo_uie_single_column_playlist", loaded at 05330000h - 0537C000h
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 004301ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0560h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430CF3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC44Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004E41B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10003251h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uGetCallStackPath" (+00000451h)
Address: 004E3E80h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491D18h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040CA96h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004480F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004990ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496FE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0570h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF5D4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430EFAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049729Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935BCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935B6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B34A0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4228h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF9C8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496154h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
projectM visualization (Panel) 0.4  (foo_uie_vis_projectm)
Play Count Mod 1.0.2  (foo_playcount_mod)
FLAC Decoder 1.1.0  (foo_input_std)
Gasazip Lyric Plugin 1.4  (foo_gasazip)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
Convolver 0.3  (foo_convolve)
Database Search 1.4  (foo_dbsearch)
ReplayGain Scanner 2.0.2  (foo_rgscan)
ReplayGain override 0.1.1  (foo_rg_trn)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Run services 0.3.2  (foo_run)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Shorten decoder 0.4.2a  (foo_input_shorten)
Reverse Playback 0.1.1 (Intel SSE)  (foo_input_reverse)
foosic music database 1.0 beta 12  (foo_sic)
TLB Remote Control 2.1  (foo_tlbRC)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
Crossfader 0.1.6.2  (foo_dsp_crossfader)
Continuator 0.4.0  (foo_dsp_continuator)
VLevel 20060324.0  (foo_dsp_vlevel)
Menu Addons 0.3.6  (foo_menu_addons)
Randomized Playlist Entry 1.2.3  (foo_random)
Skip silence 0.1  (foo_dsp_skip_silence)
foo_skip 0.2  (foo_skip)
Acro WMA decoder 0.1.6.2  (foo_input_awma)
Highlight playing 0.1.0  (foo_highlightplaying)
Common services 0.1  (foo_common)
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
Masstagger Replace 0.0.1  (foo_masstag_replace)
Columns UI 0.1.3 beta 1v8 TEST  (foo_ui_columns)
Playlist Tools 0.5.9  (foo_utils)
CD Audio Decoder 2.1.1  (foo_cdda)
Kernel Streaming Output 1.2.1  (foo_out_ks)
WMP Visualizations 0.1.2 (Intel SSE)  (foo_uie_wmpvis)
Album List 3.2.0  (foo_albumlist)
Feature Watcher 1.0.1  (foo_whatsnew)
Masstagger 1.6  (foo_masstag)
Audioscrobbler 1.3.2  (foo_audioscrobbler)
Default User Interface 0.9acc  (foo_ui_std)
Converter 1.0.1  (foo_converter)
Navigator 0.6  (foo_navigator)
Preview 1.1  (foo_preview)
Playlist Commandline Tools 0.0.1  (foo_cmd_playlist)
Pretty Popup 1.2.3  (foo_prettypop)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Timebomb v0.0.1  (foo_timebomb)
xbass 1.0  (foo_dsp_xbass)
Hide Main Title Bar 1.0.0 [May 26 2006 - 09:32:33]  (foo_notitlebar)
WMA Decoder 1.1  (foo_input_std)
RAR reader 1.1  (foo_unpack)
freedb Tagger 0.5.2a  (foo_freedb2)
Game Emu Player 1.3  (foo_gep)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Audio CD Writer 2.0.1  (foo_burninate)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Playback Statistics 1.3.2  (foo_playcount)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Resampler DSP (SSRC) 0.57 SSE2  (foo_dsp_ssrc_sse2)
Default video player 0.1.3  (foo_default_videoplayer)
Fullscreen 0.3.1  (foo_fullscreen)
DTS decoder 0.1.1  (foo_dts)
Shell Link Resolver 1.2  (foo_lnk)
Playback Utilities 1.0  (foo_utils_playback)
Discogs Tagger 0.98  (foo_discogs)
Album Art Panel 0.2.6  (foo_uie_albumart)
SoundTouch DSP 0.1  (foo_dsp_soundtouch)
foobar2000 core 0.9.4.2  (Core)
Minimize On Close 0.2  (foo_minimize_on_close)
Track info panel 0.8  (foo_uie_trackinfo)
ABX Comparator 1.3.1  (foo_abx)
Track Positioner 1.0  (foo_trackpos)
Run Command 1.0 beta 2  (foo_runcmd)
Single Column Playlist Display 0.5.4 beta [Jan  9 2007 - 15:42:59]  (foo_uie_single_column_playlist)
Quick Search Toolbar 2.8i  (foo_uie_quicksearch)
mslive 0.3.7 (Intel SSE)  (foo_input_mslive)
Last.fm Chart Player 0.2.2  (foo_scrobblecharts)
Main window snapping 0.1  (foo_snap)
Components versions viewer 0.3  (foo_version)
Standard DSP array 1.0  (foo_dsp_std)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Winamp API Emulator 0.96  (foo_winamp_spam)
Bookmarks 0.2.2  (foo_uie_bookmarks)
iPod manager 0.3.9 TEST  (foo_dop)
Console panel 0.2  (foo_uie_console)
Post-track silence 0.0.2  (foo_dsp_silence)
Winamp DSP Bridge 1.4.1  (foo_dsp_winamp)
Special file info box 2.0.4  (foo_infobox)
Playlist Manager 1.0.2  (foo_playlist_manager)
ZIP/GZIP reader 1.0  (foo_unpack)
Resampler DSP (SSRC) 0.57  (foo_dsp_ssrc)
Masstagger Addons 0.3.2  (foo_masstag_addons)
Cleartype font support 0.3  (foo_cleartype)
Taskbar Button Remover 0.1  (foo_notaskbar)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
foo_uie_wmpvis
@Kiteroa,
no, as I said, I didn't intend to create this vis, I will not implement any features.
as long as it runs well, that's it.
@alphaex32,
were you editing your UI layout when it crashed?
foo_uie_wmpvis
@alphaex32,
Nope. It always happens when I am using the AVS visualization and I change songs. It might have more to do with the AVS WMP plugin than with your component.
foo_uie_wmpvis
Reply #32
A friend of mine is using foobar under Win Vista. Using this plugin there always appears a strange message saying that a side-by-side configuration is invalid.
I post this because I haven't heard of such a massegae concerning this plugin
foo_uie_wmpvis
I get crashes when using this as a tabbed panel. Same log as what was posted above, "illegal operation" yadda yadda yadda. It doesn't matter whether a song is playing or not. Anyone else see this?
Edit - Actually, the crashes seem to be dependent partly upon what visualization I'm using. For instance, if I use one from the 'color cubes' set, I always seem to get a crash, yet if I use something from 'battery' it works fine as a tabbed panel. Also, a few times it caused a crash as soon as I inserted it into my layout as a tabbed panel...probably because one of the offending visualizations was the first thing loaded, not sure though. It's strange.
foo_uie_wmpvis
Reply #34
Sorry to dig up such an old thread but I was wondering how to activate the visualization?
I've installed version 0.1.2
I've copied the "libmmd.dll" into the foobar folder.
I also copied the "MSDIA80.DLL" runtime library to the foobar folder.
I have the default WMP that comes with WinXP.
I can start playing music but I don't see anywhere an option to activate/show the visualization.
~HaiDozo
foo_uie_wmpvis
Reply #35
by inserting the wmp vis panel.
foo_uie_wmpvis
Reply #36
Ah...
Does that entail starting WMP?
~HaiDozo
foo_uie_wmpvis
Reply #37
no.
in fact even u don't have wmp installed but those visualizations only, you still can use this component.
foo_uie_wmpvis
Reply #38
Most excellent!
How do I go about inserting this wmp panel?
Do I need a special listview plugin perhaps, I'm currently using the default.
Regards,
Ignorant bastard .., I mean HaiDozo.
foo_uie_wmpvis
Reply #39
using columns ui, in its config of layout, insert the panel from visualization part.
read the relevant wiki for more info.
foo_uie_wmpvis
Reply #40
Now I feel stupid less than average, I still haven't gotten it to work.
I managed to successfully install Columns UI.
I read some of the wiki and I searched for "visualization" and "panel" but found nothing enlighting.
I looked in the prefs (File->Preferences->Columns UI) but failed to locate anything relating to visualization.
If I rightclick on the Toolbars I get a menu with an "Visualization" entry, alas it only contains the default "Spectrum analyser".
Am I looking in the wrong place?
~HaiDozo
foo_uie_wmpvis
Reply #41
Preferences -> Columns UI -> Layout.
Then right-click where you want to put it -> Insert Panel -> Visualizations.
foo_uie_wmpvis
Reply #42
i cant find how to insert foo_uie_wmpvis.dll into a panel. Please help me.
foo_uie_wmpvis
Reply #43
Acropolis: Does this plugin cause memory leak as projectM did? I took a quick look and it seems it doesn't, but i'm not sure.
azerty1234: Please, read previous replies.
foo_uie_wmpvis
Reply #44
the component itself doesn't leak, but not guarantee for the vis plugin being used.
foo_uie_wmpvis
Reply #45
Doesn't work for me. Upon starting foobar I get the following:
"Failed to load DLL: foo_uie_wmpvis.dll
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem. "
I've inserted the foo_uie_wmpvis.dll file into the MAIN foobar directory. Is it supposed to go somewhere else? I tried putting it into components but still the same error. Please help.
foo_uie_wmpvis
Reply #46
Menu:
- Alchemy  -> Random
        -> Einskristalle
        -> and so on...
Config
i've got vista rtm business with wmp11 and my wmp11 has alchemie, stripes and waves, and batterie but my foo_uie_wmpvis only shows alchemie?!?
foo_uie_wmpvis
Reply #47
probably the wmp in the business version is different from the ultimate version, I can't test it as I don't have that version.
foo_uie_wmpvis
Reply #48
I'm sorry, I can't seem to get this to work.
I have a panel with the wmpvis plugin and i have WMP 10 installed. I even installed this twisted pixel thing.
Now when starting foobar the plugin tells me, that it doesnt find any visualizations.
You said that it would support the bars and waves as well as the battery plugin. Both are present in my WMP 10 and when I right click the wmpvis panel it gives me a "twisted pixel" item, but clicking on that does nothing.
What am I doing wrong?
-----EDIT------
OK  I installed the WMP 11.
Now the plugin found more visualizations.
I may have selected the wrong plugin, because first nothing happened again. But then I restarted foobar, and it crashed.
I then had to remove the plugin from my foobar folder and restart foobar.
Foobar asked me if I wanted to keep the settings, or discard them.
I discarded and closed foobar.
Then I put the plugin back into the components directory and started foobar.
Now the plugin seems to work with the bars and waves.
-----EDIT2------
I think I figured out when foobar crashes:
If I have the wmpvis panel activated when starting foobar, it crashes.
If I activate the panel AFTER starting foobar it works fine.
So now I have to disable the panel every time I close foobar or else I can't start it.
Any way around this?
-vaddr-
foo_uie_wmpvis
Reply #49
I never get crash during startup with this component, but I recommend you to try the update I just made.
