Topic: Is there a way to create a CUE file based on this log file? (Read 773 times) previous topic - next topic
if so, how do you figure out the Index 00 and Index 01 value based on the table below?
Also I have the length of each song, but only to the minute for e.g., song 1 is 3:24 min., song 2 is 3:55 min., but I don't have the precise second figure, I suppose I can set it at 0.5 sec. per song
输出格式    : 内部WAV例程
采样格式    : 44.100 Hz; 16 Bit; 立体声
CD内容目录(TOC)
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.33 |  3:54.22 |        33    |    17604
        2  |  3:54.55 |  3:55.73 |     17605    |    35302
        3  |  7:50.53 |  3:50.25 |     35303    |    52577
        4  | 11:41.03 |  5:33.62 |     52578    |    77614
        5  | 17:14.65 |  3:42.08 |     77615    |    94272
        6  | 20:56.73 |  4:59.05 |     94273    |   116702
        7  | 25:56.03 |  4:14.22 |    116703    |   135774
        8  | 30:10.25 |  3:56.30 |    135775    |   153504
        9  | 34:06.55 |  7:29.53 |    153505    |   187232
       10  | 41:36.33 |  4:09.62 |    187233    |   205969
Re: Is there a way to create a CUE file based on this log file?
You have all information needed to create a cue in the table. The last portion after the dot in the time fields is sectors, just like in cue sheets. I assume the 33 sectors in the beginning have not been extracted so your cue can simply be constructed like this:
FILE "cdimage.wav" WAVE
  TRACK 01 AUDIO
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    INDEX 01 3:54:55
  TRACK 03 AUDIO
    INDEX 01 7:50:53
If you have extracted and included the 33 sectors before the first track then you can include the info in the cue:
  TRACK 01 AUDIO
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    INDEX 01 3:54:55
Those 33 sectors contain 33 * 588 samples of audio, that's 0.44 seconds.
