Topic: [crashware] foo_input_mslive (Read 274978 times) previous topic - next topic
Reply #250
What exactly has changed? I see the "display static info" checkbox but cannot sort out what it does. (Mainly because my Online Radio tag display is a code mayhem)...
static info is the first read of the track info.
dynamic info is the track info at different time.
Playing an asx-file created with your component crashes (the last beta of) foobar. I added this url: rtsp://213.200.97.107/energynuernberg$livestream.wma/
I don't have the crash, could it be another component?
updated for a minor bug though.
Reply #251
I'll check it out, since foo_uie_albumart made some trouble and could have been theh problem. I report back, as soon as I have news for you.
Reply #252
updated
Reply #254
Downloaded it now.
I've had problems with this great radio station  http://www.rgw.it/live.asx
The stream is alive, I tested with wmp. It doesn't play, also nothing happens if I use http://www.digital-webstream.de/stream/8770.asx
Possibly because the 8770.asx is broken?
<asx version="3.0">
<entry>
<ref href="http://www.digital-webstream.de/stream/8770.asx" />
<author>Radio Grüne Welle</author>
<copyright>(C) 2007 RGW</copyright>
</entry>
</asx>
http://server4.digital-webstream.de:8770
http://server4.digital-webstream.de:8770 works.
Maybe you can make your asx parser very "liberal" in what it plays? E.g. if it finds just one playable url, it should follow it, no matter if the asx may be standard compliant or not. And follow the first, if there's more than one... The old story, standard compliancy versus education
Reply #255
updated.
the parser really doesn't care about the referenced content
it supports playlist format types like asx, references, or direct links.
it's the mslive core's problem, that I didn't expect the REF element could be pointing to another playlist.
hopefully the new update should be liberal enough.
Reply #256
Works good, I reckon there will be less support questions like "does not play" here. Many thanks.
Reply #257
Hey, this is interesting: I tried to use the converter to dump a stream to disk, and it works with whatever encoder I use  The converter will be always open and I can still hear the stream.
Acropolis, what do you think: Does the converter use the existing stream or does it open a second connection? Especially, if the converter is running, I open another track and open the live stream again, will I then have two connections to the streaming server?
Reply #258
as I can see, the converter is just another instance (well, sort of) of the normal playback routine.
for each instance, it will have a connection.
so you have two connections when playing normally and using the converter at the same time.
Reply #259
updated.
Reply #260
You removed the dependencies, GREAT. Will you offer statically linked compiles for your other components as well? Thanks...
Reply #261
what a problem?
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 00E2AC4Dh
Call path:
entry
Code bytes (00E2AC4Dh):
00E2AC0Dh:  CC CC CC 55 8B EC 83 EC 0C 8B 45 08 56 57 89 55
00E2AC1Dh:  F4 89 45 F8 A8 0F 75 58 F6 C2 0F 75 53 8B D1 C1
00E2AC2Dh:  EA 04 83 E1 0F 89 55 FC 89 4D 08 85 D2 75 04 85
00E2AC3Dh:  C9 74 48 8B 75 F4 8B 7D F8 8B 4D FC 85 C9 74 11
00E2AC4Dh:  0F 28 06 0F 29 07 83 C6 10 83 C7 10 83 E9 01 75
00E2AC5Dh:  EF 8B 4D 08 85 C9 74 12 8B D1 C1 E9 02 51 C1 E1
00E2AC6Dh:  02 2B D1 59 F3 A5 8B CA F3 A4 5F 5E 8B E5 5D C3
00E2AC7Dh:  51 52 50 E8 4B 9A 00 00 83 C4 0C 5F 5E 8B E5 5D
Stack (0012F0F4h):
0012F0D4h:  F7820CDC 804E9120 F7820CE4 00E73005
0012F0E4h:  FF3C3DA0 80C23868 017AF000 C00039CC
0012F0F4h:  0000003C 00E4F7A0 00A063E0 00E73D40
0012F104h:  00000003 00A063E0 00E12B3A 0000000B
0012F114h:  00E2A9E9 00A063E0 004C2C47 00E4D16C
0012F124h:  0012F238 01C8705A 004123E9 00A063E0
0012F134h:  00A06760 00000000 003F2238 00000000
0012F144h:  7C9006F0 00000201 00000000 003F3D98
0012F154h:  003F0000 00010000 00000018 003F0000
0012F164h:  003F0000 0012EF60 00000000 0012F1F8
0012F174h:  7C8FEE18 000106F0 00000003 0012F0DC
0012F184h:  1000B8FB 0012F1C8 7C8FEE18 7C900570
0012F194h:  FFFFFFFF 7C90056D 1000B6B1 003F0000
0012F1A4h:  00000000 1000B6D0 00DA0000 00DD526C
0012F1B4h:  FDC99800 01C7E019 0012F204 0012F21C
0012F1C4h:  0012F1AC 22024200 01C8705A 0E0BB780
0012F1D4h:  22024200 01C8705A 10002A37 00000027
0012F1E4h:  0012F240 004D0F78 00A063E0 00000044
0012F1F4h:  00000044 0000003B 004D0F78 00A06760
0012F204h:  00000021 00000021 00000010 00E10000
Registers:
EAX: 00E73D40, EBX: 0000003B, ECX: 00000003, EDX: 00000003
ESI: 00A063E0, EDI: 00E73D40, EBP: 0012F108, ESP: 0012F0F4
Crash location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Loaded modules:
foobar2000   loaded at 00400000h - 0051E000h
ntdll loaded at 7C8F0000h - 7C99F000h
kernel32 loaded at 7C800000h - 7C8EF000h
COMCTL32 loaded at 773C0000h - 774C3000h
msvcrt   loaded at 77C00000h - 77C58000h
ADVAPI32 loaded at 77DC0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F02000h
Secur32   loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 7E360000h - 7E3F0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9B0000h - 7D1C7000h
ole32 loaded at 774D0000h - 7760D000h
shared   loaded at 10000000h - 1002A000h
COMDLG32 loaded at 76390000h - 763D9000h
foo_abx   loaded at 00A10000h - 00A43000h
foo_albumlist loaded at 00A70000h - 00AD5000h
foo_audioscrobbler   loaded at 00B00000h - 00B31000h
WS2_32   loaded at 71AA0000h - 71AB7000h
WS2HELP   loaded at 71A90000h - 71A98000h
foo_cdda loaded at 00B60000h - 00B95000h
foo_converter loaded at 00BC0000h - 00C25000h
foo_cwb_hooks loaded at 00C50000h - 00C9A000h
foo_dsp_std   loaded at 00CC0000h - 00D07000h
foo_fileops   loaded at 00D30000h - 00D77000h
OLEAUT32 loaded at 77110000h - 7719B000h
foo_freedb2   loaded at 00DA0000h - 00DE1000h
foo_input_mslive loaded at 00E10000h - 00E57000h
WMVCore   loaded at 15110000h - 1536A000h
WMASF loaded at 11C70000h - 11CAA000h
imagehlp loaded at 76C80000h - 76CA8000h
DBGHELP   loaded at 59CA0000h - 59D41000h
VERSION   loaded at 77BF0000h - 77BF8000h
Stack dump analysis:
Address: 00E4F7A0h, location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Address: 00E12B3Ah, location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Address: 00E2A9E9h, location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Address: 004C2C47h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00E4D16Ch, location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Address: 004123E9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C9006F0h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C8FEE18h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "strchr" (+00000117h)
Address: 1000B8FBh, location: "shared", loaded at 10000000h - 1002A000h
Address: 7C900570h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C90056Dh, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 1000B6B1h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000B6D0h, location: "shared", loaded at 10000000h - 1002A000h
Address: 00DA0000h, location: "foo_freedb2", loaded at 00DA0000h - 00DE1000h
Address: 00DD526Ch, location: "foo_freedb2", loaded at 00DA0000h - 00DE1000h
Address: 10002A37h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+00000396h)
Address: 004D0F78h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00E10000h, location: "foo_input_mslive", loaded at 00E10000h - 00E57000h
Address: 004B07D9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004120EBh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C9006EBh, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 00498E01h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0048A91Eh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0043F94Bh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004050E9h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00405103h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00405001h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00404F3Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00404EA7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004AE997h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004AE9ACh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00489D53h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004ED04Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004140B6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004126D7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C9005C8h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C900551h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C9040C0h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlDetermineDosPathNameType_U" (+00000721h)
Address: 7C9040BBh, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlDetermineDosPathNameType_U" (+0000071Ch)
Address: 7C900833h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 7C900838h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 7C8FE96Ch, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "NtUnmapViewOfSection" (+0000000Ch)
Address: 7C90A2ACh, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlPushFrame" (+000000CCh)
Address: 7C905DB4h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlValidateUnicodeString" (+00000142h)
Address: 7C96CE62h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Address: 7C96CE28h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Address: 7C900732h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C900738h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9006ABh, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7751E581h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoGetTreatAsClass" (+00001374h)
Address: 7E3694BEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E36B42Dh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7E36B3F9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 7E36B393h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 7E36B3A7h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E36B3B0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 7E390457h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E368816h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E36885Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000193h)
Address: 7E36882Ah, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000163h)
Address: 7E36F9FEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CallNextHookEx" (+000001A3h)
Address: 7E368830h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+00000169h)
Address: 7E36B4C0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E36B4CBh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 774D0000h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 7E36B4D0h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E36B50Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7E36B51Ch, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 7C8FEAE3h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E36B473h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E36FE13h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 7E36FDD9h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 774DD294h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 7E36FDFEh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "CreateWindowExW" (+000001D9h)
Address: 7C809382h, location: "kernel32", loaded at 7C800000h - 7C8EF000h
Symbol: "GetTickCount" (+000000E6h)
Address: 7C80E6D2h, location: "kernel32", loaded at 7C800000h - 7C8EF000h
Symbol: "GetModuleHandleW" (+00000295h)
Address: 77DC8FE8h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "MD4Final" (+00000556h)
Address: 77DC8AFAh, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "MD4Final" (+00000068h)
Address: 77E362C0h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Address: 77E362A0h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Address: 77DC8B27h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "MD4Final" (+00000095h)
Address: 77DC880Ah, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+0000028Ch)
Address: 77DC8867h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000002E9h)
Address: 7C90554Ah, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Address: 7C9053F5h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 774DC050h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 77DC8921h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000003A3h)
Address: 77DC892Ah, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000003ACh)
Address: 77DC8771h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000001F3h)
Address: 77DC877Fh, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+00000201h)
Address: 7C901538h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C901596h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "wcsncpy" (+00000B07h)
Address: 775F68E4h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 77DC8664h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000000E6h)
Address: 77DC8627h, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+000000A9h)
Address: 77DC85CFh, location: "ADVAPI32", loaded at 77DC0000h - 77E6B000h
Symbol: "SystemFunction036" (+00000051h)
Address: 77E7611Ch, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrTypeFlags" (+000003E4h)
Address: 77E76125h, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrTypeFlags" (+000003EDh)
Address: 77E760A8h, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrTypeFlags" (+00000370h)
Address: 775F6860h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 77E760B4h, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrTypeFlags" (+0000037Ch)
Address: 774EF344h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoInitializeEx" (+000003D9h)
Address: 775F68C0h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 774EF4C3h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoInitializeEx" (+00000558h)
Address: 774ED6BCh, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "IsValidInterface" (+00000293h)
Address: 774ED7DCh, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "IsValidInterface" (+000003B3h)
Address: 774ED20Ah, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoTaskMemAlloc" (+000001C2h)
Address: 774ED1D7h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoTaskMemAlloc" (+0000018Fh)
Address: 775F6868h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 774EF5E1h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoInitializeEx" (+00000676h)
Address: 774DC2B4h, location: "ole32", loaded at 774D0000h - 7760D000h
Address: 7751ED05h, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoGetTreatAsClass" (+00001AF8h)
Address: 004EA198h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 774EF05Bh, location: "ole32", loaded at 774D0000h - 7760D000h
Symbol: "CoInitializeEx" (+000000F0h)
Address: 004C5D60h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004125C5h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B161Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CAC7h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C8FE027h, location: "ntdll", loaded at 7C8F0000h - 7C99F000h
Symbol: "ZwQueryInformationProcess" (+0000000Ch)
Address: 1000263Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000CAh)
Address: 004C8224h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4766h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0042CEB6h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049BFFEh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993E1h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993DBh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004BAF9Ch, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B9620h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AFC0h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004993EFh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 004B4B73h, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 0049AD6Fh, location: "foobar2000", loaded at 00400000h - 0051E000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8EF000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8EF000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8EF000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049ADDAh, location: "foobar2000", loaded at 00400000h - 0051E000h
Version info:
foobar2000 v0.9.5
UNICODE
Windows 5.1
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: codeboxed.[/size]
Reply #262
I'm having trouble getting track info to display when playing a stream (ex. rtsp://live.cumulusstreaming.com/WXFX-FM).
All I end up with after the stream buffers in is -
mslive://|rtsp://live.cumulusstreaming.com/WXFX-FM|/
Reply #263
rtsp://live.cumulusstreaming.com/WXFX-FM works fine and out of the box here.
Are you using the latest version of the mslive plugin? Does "View - Console" tell anything?
EDIT: Ugh, I think your problem is only about displaying information. Well, I'll stay silent here, different task with streams...
Reply #264
Thank you for great plugin!
I have a question - I keep foobar opened for a long time (week, for example), and, for example, each day I start live radio through foo_input_mslive. If I start radio and then stop it, you can see in task manager that total quantity of threads of foobar is increased by 2. So, soon you can have more than 100 threads used by foobar. Is it bug of foo_input_mslive or ms?
Thank you.
Reply #265
Unable to open item for playback (cannot connect to any of the referenced urls):
"mslive://|http://www.centralstation.com.au/kissfm/stream.asx|live|/"
Installed Microsoft Visual C++ 2008 Redistributable Package (x86)
http://www.microsoft.com/downloads/details...;DisplayLang=en
but doesn't work =\
Reply #266
You need to install Windows Media or something else that contains WMVCORE.DLL
Reply #267
I have windows media 11.
I can't find libmmd.dll on Acropolis' blog, doesn't look like it's there anymore.
Don't know what is SSE but i have a Intel E4300
Reply #268
Latest version of foo_input_mslive 0.4.6 doesn't require 'libmmd.dll', so, just update your plugin:
http://acropolis.lokalen.org/wp-content/pl...wnload.php?id=6
Reply #269
Yea that's what i've installed though. Put it in the components directory and restarted foobar (9.4.3)
Reply #270
Looks like something wrong with URL: "mslive://|http://www.centralstation.com.au/kissfm/stream.asx|live|/"
I think that better ask author at his site.
Reply #271
Hi everybody! My first post here :)
First of all, many thanks for the plugin!
And unfortunately one more "Unable to open item..." msg :|
I'm trying to open "mslive://|http://akastreaming.yle.fi/vp/fiyle/no_geo/live_f.asx|/" but I keep getting "Unable to open item for playback (Could not connect to host)" error.
Running foo_input_mslive 0.4.6 on foobar2000 v0.9.5.3
Stream opens without problems when using WMP.
Reply #272
Maybe some firewalling/filtering problem on your side. The stream works here. OMG, nice finnish that I'm listening to now: "Pautarakalaaala snapsi mukalalaaaaa"  BTW the author has been banned from HA, you can ask in his blog
Reply #273
You were absolutely right! Works fine on my home pc, although can't understand why WMP was able to play it on my work pc also (and foobar wasn't). Anyway, my goal is to make that stream play on a pc running windows with no IE, WMP and OE installed... I may have a look at that soon.
Btw, YleX is very famous Finnish radiostation (but only in Finland I assume :P) I wonder which song you've been listening :D
Reply #274
You'll have a WMP dependency in any case. Why the effort, just have an up to date wmp, you'll need it anyway, coz streams often use the newest and fanciest unplayable windows media format. -->
No idea, listened to some hardrock, uninteresting for me.
