Topic: JScript Panel script discussion/help (Read 300377 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #1425
I removed all advanced queue management stuff in JSP3. It exists in JSP2 and SMP.
However, you can get queued items in a dirty way by using title formatting...
var tfo = fb.TitleFormat("[%queue_index%]");
function get_queued_items(playlistIndex) {
var items = plman.GetPlaylistItems(playlistIndex);
var queued_items = fb.CreateHandleList();
for (var i = 0; i < items.Count; i++) {
if (tfo.EvalPlaylistItem(playlistIndex, i).length) {
queued_items.AddItem(items.GetItem(i));
return queued_items;
var queued_items = get_queued_items(plman.ActivePlaylist);
As for playing a given item, use this...
https://jscript-panel.github.io/docs/namespaces/plman/#plmanexecuteplaylistdefaultactionplaylistindex-playlistitemindex
Reply #1426
Thx. That did the trick. Nice clean randomize button now. Leftclick randomizes, rightclick randomizes and starts playing first item.
		fb.RunMainMenuCommand("Playback/Flush playback queue");		// Flush queue in case foo_keep_queue is active
fb.RunMainMenuCommand("Edit/Selection/Sort/Randomize") // Randomize selection and display selection in new order
var FirstSelectedItem = _first_selected_item(plman.ActivePlaylist);
if ( FirstSelectedItem > -1 ) {
plman.ExecutePlaylistDefaultAction(plman.ActivePlaylist, FirstSelectedItem)
I keep my queue button rightclick code as is (it works) and start experimenting with the other piece of code you sent.
Reply #1427
I created a DSP Preset button which works fine.
How can I optimize the following
case arr[active].name == 'Upmix to 3.0 (FL FR C)' || arr[active].name == 'Upmix to 4.0 (FL FR BL BR)' || arr[active].name == 'Upmix to 5.0 (FL FR C BL BR)':
which works to something like
case arr[active].name[1,5] == 'Upmix':
which does not work.
What is the syntax for matching the first 5 characters of arr[active].name ?
On a similar note ... how can I check for a pattern in a string (for instance) '[exclusive]' ?
Reply #1430
How do I create a variable var global ?
By changing his value on panel A , it also changing on other panels ?
I need a function that include those variables inside a new .js file ?
Hope it's clear understanding. Thanks 😘
Reply #1431
Not really sure what you're asking??
You can obviously put variables in your own .js files and import them as documented here...
https://jscript-panel.github.io/docs/preprocessors/
If you want an updated variable in one panel sent to another, use window.NotifyOthers and on_notify_data callback.
https://jscript-panel.github.io/docs/namespaces/window/#windownotifyothersname-info
https://jscript-panel.github.io/docs/callbacks/component/#on_notify_dataname-info
Reply #1432
[/quote
Thanks you Marc . You are so reactive to us .
I made it work to change the background color from panel 1 and others panels with the function on notify like you said .
Now I need to change the background to the others layout as well.
Is it possible to send variable from layout to layout ?
Thanks 😘
jscript3 error maybe
Reply #1433
good evening i am using the latest jsript panel 3.3.33 on smooth browser when I add a folder with 100 turns in it adds 200
many thanks in advance
Re: jscript3 error maybe
Reply #1434
What? Did you mean to say tunes? Show an example screenshot and explain what you think is wrong with it.
Also. 3.3.33 is a long way from being the latest. Anyone using 3.3.30-3.3.39 really should update because there are some rendering bugs when panels are in tabs. 3.340 is the last release for Windows 7/8 users which fixes those bugs. The 3.4.x series requires at least Windows 8.1. The current version is 3.4.28.
Reply #1435
okay thank you mark all sorted  :)
