Topic: Impedance switch on a Class-D amp? (Read 1845 times) previous topic - next topic
Hi all. I recently bought one of the little Vox MV50 guitar amps. This uses the NuTube preamp tube, but is a class D amp. I don't understand why this thing would have an impedance switch on the back. I didn't think that mattered with a class-D amp. (Or any other solid-state amp, for that matter.) Is this just a marketing gimmick to help create the illusion that this is a "tube" amp? Or is this actually needed in this application?
Thanks all;
Artie
Re: Impedance switch on a Class-D amp?
It probably just caps the power so that you don't damage low impedance speakers.
Actually it can mather with class-D but that depends of the design, this is rare as most class-D are designed in a way that this don't happen, in the class-D the output speaker impedance can affect the response of the output filter an this switch can possibly tune the output filter to obtain allways the same response.
Yeah . . . I was thinking it was just a tone-shaping option. I suppose I could switch it while using the same speaker and hear what difference it might make. I'd do this, of course, at lower volumes.
