It would be great if someone were to further improve this setup. In particular, the "notify-send" command has an "-i" option which allows an image to be displayed in the notification balloon. It would be nice to have the correct album art displayed along with the track info...
Here you go:
#!/bin/bash
# Author : Anonymous
# Version : 1.0
# License : n/a
# Date : 2010 04/15
# Requires : foobar2000, foo_np_simple, notify-send
# Script Name : fb2000_notify.sh
# Description : Script to display Now Playing' info via 'foo_np_simple'
# component and 'notify-send'.
# Notes : n/a
# Acknowledge : thanks to original authors
# Resources : n/a
# -- User Constants - User can specify these variables as necessary -----------
# Location (full path) of 'foo_np_simple' file:
NPFILE='/home/user_name/.wine/drive_c/Program Files/Foobar2000/now_playing/np.txt'
# Directory where you will store cover art thumbnail image used by notify-send.
# Note: using the same directory where the 'foo_np_simple' file is kept might
# be a good place for the thunmail.
IMGDIR='/home/user_name/.wine/drive_c/Program Files/Foobar2000_02/now_playing'
# Full path to alternate image (if no cover art exists).
IMGALT='/home/user_name/.wine/drive_c/Program Files/Foobar2000_02/default.jpg'
# Specify replacement string for '&' character in message body. See function,
# 'f_fix_notify_bug', notes below.
AMPALT='And'
# Strings to add to image thumbnail file. For example, if original image file
# name 'cover' (excluding extension), then new file will become
# 'cover_thumbnail', assumimg default values are used.
SEP_NAME='_'
IMGFILE_XTRA_NAME='thumbnail'
# Size in pixels of thumbnail image used in 'notify-send' pop-up. This values
# is the height dimension and will automatically generate the width to maintain
# aspect ratio.
THUMB_SIZE=96
# User name for controlling xhost, etc.
NOTIFUNAME='user_name'
# Also see the 'f_convert_image' function to modify image boder, filter,
# unsharp mask, etc. Make a backup copy and play around.
# -- Other Constants - DO NOT CHANGE ------------------------------------------
# Separator between file name and extension
SEP_EXT='.'
# Path separator
SEP_PATH='/'
# Extension for thumbnail image. This must be 'png' as it supports
# transparency necessary for proper display of image in notify-send pop-up.
IMGFILE_CONVERT_EXT='png'
# -- Functions ----------------------------------------------------------------
function f_get_npinfo {
# Get 'Now Playing' info from user-specified file and set some variables
# required by the script. The variables are assigned values based on
# specific lines from the file:
# Line 1 - used for 'notify-send' message summary
# Line 2 to Line n-2 - used for 'notify-send' message body
# Line n-1 - used as the directory to search for 'Now Playing' cover art
count=0
while read -r line; do
line_array[$count]="$line\n"
let count=$count+1
done < "$NPFILE"
msg_line_summary=0
let msg_lines_body=${#line_array[@]}-2
let msg_line_dir=${#line_array[@]}-1
msg_summary=$(echo -e "${line_array[$msg_line_summary]}")
msg_body=$(echo -e "${line_array[@]:1:$msg_lines_body}")
cover_dir=$(echo -n "${line_array[$msg_line_dir]}")
function f_fix_notify_bug {
# Notify send fails to print the message body if it contains an ampersand
# (&). It is possible there are other characters that introduce odd
# behavior, but no others have been noted yet. Also, the same behavior did
# not seem to apply to the message summary.
# Remove '&'s from message body and replace with user-specified
# alternative.
msg_body=$(echo "$msg_body" | sed "s/&/${AMPALT}/g")
function f_get_image {
# Search directory of currently playing audio file for image file. Image
# file in this directory is assumed to be the cover art image. The image
# will be used to create the thumbnail for the 'notify-send' pop-up.
IFS=$''
cover_dir=$(echo $cover_dir | sed -e 's/[a-zA-Z]://' -e 's/\\n//g' -e 's/\\/\//g')
for item in "${cover_dir}/"*; do
if [ -f "$item" ]; then
mime=$(file -ib "$item")
result=$(echo $mime | grep 'image')
if [ $result ]; then
imgfile="$item"
break
else
imgfile="$IMGALT"
fi
fi
done;
unset IFS
function f_convert_image {
# Convert cover art:
# Step 1: create thumbnail
# Step 2: apply drop shadow
if [ -n "$imgfile" ]; then
# Resize image
convert -depth 24 \
-background transparent \
-thumbnail x${THUMB_SIZE} \
-quality 100 \
-bordercolor '#000000' \
-border 2x2 \
-filter Lanczos \
-unsharp 0x1.5+1+0 \
"$imgfile" \
"$imgfile_resized"
# Create drop shadow
convert "$imgfile_resized" \
\( +clone -background black -shadow 60x5+10+10 \) \
+swap \
-layers merge \
+repage \
"$imgfile_resized"
fi
function f_notify {
# Create the 'notify-send' pop-up.
# Set some vars
notifuname="$NOTIFUNAME"
namecheck=$(who | grep -E "\b${notifuname}\b")
#notificon="user-info"
notificon="$imgfile_resized"
# Set X display (needed when terminal app launches GUI app)
export DISPLAY=:0.0
# Test whether specified user is logged in
if [ -n "$namecheck" ]; then
# Test whether X is running
isx=$(xdpyinfo | head -20 | grep "X.Org")
# Test whether screen has been blanked by xscreensaver
if [ -n "$isx" ]; then
# Add user to xhost (will be removed before script exits)
# otherwise xscreensaver-command will not work properly.
# [url=http://www.leidinger.net/X/xhost.html]http://www.leidinger.net/X/xhost.html[/url]
xhost +nis:${notifuname}@ > /dev/null
is_scrblank=$(xscreensaver-command -time 2> /dev/null| grep "screen non-blanked")
# Above command issues an error message ('no saver status on
# root window.') if screensaver has not been invoked since daemon
# was started. Therefore, if error status (1), it means the screen
# is not blanked and notifier should be issued to desktop.
is_err=$?
# Debug
# echo $is_scrblank
# echo $is_err
if [ -n "$is_scrblank" ] || [ !"$is_err" ]; then
# Send desktop notification
notify-send \
--icon="$notificon" \
--expire-time=6000 \
--urgency=normal \
"${msg_summary}" "${msg_body}"
fi
fi
fi
# Remove user from xhost
xhost -nis:${notifuname}@ > /dev/null
# -- Main ---------------------------------------------------------------------
# Call functions and assign values to additional variables.
f_get_npinfo
f_fix_notify_bug
f_get_image
imgfile_base=$( basename "$imgfile" )
imgfile_base_noext="${imgfile_base%.*}"
imgfile_thumbnail="${imgfile_base_noext}${SEP_NAME}${IMGFILE_XTRA_NAME}${SEP_EXT}${IMGFILE_CONVERT_EXT}"
imgfile_resized="${IMGDIR}${SEP_PATH}${imgfile_thumbnail}"
f_convert_image
f_notify
exit
The above code has a section at the beginning (User Constants) that needs some attention before the script can be used. I don't ordinarily like putting user configuration in scripts, but this was quickly put together (relatively speaking). I definitely should have done it in Perl or Python.
Here is the foo_np_simple code I inserted in foobar2000:
$if(%isplaying%,
$if(%TITLE%,%TITLE%,%filename_ext%)
$char(10)
$char(10)
Artist: [%album artist%]
$char(10)
Album: [%album%]
$char(10)
Genre: [%genre%]
$char(10)
Sub-Genre: [%sub-genre%]
$char(10)
$char(10)
%codec% ● %bitrate%kbps ● %samplerate%Hz ● %channels%
$char(10)
$directory_path(%path%)
$char(10),)
Notice a couple of things:
1) the bash script is not part of the text that foo_np_simple sends to its file. The 'now playing' info and the script are kept separate. The script reads in the file data. As such, the incron table entry (I used my regular user account for the table rather than root) looks like this:
/some/path\ with\ spaces/now_playing.txt IN_CLOSE_WRITE fb2000_notify.sh
2) The notify-send message takes this form:
message summary
message body
The above example formatting text takes the same form but with one added piece of output: the directory where the currently playing audio file is located (it's assumed the cover art is in that directory).
So, a couple of things need to be considered if / when modifying the example I provided:
a. the first entry that creates output to the np_simple file needs to be your desired notify-send summary (conditional functions, etc. that don't produce output to the file don't count ... notice the actual first line of the formatting string is the conditional, %isplaying%). In the above example the first item that produces output (and which will be the notify-send summary) is:
($if(%TITLE%,%TITLE%,%filename_ext%)
The entry could be [%genre%] if you like, but I doubt many people would choose that. Bottom line, this entry will be BOLD and set apart above the message body in the notify-send message.
b. A really critical issue is that the last output item MUST be the directory where the album art is located ALWAYS followed by a blank line.
This is taken care of in the example above by the following:
$char(10)
The reason it is critical is that the directory is required to retrieve the related album art. You should not change this unless you recode the related portions of the script.
Anything that is placed between your desired summary entry and the directory entry (essentially, these items in between are the body of the notify-send message) can be whatever you like with spacing to suit you.
You might want to use my example formatting first to make sure things are working before you venture into modifications.
I think that's it for now.
PS
Unsharp mask on the thumbnail cover art image created by the script is not optimal ... it looks decent, but I wanted it to be visible initially to let you know it was there. Feel free to tweak the settings.
PSS
I don't have any real issues with pretty_pop, and the standard info balloons work for me on mousing-over the tray icon, so I really don't know if this is something I'll continue to use. Coding it was mostly an exercise to see how it could be done.
-- Screen-shot attached:
