Topic: How do I make output format bit rate choice? (Read 3068 times) previous topic - next topic
8, 16, 24, or 32 bit.
"using bit rate above your hardware capabilities will only degrade your performance".
My "sound device" in the second image above says "bits/pixel  ----  32"
Is that all I need to know?  Set at 32 then?
Is it completely system dependant?  Or does the the audio souce matter?  Music files on the harddrive?  Online radio broadcasts?
Erm, the first picture has no relevant information, and the second and third picture have Display and Video Codec selected.
24 will be fine, in any case.
You never choose output bitrate. You may be able to change the output bit depth and sample rate, but I see you are using Windows XP, so there aren't as many options. The things you can set will be in the Sound and Audio Devices control panel. There is a place where you can set sample rate conversion ('Best' is the one you want), and there may be some options specific to your soundcard, but probably there is nothing for you to set. What problem are you trying to solve?
Sorry for the poor pic quality.    Did not think it made any difference which item was selected for the screen capture.  Directly above the selected is the "Sound Device".  Next column reads "bits/pixel 32".
Sorry again.  I'm new to this.  I mangled the definition of terms and I do understand that can lead to confusion.  I meant bit depth.
I was just going through the Foobar setup screens and this appeared in the options.
I'm just trying to find information on which of these is appropriate for me.  Is there any more information about my system, OS, soundcard, etc?
Again, the bits/pixel are regarding the Display, which you highlighted, not the sound card. In any case, just look up the specifications of your audio device on the internet or in the manual. FWIW, any option above 8bit is indistinguishable from each other anyway, so just choose 16bit or greater.
Your Compaq Mini has HD Audio codec, those support 24-bit output. Selecting it gives you better output quality in theory if you use volume controls. If you always play at full volume there is no audible difference, as Kohlrabi mentioned.
Thank you all very much.  I was meanwhile, before Case's post, only able to find the following info on this audio codec, the "ATI High Definition Audio Codec".  Cannot seem to determine and exact model number, but all that I found associated with them mentions 24 bit.
And of course I'm sorry for being an idiot there and posting the video specs there earlier.
IDT Introduces Low Power High Definition Audio Codec Optimized for Superior PC Audio Experience
The IDT 92HD71B features 4 stereo channels, and is compatible with the Intel high definition (HD) audio interface. The audio device provides stereo 24-bit resolution with sample rates up to 192 kHz. The dual digital SPDIF outputs enable simple integration with multi-channel consumer entertainment equipment, including audio integration with system HDMI video. The codec incorporates IDT proprietary technology to achieve digital to audio conversion signal-to-noise ratio fidelity in excess of 100dB. It also includes extensive optimizations to minimize unwanted audio artifacts, such as "pops", during system power up.
Thanks again for the direction here.
