Hi All,
While implementing WMA I observed that in fft.c there is a macro definition as SPLIT_RADIX_FFT but when trying to define the macro and generating the test cases it is observed that the generated test cases are failing to meet conformance criteria mentioned by Microsoft. Is there any issue with code under SPLIT_RADIX_FFT? I am using the executable provided by MS to test the conformance.
Can anyone please help me out in resolving this issue, I am lagging behind in performance because of the fft module which is consuming 45% of overall MCPS in M0 and M1 profiles.Do we have anyother solution for it.
Regards,
Gopi
