Topic: CUETools DB (Read 223305 times) previous topic - next topic
Re: CUETools DB
Reply #300
Discs on Musicbrainz with HTOA have tracks listed incorrectly on the database page.
http://db.cue.tools/cd/936811
When using the "SaGa Frontier Original Soundtrack" Musicbrainz tracklist, "Theme of Coon" appears as track 1 but it should be "ムスペルニブル" instead.
This has come up before for a different CD but I'll need to search for the discussion.
The CD you referenced above is CD3
https://musicbrainz.org/release/ba1062ea-4f30-4faf-82a6-2cc20fdfa5d7
and MusicBrainz lists 21 track titles for the 20 track CD (hidden track + 20).
CTDB did retrieve and store all 21 titles from MusicBrainz
ioV0F7sbhrjXv4Qwy8K.fQPLUTs-
but returns the first 20 titles (for a 20 track CD). CTDB doesn't store track title + track number like you see on MusicBrainz. The number of tracks and positions are stored in the TOC.
korth
Re: CUETools DB
Reply #301
Right, I understand why it happens. I'm just wondering if it could be fixed on the CTDB side. The Musicbrainz API has the ability to identify pregap tracks so it should be able to filter those out on the tracklist the database shows. (ex. https://musicbrainz.org/ws/2/release/ba1062ea-4f30-4faf-82a6-2cc20fdfa5d7?fmt=json&inc=media+recordings The media entry for the last disc has a pregap entry with info about the pregap track separate from the rest of the tracks.)
Re: CUETools DB
Reply #305
Hi
After MuusicBrainz schema update of 2021-05-17, synchronization to MusicBrainz data seemed not working.
The release data input after that date doesn't appear on the metadata selection tab, even if MusicBrainz submit button can go to the matching disc on MusicBrainz page.
Could you check?
Re: CUETools DB
Reply #306
Hi all, first time poster here,
I was backing up my CD collection with EAC, have completed 30 or so cds. However, it stops during the (initial) lookup of my CD The Corrs "Talk on Corners". The CTDB lookup never ends so I can't start the backup process.
EAC - CTDB seems to work fine with all other lookups so far so is there something off about "The Corrs" entry in DB?
Re: CUETools DB
Reply #307
So you're referring to the metadata portion of the plugin (song titles, etc.) before the ripping process begins?
If you could use one of the other metadata plugins in EAC to rip the entire CD then post the TOCID from the CTDB portion of the  extraction log, I could look up the entries. My access is limited so I can't do a full search at this time.
Edit:
found http://db.cuetools.net/top.php?tocid=uBweppFVUz5wxaGtmAUHezr1h.0-
http://db.cuetools.net/lookup2.php?version=3&ctdb=1&metadata=extensive&fuzzy=1&toc=0:19292:38365:58097:77985:95555:112055:132975:149502:170140:188277:210765:228715:251385:269387:292572
korth
Re: CUETools DB
Reply #308
Could you check?
Forwarded and acknowledged
korth
Re: CUETools DB
Reply #309
Yes, the metadata and such lookup. After some feverish clicking I got past it with the first option, first image. So ripping went fine.
Today I tried again and for some reason it was no problem doing the same operation!?
I got three pressings suggested and one cover image suggestion.
Fine.
So I cleared the options in my EAC view.
Took another CD, look up was fine.
Re-tried the Corrs album and BOOM! Stuck again in a (seemingly) never ending loop of look up - with the "busy" bar fading at lower edge of window. Pressing the red "x" does nothing seemingly once it has gone down the rabbit hole - unless there is some 5 minute time out I have to wait?
Aaaanyway, I killed entire EAC program and just went on with my day. Next time I'll try re-inserting same disc angain and again until the metadata search passes.
Thanks for taking a look at it though.
