Topic: CUETools on GitHub. May we see a new compile soon? [split from topic CUETools DB] (Read 1159 times) previous topic - next topic - Topic derived from CUETools DB
I recently moved the CTDB website code from sourceforge to github - https://github.com/gchudov/db.cue.tools
And repaired discogs monthly snapshot import that was broken for a while.
I see you did the same for CUETools itself and lifted it to VS2017/NET4.7. May we see a new compile soon? I started to put it together myself im VS but still have tons of misses. I am a noob in getting all these dependencies together unfortunately.
Re: CUETools on GitHub. May we see a new compile soon? [split from topic CUETools DB]
I'll try. There were some breaking changes to settings format and such, so before i upload a new build i wanted to finish those at least and run some tests to see it all still works ;)
CUETools 2.1.6
Nice to hear that and thanks again for the many work you invest!
I have no idea if this helps with anything but i wanted to mention that CUETools.Flake.exe built in VS2017 takes a noticable speed hit against the 2.16 version i once compiled in SharpDevelop. I did never build 2.17 before so it may be a general thing.
