HydrogenAudio
Digital Audio/Video => General A/V => Topic started by: Digisurfer on 2005-09-05 05:43:50
Title: Lossless audio compression with VirtualDub?
Post by: Digisurfer on 2005-09-05 05:43:50
Hey all, quick question. I Just entered the world of video capture recently and am wondering if there are any lossless audio codecs that work with VirtualDub for capture. Thanks!
Post by: stephanV on 2005-09-05 06:54:46
Nope, PCM is your only choice.
Post by: Digisurfer on 2005-09-06 04:35:06
[a href="index.php?act=findpost&pid=325087"][{POST_SNAPBACK}][/a]
Thanks, figured as much. How about transcoding the PCM to (for example) Wavpack, and then replacing the PCM audio track in the video file with it? I know there are Directshow filters for the playback of Wavpack and FLAC (haven't checked the others) so playing the final file shouldn't be a problem.
Post by: stephanV on 2005-09-06 08:04:32
You can do that (FLAC, Wavpack or TTA) if you don't mind using Matroska. With AVI no such thing is possible.
Post by: Digisurfer on 2005-09-06 12:49:13
[a href="index.php?act=findpost&pid=325330"][{POST_SNAPBACK}][/a]
Great, thanks for the heads up. Learning as I go, hehe.
Post by: Digisurfer on 2005-09-07 09:50:12
One more quick question. If PCM is my only choice, why are there compression options, including MP3? I can even install the Directshow filters that come with LAME and use those in VirtualDub as well. Not trying to be a pain, only trying to understand. Thanks again!
Post by: stephanV on 2005-09-07 12:14:01
I meant to say: If you want to have lossless audio, PCM is your only choice.
Using MP3 is of course possible (watch out to not use ABR/VBR modes, as they wouldn't work in VirtualDub also), but that wouldn't be lossless.
Post by: isidro on 2012-10-14 20:29:08
From here: http://forum.videohelp.com/threads/343407-...l=1#post2188956 (http://forum.videohelp.com/threads/343407-FLAC-in-Virtualdub?p=2188956&viewfull=1#post2188956)
Now you can import it.
First remux the flac file to mkv (using mkvmerge) then import with the Matroska input plugin: http://forums.virtualdub.org/index.php?act...f=7&t=19488 (http://forums.virtualdub.org/index.php?act=ST&f=7&t=19488)
(and Use Audio Direct Stream Copy to generate AVI even if you can't hear it in vdub)
