Topic: lame: lowpass filter disabled for -V0 but enabled for -b 320 -- why? (Read 5914 times) previous topic - next topic
Does anyone know the reason behind disabling the lowpass filter with -V0 but enabling it with -b 320? I mean, if -V0 can handle the high frequencies, then why -b 320 cannot? Hydrogenaudio recommends either -V0 or -b 320 for maximum quality, and so far I thought the major difference between them is the size of the file...
My random guess is that the low pass was disabled in v0 to encourage the encoder to use a higher bit rate, but that is just a guess.
The major difference is that CBR is pointless to use in lossy encoding, for it defeats the main purpose of lossy encoding, and VBR isn't. If you are looking at very high bitrate solutions already, take a look at halb27's lame3100i encoder for improved VBR performance.
With current VBR sfb21 content (the stuff above 16 kHz) is encoded with lower accuracy compared to previous versions. I guess this allowed the Lame dev(s) to skip the lowpass altogether. It's a matter of taste what behavior to prefer, and it doesn't play a major role anyway.
lame3995o -Q1.7 --lowpass 17
Kohlrabi, saying that -b 320 is pointless and offering an improvement over -V0 in the same post is as confusing as removing the lowpass filter from one option an leaving it in another.
halb27, I guess what I'm trying to understand is what behavior Lame devs preferred. The inconsistency between the default settings leaves me a bit puzzled. What about lame3100i? Is the filter on or off by default?
With 3100i I use a lowpass for any -Vn+ setting by default.
I see... So the choice you made for 3100i default settings implies that you recommend to explicitly enable the filter with --lowpass if -V0 option is used, unless personal taste dictates otherwise.
Which, in itself, is just his personal taste.
My recommending -V0+ does not change the fact that CBR is pointless*.
*except with broken/old decoders or for very specific streaming situations where ABR does not work
