I'm trying to add FFmpeg as a convertor for audio in Foobar2000, using the following settings:
Encoder: C:\Program Files\ffmpeg\bin\ffmpeg.exe
Extension: m4a
Parameters: -i pipe:0 -y -c:a aac -b:a 128k "%d"
- Do not convert with multiple threads.
And it gives me this:
1 out of 1 tracks converted with major problems.
Source: "C:\Users\matthew\Documents\Writing6.wav"
An error occurred while writing to file (Invalid command-line parameters) : "C:\Users\matthew\Music\Writing6.m4a"
Conversion failed: Invalid command-line parameters
Is that error from Foobar2000 or FFmpeg? It's a valid path, why would it complain?
So I've also tried these arguments:
-i "%d" -y -c:a aac -b:a 128k "%d"
The conversion works outside Foobar2000:
C:\Users\matthew\Documents>ffmpeg -i writing6.wav -y -c:a aac -b:a 128k writing6.m4a
ffmpeg version N-86911-gb664d1f Copyright (c) 2000-2017 the FFmpeg developers
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, wav, from 'writing6.wav':
Metadata:
encoded_by : REAPER
date : 2018-04-09
creation_time : 13-52-07
time_reference : 0
Duration: 00:01:37.00, bitrate: 2116 kb/s
Stream #0:0: Audio: pcm_s24le ([1][0][0][0] / 0x0001), 44100 Hz, stereo, s32 (24 bit), 2116 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s24le (native) -> aac (native))
Press [q] to stop, [?] for help
Output #0, ipod, to 'writing6.m4a':
Metadata:
encoded_by : REAPER
date : 2018-04-09
time_reference : 0
encoder : Lavf57.76.100
Stream #0:0: Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp (24 bit), 128 kb/s
Metadata:
encoder : Lavc57.102.100 aac
size= 1544kB time=00:01:37.01 bitrate= 130.4kbits/s speed=34.8x
video:0kB audio:1527kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.120084%
[aac @ 00000000046876a0] Qavg: 1439.548
What's the right syntax for this to work?
