Topic: Test sample archives (Read 34145 times) previous topic - next topic
hello, i'm not sure if I should post it here, i have found a kind of killer sample.
not sure if this is something special.
fails at all settings up to q10 on both 1.14 and 1.15s
http://foobar2000.h12.ru/files/teh_sample.flac
stimulating the audio nerve directly
[a href="index.php?act=findpost&pid=266102"][{POST_SNAPBACK}][/a]
The link is broken...
strange. works for me. Maybe because hosting allows file to be downloaded only by russians? Try using a download manager.
edit: can someone for whom the link works please make a mirror for those for whom the link doesn't work?
Doesn't work for me too. Right click / save as works apparently, but the downloaded flac file is only 12 kb, and correspond to a html file.
EDIT: I suppose that the upload forum is an easy place to make this file available for the whole HA people
getting redirected to
http://register.h12.ru/request.shtml?http:...teh_sample.flac
same here
I suppose that the upload forum is an easy place to make this file available for the whole HA people smile.gif
Nothing but a Heartache - Since I found my Baby ;)
This synthetic sample causes problems for all codecs. MPC fails at --quality 10, Nero Reloaded's encoder fails at "Transcoding" too. Wavpack 4.1 lossy fails at -b250 but does well at -b300. Vorbis handles it the best, making it extremely hard to ABX at -q10, but it uses 215-221 kbps (aoTuV), whereas the other codecs allocate many less bits. yandexx, what program did you use to create it? It's a pure sine wave. It's no wonder it can't be encoded properly. BTW, when adding a quiet layer of (synthetic) strings and merging it with the drum beat, all codecs handle it well
BTW, if it's from a CD, tell us which one? a Sample CD? A Yamaha synthesizer samples CD? CoolEdit?
And if Warhol's a genius, what am I? A speck of lint on the ***** of an alien
You can find all my listening test samples here:
http://www.rjamorim.com/test/samples/
But please only download them if you'll really use them. That account is on a tight bandwidth quota.
This sample is just repeated kick sound from Fruity Loops.
Guruboolez, thanks for the hint! For all who are not able to download from given link, sample is now available in the Uploads forum.
just thought i would share something i found that could let you upload all the samples you want with no bandwitch or age limmit.
http://zshare.net  if you make a free acct u can upload multi files at once, and manage them easily
