Topic: foo_lastfm_radio (Read 345487 times) previous topic - next topic
foo_lastfm_radio
Reply #200
ty for the answer. I thought it was easy to do, because Popup plus do it automatically, but I didn't found something in Google. Then only wait, I can do that  , and ty again for do this plugin.
foo_lastfm_radio
Reply #201
Version 0.5.5 released with some small changes. See original post for details.
foo_lastfm_radio
Reply #202
0.5.5: New advanced preference: cache album art to a file.
great, thanks! :-)
something i noticed when opening a custom station:
when selecting Tags, it says: <enter comma separated tags>
Afaik, last.fm doesn't support multiple tags. At least it does not work with foo_lastfm_radio.
foo_lastfm_radio
Reply #203
Yes, that was one of the other changes. It now just says tag singular.
foo_lastfm_radio
Reply #204
Wow, this is fantastic. Just what I was looking for. Actually, better than I was looking for.  Thanks so much!
foo_lastfm_radio
Reply #205
I have a problem with cache to file:
it caches the cover of the last song in the playlist, not the cover of the playing song.
foo_lastfm_radio
Reply #206
It currently caches the file when an album art display requests the image, which is normally when the selection changes for the default UI. I guess that also means that if there is no album art display, it doesn't get cached. I'll change it to cache on playback (or selection if not playing) for the next version.
foo_lastfm_radio
Reply #207
What a great plugin! I never was into last.fm radio, as I couldn't see what the next song or songs were. Now that's a problem solved!
Great to discover some new music (and let foo_run open a certain website if I like it so I can download it directly).
Also last.fm says this on my profile page when using this:
Listening now using foobar2000 0.9 - Tuned to Psybient Radio
Thank you for creating it!
foo_lastfm_radio
Reply #208
i don't use any album art panel, i draw images in panel stack splitter.
For imagepath i use
$if($strcmp('FOO_LASTFM',$left(%path%,10)),
c:\lastfmcache.jpg,
$replace(%path%,%filename_ext%,folder.jpg)
Any idea for a workaround? How can i "request" the image?
foo_lastfm_radio
Reply #209
Does the imagepath accept http:// locations? I could provide the tracks' image URLs in tags easily.
foo_lastfm_radio
Reply #210
Please do so. I show album art in an external program (Serious Samurize). When this tag is there I can hopefully write it to a txtfile with foo_np_simple, and retrieve the path from there with samurize.
a little bug or flaw (not a biggie):
when working on other songs tag's in the properties screen (more specific, automatically fill values) this screen loses focus when there is a trackchange in a last.fm playlist.
foo_lastfm_radio
Reply #211
Quick update to version 0.5.6. There is now a new technical field "lastfm:imageURL".
Use $info(lastfm:imageurl) to retrieve it. Let me know if it helps!
I'll look at changing the caching behaviour another time.
foo_lastfm_radio
Reply #212
@Sardonic Wrath
$imageabs(left,top,width,height,%path%,artreader),...)
foo_lastfm_radio
Reply #213
@Sardonic Wrath
artreader is in ELplaylist, there is nothing like this in PPS, or is there?
thanks a lot for the quick fix release nausea, i am goning to try it out tomorrow!
foo_lastfm_radio
Reply #214
Sure, there is artreader in PSS too.
I use it for displaying all my embedded covers and it works great.
foo_lastfm_radio
Reply #215
New to this plugin. Looks like a great idea but everytime I try to use it foobar crashes.
I have entered the connection data in the preferences dialog and tested them. Close preferences dialog. I then select open your personal Lastfm radio from the main menu/file. There is a lot of disk activity and then I get the message 'Unhandled exception: Invalid path syntax' in a message box with an OK button. This is repeatable 100%.
Below is the contents of the failute text file;
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C91B1FAh
Access violation, operation: write, address: 00000010h
Call path:
entry=>user_interface::shutdown
Code bytes (7C91B1FAh):
7C91B1BAh:  0B 64 A1 18 00 00 00 0F B6 4D 0B 89 88 84 0F 00
7C91B1CAh:  00 38 1D C4 B0 97 7C 0F 85 0C 89 FF FF A0 E8 B1
7C91B1DAh:  97 7C F6 D8 57 1B C0 F7 D0 25 E0 B1 97 7C 8B F8
7C91B1EAh:  8B 46 10 3B C3 89 45 FC 0F 84 9E 00 00 00 8B 06
7C91B1FAh:  FF 40 10 8B 45 FC 83 E0 01 89 45 E8 8B 06 FF 40
7C91B20Ah:  14 F6 05 F0 02 FE 7F 01 0F 85 2E 69 02 00 39 5D
7C91B21Ah:  E8 57 53 0F 85 E8 84 01 00 FF 75 FC E8 05 2D FF
7C91B22Ah:  FF 3D 02 01 00 00 0F 84 9B 69 02 00 3B C3 0F 8C
Stack (0012AB30h):
0012AB10h:  B263C2BC 80566B96 B263C288 7FFDF700
0012AB20h:  BC6963F0 0012E640 7FFDF000 88EF3DA8
0012AB30h:  000C02AA 00C4D45C 0012C6C8 0012AB88
0012AB40h:  00000000 0017F770 0012C898 0012ABF0
0012AB50h:  7740A559 00000000 7740A559 0012AB94
0012AB60h:  7E4188D1 00774038 7740A559 0017F770
0012AB70h:  0012AB8C 7740761C 0017F770 030B04C0
0012AB80h:  0012D150 0017F770 0012ABB4 7E418734
0012AB90h:  00080306 00001132 00000000 00000000
0012ABA0h:  00000358 0012ABC4 7C901046 00C77634
0012ABB0h:  00C1E85C 00C77634 7E418BD9 7FFDF000
0012ABC0h:  00C77630 0012ABD4 00C1E82F FFFFFFFF
0012ABD0h:  0012ABF8 0012ABE4 00C1E7E5 FFFFFFFF
0012ABE0h:  0012ABF8 0012AC00 00C1FF87 00C77630
0012ABF0h:  FFFFFFFF 00C77630 00C42338 00C77630
0012AC00h:  0012C4CC 00C1B616 816C790D 00C4D45C
0012AC10h:  7E44048F 7E418830 FFFFFFFF 7E41882A
0012AC20h:  7E42A013 00000002 00C4D470 00080306
0012AC30h:  00001132 00000000 0012C898 00000000
0012AC40h:  00000000 0012C7F4 00C1D8D0 0012AC6C
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000358, EDX: 00C77644
ESI: 00C77634, EDI: 00000000, EBP: 0012ABA4, ESP: 0012AB30
Crash location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlpWaitForCriticalSection" (+0000005Bh)
Loaded modules:
foobar2000                      loaded at 00400000h - 0053B000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
MSCTF                            loaded at 74720000h - 7476C000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_dbsearch                    loaded at 00AB0000h - 00B20000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_quicktag                    loaded at 00B30000h - 00B64000h
foo_lyricsgrabber                loaded at 00B90000h - 00BE2000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_uie_explorer                loaded at 00C10000h - 00C5E000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_playcount                    loaded at 00C90000h - 00CBA000h
foo_dsp_continuator              loaded at 00CE0000h - 00CF8000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_trackpos                    loaded at 00D20000h - 00D3F000h
foo_uie_elplaylist              loaded at 00D60000h - 00DC9000h
gdiplus                          loaded at 4EC50000h - 4EDF6000h
foo_rgscan                      loaded at 00E00000h - 00E5B000h
foo_mouse_gesture                loaded at 00E80000h - 00EA9000h
foo_uie_tagger_mod              loaded at 00ED0000h - 00F0F000h
foo_misc_addons                  loaded at 00F30000h - 00F5A000h
foo_uie_playlists_dropdown      loaded at 00F80000h - 00FBC000h
foo_utils                        loaded at 00FE0000h - 01024000h
foo_converter                    loaded at 01050000h - 010BC000h
foo_dsp_delta                    loaded at 010E0000h - 010FF000h
foo_new_file_stamper_mod        loaded at 01120000h - 01149000h
foo_uie_albumart                loaded at 01170000h - 011AD000h
foo_masstag                      loaded at 011D0000h - 01213000h
foo_uie_lyrics_panel            loaded at 01240000h - 012A4000h
foo_uie_albumlist                loaded at 012D0000h - 0130D000h
foo_infobox                      loaded at 01330000h - 01370000h
foo_channel_mixer                loaded at 01390000h - 013CA000h
foo_uie_bookmarks                loaded at 013E0000h - 01441000h
foo_playlist_tree_mod            loaded at 01460000h - 014C7000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
libmzgc360_000                  loaded at 014F0000h - 01594000h
foo_masstag_addons              loaded at 015E0000h - 015FF000h
foo_trackfinder                  loaded at 01620000h - 01646000h
foo_ui_columns                  loaded at 01670000h - 017D6000h
foo_run                          loaded at 01800000h - 0182D000h
foo_uie_library_tree            loaded at 01850000h - 0189B000h
foo_uie_vis_peakmeter_spectrum  loaded at 018C0000h - 018FF000h
foo_dts                          loaded at 01920000h - 019FB000h
foo_freedb2                      loaded at 01A20000h - 01A61000h
foo_fileops                      loaded at 01A90000h - 01AD6000h
foo_abx                          loaded at 01B00000h - 01B31000h
foo_albumlist                    loaded at 01B60000h - 01BCB000h
foo_uie_trackinfo_mod            loaded at 01BF0000h - 01C46000h
foo_audioscrobbler              loaded at 01C60000h - 01C91000h
foo_cdda                        loaded at 01CC0000h - 01D00000h
foo_playlist_manager            loaded at 01D20000h - 01D64000h
foo_textdisplay                  loaded at 01D90000h - 01DCF000h
foo_uie_panel_splitter          loaded at 01DF0000h - 01E3F000h
foo_uie_quicksearch              loaded at 01E60000h - 01EA6000h
foo_rg_trn                      loaded at 01ED0000h - 01EEB000h
foo_unpack                      loaded at 01F10000h - 01F3E000h
foo_input_std                    loaded at 01F60000h - 020A0000h
foo_menu_addons                  loaded at 020C0000h - 020FC000h
foo_ui_std                      loaded at 02120000h - 021F4000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_uie_tabs                    loaded at 02220000h - 0224A000h
foo_texttools                    loaded at 02270000h - 022A3000h
foo_removeplayed                loaded at 022D0000h - 022E8000h
foo_dsp_std                      loaded at 02310000h - 02358000h
foo_dsp_fsurround                loaded at 02380000h - 023B1000h
libfftw3f-3                      loaded at 63740000h - 6380B000h
dciman32                        loaded at 73BC0000h - 73BC6000h
xpsp2res                        loaded at 10030000h - 102F5000h
netapi32                        loaded at 5B860000h - 5B8B5000h
appHelp                          loaded at 77B40000h - 77B62000h
ieframe                          loaded at 148D0000h - 15349000h
iertutil                        loaded at 5DCA0000h - 5DE85000h
urlmon                          loaded at 1A400000h - 1A52B000h
MSNLNamespaceMgr                loaded at 15680000h - 156CD000h
WININET                          loaded at 63000000h - 630E5000h
Normaliz                        loaded at 05AA0000h - 05AA9000h
SETUPAPI                        loaded at 77920000h - 77A13000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 00C4D45Ch, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 7740A559h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001E6A9h)
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7740761Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001B76Ch)
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7C901046h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlEnterCriticalSection" (+00000046h)
Address: 00C1E85Ch, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 00C1E82Fh, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 00C1E7E5h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 00C1FF87h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 00C42338h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 00C1B616h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 7E44048Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000163h)
Address: 7E42A013h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 00C4D470h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 00C1D8D0h, location: "foo_uie_explorer", loaded at 00C10000h - 00C5E000h
Address: 7E42A039h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CallWindowProcW" (+0000001Bh)
Address: 7C913273h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnlockHeap" (+00000020h)
Address: 7C91328Fh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlUnlockHeap" (+0000003Ch)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0171A440h, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 0174689Ah, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 0171A5D6h, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 755D912Ah, location: "msctfime", loaded at 755C0000h - 755EE000h
Symbol: "UIWndProc" (+00000000h)
Address: 755C142Ch, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000193h)
Address: 7E42927Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetParent" (+0000016Ch)
Address: 7E4292E3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendMessageW" (+00000049h)
Address: 7E46B8CDh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+000003C9h)
Address: 7E46C60Dh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+00001109h)
Address: 755DD55Bh, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755DD563h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755C44F5h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755D383Fh, location: "msctfime", loaded at 755C0000h - 755EE000h
Symbol: "CtfImeDispatchDefImeMessage" (+00000027h)
Address: 7E46C926h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+00001422h)
Address: 7E46C95Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+00001457h)
Address: 7E46C97Dh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+00001479h)
Address: 7E44B642h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DeregisterShellHookWindow" (+0000B382h)
Address: 7E428DD9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000000B9h)
Address: 7E471088h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E428DACh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000008Ch)
Address: 7E428D8Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 7E428D90h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000070h)
Address: 01743009h, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 01743020h, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 7C832F49h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "LocalUnlock" (+00000080h)
Address: 755C720Bh, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755C7219h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755C44A4h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 7C910202h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91017Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 7C910208h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 76399F76h, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "ImmUnlockIMC" (+00000031h)
Address: 755C7184h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755C4458h, location: "msctfime", loaded at 755C0000h - 755EE000h
Address: 755D42D9h, location: "msctfime", loaded at 755C0000h - 755EE000h
Symbol: "CtfImeDispatchDefImeMessage" (+00000AC1h)
Address: 00C9A7D9h, location: "foo_playcount", loaded at 00C90000h - 00CBA000h
Address: 00C9933Ch, location: "foo_playcount", loaded at 00C90000h - 00CBA000h
Address: 00CAE030h, location: "foo_playcount", loaded at 00C90000h - 00CBA000h
Address: 00C99231h, location: "foo_playcount", loaded at 00C90000h - 00CBA000h
Address: 763A3C0Ch, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "CtfImmIsTextFrameServiceDisabled" (+0000036Bh)
Address: 763A6020h, location: "IMM32", loaded at 76390000h - 763AD000h
Address: 763A3C1Ah, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "CtfImmIsTextFrameServiceDisabled" (+00000379h)
Address: 004AF3E1h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0041AC77h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0040B8E2h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00405194h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00415326h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00404DDAh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043D15Dh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004A4461h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004A44DFh, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0050458Ch, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 0043D123h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7E418B8Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+0000010Ch)
Address: 0043CC73h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00404C67h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7E429C1Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetKeyboardLayoutList" (+00000000h)
Address: 7472FB62h, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_DllDetachInOther" (+00000880h)
Address: 76399B35h, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "ImmUnlockClientImc" (+00000013h)
Address: 76392B56h, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "ImmSetActiveContext" (+00000178h)
Address: 7E46B90Eh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+0000040Ah)
Address: 7E46B916h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+00000412h)
Address: 7E46BDF2h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IMPSetIMEA" (+000008EEh)
Address: 7C80262Ah, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "WaitForSingleObjectEx" (+000000DAh)
Address: 7C802600h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "WaitForSingleObjectEx" (+000000B0h)
Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C802608h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "WaitForSingleObjectEx" (+000000B8h)
Address: 7C802542h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "WaitForSingleObject" (+00000012h)
Address: 7C90DA0Ch, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwReleaseMutant" (+0000000Ch)
Address: 7C8024C7h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ReleaseMutex" (+00000010h)
Address: 7475577Ah, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_RunInputCPL" (+0000469Bh)
Address: 74755F00h, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_GetThreadFlags" (+0000040Fh)
Address: 74755F08h, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_GetThreadFlags" (+00000417h)
Address: 7473F7EFh, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_CreateCicLoadMutex" (+00008804h)
Address: 7473F87Fh, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_CreateCicLoadMutex" (+00008894h)
Address: 74755D2Ah, location: "MSCTF", loaded at 74720000h - 7476C000h
Symbol: "TF_GetThreadFlags" (+00000239h)
Address: 7E4277B0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetMessageA" (+00000085h)
Address: 7E4277F7h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PostThreadMessageA" (+00000032h)
Address: 004AF2F9h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 004AF318h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004B1650h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 004DD990h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 016CEB5Eh, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 016CCBE0h, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 016CEB7Eh, location: "foo_ui_columns", loaded at 01670000h - 017D6000h
Address: 010000C0h, location: "foo_utils", loaded at 00FE0000h - 01024000h
Address: 004DEAF8h, location: "foobar2000", loaded at 00400000h - 0053B000h
Address: 00505140h, location: "foobar2000", loaded at 00400000h - 0053B000h
Version info:
foobar2000 v0.9.6.3 beta 2
UNICODE
Windows 5.1
Additional info:
Library Tree 0.1.1  (foo_uie_library_tree)
ReplayGain Scanner 2.0.8  (foo_rgscan)
Playback Statistics 2.1.7  (foo_playcount)
Peakmeter Spectrum Visualisation 0.2.0.0 beta  (foo_uie_vis_peakmeter_spectrum)
Run services 0.3.5  (foo_run)
ReplayGain override 0.1.2  (foo_rg_trn)
New file stamper 1.0.0 [Dec 21 2008 - 01:05:11]  (foo_new_file_stamper_mod)
ZIP/GZIP reader 1.0  (foo_unpack)
Lyrics Grabber 0.2.6.2 Beta  (foo_lyricsgrabber)
Default User Interface 0.9.5  (foo_ui_std)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
FreeSurround 0.3.5  (foo_dsp_fsurround)
ELPlaylist 0.6.4.2(beta)  (foo_uie_elplaylist)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Misc. Addons 0.1.4 (SSE)  (foo_misc_addons)
Converter 1.2  (foo_converter)
Panel Stack Splitter 0.3.6.2(alpha)  (foo_uie_panel_splitter)
Playlist Tree Mod Panel 3.0.6.1 [Jul 31 2008 - 00:00:57]  (foo_playlist_tree_mod)
Tagger Mod Panel Window 1.1.0.0 [Dec 16 2008 - 23:58:11]  (foo_uie_tagger_mod)
CD Audio Decoder 2.1.4  (foo_cdda)
Database Search 1.4  (foo_dbsearch)
Bookmarks 0.2.6  (foo_uie_bookmarks)
RAR reader 1.2  (foo_unpack)
Track Positioner 1.0  (foo_trackpos)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
freedb Tagger 0.6.1  (foo_freedb2)
Channel Mixer 0.9.6.5  (foo_channel_mixer)
mouse gesture host 0.4.1  (foo_mouse_gesture)
File Operations 2.1.1  (foo_fileops)
Columns UI 0.3.6.7  (foo_ui_columns)
Special file info box 2.0.4  (foo_infobox)
DTS decoder 0.1.4 (Intel SSE)  (foo_dts)
Masstagger Addons 0.3.5 (SSE)  (foo_masstag_addons)
Audioscrobbler 2.3.1  (foo_audioscrobbler)
Playlist Manager 1.0.2  (foo_playlist_manager)
Album List 4.3  (foo_albumlist)
Continuator 0.6.1  (foo_dsp_continuator)
Explorer Tree 1.04.7b  (foo_uie_explorer)
Masstagger 1.7.1  (foo_masstag)
Album list panel 0.3.3  (foo_uie_albumlist)
Text Tools 1.0.2  (foo_texttools)
Text Display UI Element 1.0 RC 3  (foo_textdisplay)
Noise Sharpening DSP 1.0.0  (foo_dsp_delta)
foobar2000 core 0.9.6.3 beta 2  (Core)
Track Finder 2.1.1 [Jun 16 2006 - 12:36:15]  (foo_trackfinder)
Playlist Tools 0.6.2 beta 6  (foo_utils)
Menu Addons 0.4.1 (SSE)  (foo_menu_addons)
Playlists Dropdown 0.7 beta 1  (foo_uie_playlists_dropdown)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Album Art Panel 0.2.7  (foo_uie_albumart)
Standard DSP Array 1.0  (foo_dsp_std)
Remove played Files 1.4.0  (foo_removeplayed)
ABX Comparator 1.3.3  (foo_abx)
Quick Tagger 1.0.1  (foo_quicktag)
foo_lastfm_radio
Reply #216
Works great. Was testing it wit 0.5.5 at first, wanted to file it didn't work, then I had that "Oops"-"ligthbulb above head"-moment and upgraded. Worked instantly. I spam it to foo_np_simple with:
$if($stricmp($left(%path%,3),FOO),$info(lastfm:imageurl),$replace(%_path%,%_filename_ext%,)folder.jpg)
Thank you for updating so fast!
foo_lastfm_radio
Reply #218
Since yesterday, the plugin will download a playlist, but when I try to play it, it skips through them quickly without actually playing any of the tracks. Tried uninstalling the entire program, reinstalling newest versions. Same issue. Anyone experienced this?
foo_lastfm_radio
Reply #219
I've just found that it's skipping through, although I think it was playing fine earlier today (?).  This was with v0.5.4, just upgraded to 0.5.6 but the same happens here.
Has Last.fm changed something?
foo_lastfm_radio
Reply #220
Looks like they may have. Banshee (a Linux player with similar last.fm radio support) is also not working.
The API this plugin uses was never officially documented or supported, so this was always a possibility. As the new Last.fm playlist API doesn't include links to the tracks in the playlists it returns, it may be RIP foo_lastfm_radio. Which is a shame...
But who knows, maybe it's temporary.
foo_lastfm_radio
Reply #221
Hi nausea
Many thanks for the reply. It worked
I didn't think to check out errors caused by other plugins.
Thanks again. I'll now start playing with your great plugin.
foo_lastfm_radio
Reply #223
firefm for firefox radio player still works. maybe this helps?
