Topic: converter in 0.9b is multithreaded! (Read 4151 times) previous topic - next topic
Until now I had only used the new converter in foobar2000 in single cpu machines, without multi-threading. Tonight, I just upgraded foobar2000 to 0.9b10 on my fast workstation, with hyperthreading, and started a big encoding job.
Imagine my surprise seeing 2 files being converted at once! First I thought I made a mistake and somehow managed to launched 2 instances. Stopped the process and restarted it carefully, and same again :-)
Task manager confirms there are 2 instances of the encoder running, one on each (virtual) CPU. This is great, especially since it works without any configuration required. Thanks.
[a href="index.php?act=findpost&pid=333790"][{POST_SNAPBACK}][/a]
cool
on a pentium 4 D
Pity that HyperThreading isn't as hot as Intel would like everyone to think it is.
Yah, running two encoding processes on the same P4 HT results in about 10% performance boost, whereas the same thing on Athlon64 X2 results in near 100% performance boost. So I guess that would make a P4 D about 100% over a single process. Maybe. I don't know. The known P4 HT results were also more likely to be concurrent ReplayGain processes, rather than encoding.
Would anyone care to benchmark the concurrent processing, using various source/target formats? ( MP3, MusePack, 099 Verbis, FLAC, WavPack, whatever floats your boat )
Just a very quick test using an old P4 3 Ghz with HT, don't have time for more:
Converting mp3 to mp3 (yeah, I know, this is stupid...): 15 sec, so this makes 30 sec for two mp3s
Converting 2 identical mp3s at the same time using HT: 24 sec
