Topic: How to fix a problem with playing old MPC or MPEGPlus files? (Read 1302 times) previous topic - next topic
I have old files in MPC format, converted by unknown means, but except in the AVSMediaPlayer I could not playing them anywhere else.
MediaInfo gives a contradictory picture, although it correctly determines the length of the track and that it is Musepack SV7, but every time it gets confused with the version of the writing library - then 2.51 alpha, then 1.12 beta, then 1.64, etc.
I would like to know how else to open this file and what kind of subformat is this?
Re: How to fix a problem with playing old MPC or MPEGPlus files?
As I understand it, the whole problem lies in the experimental codec that is part of the Helix RMbin. Therefore, it was necessary to ask more simply - what is the MREGPlus version there?
Seems to be SV 7.15.   I think this was an experimental version pre-sv8 that should not have been used .
I dug a little deeper:
https://hydrogenaud.io/musepack/klemm/www.personal.uni-jena.de/~pfk/mpp/index2.html#test-encoder-binaries
"These are versions absolute unusable for archiving!
File format can be changed from one hour to another!
Files can't be decoded in the future!
Some changes are done:
  - different bitstream! (marked as Version 7.15)"
Thanks, it's a great find, of course! But the probability that something suitable will be found among a bunch of old binaries is not great!
Besides, there is a ready-made solution - this is FreeAudioEditor2017, which opens MPC SV7.15 files for editing without problems!
There is an utility - mpc2sv8 - included with the musepack linux packages.
Does it handle such files?
~> mpc2sv8
mpc2sv8 - Musepack (MPC) sv7 to sv8 converter v1.0.0 (C) 2007-2009 MDT
Built Jan 25 2024 00:00:00
Usage:
mpc2sv8 <infile.mpc> <outfile.mpc>
or
mpc2sv8 <infile_1.mpc> [ <infile_2.mpc> ... <infile_n.mpc> ] <outdir>
Aah I see, no it can't,
at least not without errors
"An error occured while decoding, this file may be corrupted"
The resulting file is recognized as SV8 by mediainfo, but I haven't tried playing it
anyway, here's the result of running
mpc2sv8 Sound.mpc o.mpc
No, the mpc2sv8 utility will not help in this case, as all other available binaries did not help either.
I would also like to dig into the NCTAudioCompress3 library, what is indicated there about "MP Plus SV-8", but I think it's useless.
In short, if anyone has such non-standard MusePack files, distill them using the FreeAudioEditor into a format convenient for you, and do not bother!
