Topic: auCDtectTaskManager multiple files (Read 4529 times) previous topic - next topic
Hy !
I integrated auCDtectTaskManager in Foobar from y-soft.org but instead of:
"$if(%__referenced_file%,$directory_path(%path%)\%__referenced_file%,%path%)"
I need some command line  for open all files from foobar playlist, not only one file.
Thank's in advance .
hello together
I have the same question. Does anyone have a solution? many thanks!
Does anyone have a suggestion? I've tried a few things, e.g. % __ referenced_folder% or % __ referenced_directory% but it does not work.
thx
Re: auCDtectTaskManager multiple files
Hy!
No suggestion for so long? No one uses auCDtectTaskManager ? :(
i use fooCDtect
works great with multiple files, uses multiple cores, shows results in a nice window.
You just have to install it and create the correct converter settings
instructions, program and sources in the archive
i use fooCDtect
I use auCDtect because I want to view the Spectrogam not only Conclusion of CDDA fidelity !
Unfortunately fooCDtect can't do that  :o
