Topic: Shuffle tracks of album A, then shuffle tracks of album B, etc. (Read 2892 times) previous topic - next topic
Hello !
I love Foobar, but there's one thing I can't figure how to do :
I have a playlist with all 10 albums. I would like to listen to all tracks of album 1 played in a shuffled order, then to all tracks of another album (choosen randomly, let's say album 6) in a shuffled order, etc.
Some players (like Poweramp) offer that option, but Foobar is so much better on other sides that I don't considering switching. Is there a way to do this in Foobar ?
Thank you very much !
Rémi
Re: Shuffle tracks of album A, then shuffle tracks of album B, etc.
You can change your playlist:
1) Edit -> Sort -> Randomize
2) Edit -> Sort -> Sort by... -> type %album% and press Enter
Hi lvqcl,
This helps, but it's not exactly what I'm asking :)
I've done what you've written and it absolutely makes it for once. But my question is : is there a way to automatize this, so that whenever I listen to a playlist, with the "Shuffle (albums)" options, it plays all albums with each album getting its tracks shuffled ?
Your solution implies that I do this every time I want to listen to a playlist, and do it again if I don't want the tracks the same order as the last time.
I know I'm picky. I guess you're picky when you love music :)
Hello,
No one can help on this ?
Thanks,
Rémi
What you want isn't possible as far as I know, that's why lvqcl gave you the closest approximation.
Hello,
Thanks,
Rémi
Well.
I try to help you but it takes some time how to figure out this request.
You can do this only if you
1.Create 10 playlists (one album for playlist)
2. Configure:
A. foo uie exlorer(fast creates playlists)  - https://hydrogenaud.io/index.php/topic,34207.0.html
B. foo scheduler(jumping to nex playlist when all track are played in album A) - https://www.foobar2000.org/components/view/foo_scheduler
C. foo removeplayed (remove played tracks)  - https://hydrogenaud.io/index.php/topic,50312.0.html
or foo playlist attributes (remove played tracks) - https://hydrogenaud.io/index.php/topic,73783.0.html
