Topic: Create .fpl file (Read 2180 times) previous topic - next topic
Create .fpl file
Hello everyone, after much searching on the forum could not understand how to run or how to run the .fpl extension file allocated in the folder-playlists v1.3
I'm a developer in PHP and need to dynamically create the file with extension .fpl but not all that I am creating this working.
I realized that when I create manually change some things example:
  7YÛDMVN € 4aR * º ‰ |¹1K² / ƒ% vDÉË76 L ·? ? ? öAYù <ENC ??> g ‡ ... OIO
ÿÿÿÿÿÿÿÿ¾7üžÂùÑ? Za Za € ¿¿€? ? ?
        T? Z? `? d d s "™ ¢ ¤ ª ® · Ë ½
Can anyone help me in the dynamic creation of this file?
Re: Create .fpl file
The FPL playlist format was designed not to be human-readable or editable. Its a completely closed format.
May I ask what kind of service you're trying to implement here for which the common interchange playlist formats like m3u8 are not suitable?
As mudlord alludes to, the FPL format is binary, slightly protected and not intended for external consumption and may change at any time in any way the author desires.
Stay sane, exile.
Hum, ok. Thanks for listening
m3u work, however I can not set up for the open player already playing it. There is this possibility?
I'm using this way to change radio stations, each station (rock, blues) has its separate m3u.
