Topic: Updater not working on Windows 7 (Read 290 times) previous topic - next topic
Hello. The following options under the “Help” menu seem to not work on the Windows 7 system:
  • Check for new foobar2000 versions (shows the “Update check failure: The function requested is not supported” error message when checking for the update)
  • Check for updated components (“Could not check for updates: The function requested is not supported” error)
  • Online troubleshooter (“Online troubleshooter failure: The function requested is not supported” error)
They work fine on Windows 10 VM.
Re: Updater not working on Windows 7
Thanks, that's worked.
Still, it would be nice if the program would specify what the exact problem is, other than The function requested is not supported – to point you in the right direction.
