Topic: Can't change the font size of one particular line. (Read 264 times) previous topic - next topic
I'm using Columns UI and I need the fonts of my playlist a little larger. Changing them in Prefs/Columns UI/Colors and Fonts will do the trick EXCEPT it will not change the Grouping title formatting script.
So for example, Michael Jackson - Thriller - 1983  does not change with the rest of the playlist. It's always small.
Re: Can't change the font size of one particular line.
I can't change the font type, either. It always stays the same.
Thanks for the reply. No, I don't have that installed.
BTW, I just tried it on Tedgo's Darkone and font change does the same thing...nothing. (For title formatting script)
AH! I see. I did not know I could select different fonts for each element, like that. Thanks very much!
