Topic: library tree - sorting questions (Read 634 times) previous topic - next topic
Hello
I've got few issues regarding sorting library tree
1. https://imgur.com/a/VUCBLmb - Is there any possible way to reverse the order of the stars?
2. Can I change the default alphabetical sorting to something else? To be more precise: lets take regular "View by genre" - Can i switch the order of genres from alphabetical to sorting by quantinty of artist/albums that belongs to particular genres, from biggest number in descending order
Re: library tree - sorting questions
As I recall you can do force-sorting in library tree by inserting zero-width space characters (or any other custom character) via titleformatting (bit of a hack).
Sorting by number of items - probably not doable with library tree.
If you want additional features you should look into foo_facets plugin (you can sort by number of items, among a bunch of other features you may or may not like).
Or maybe the library tree scripts based on JScript / Spider monkey panel plugin might have a sorting option. Did not check.
Thanks for suggestion, i'm done with 1st point with help of multiple layered $ifequal
