Topic: foo_enhanced_playcount - Record all song plays and Last.fm scrobbles (Read 64510 times) previous topic - next topic
Re: foo_enhanced_playcount - Record all song plays and Last.fm scrobbles
Reply #350
I figured there had to be a way and I was simply mishandling things. Thank you for that, this works great!
I had hoped to propagate %added_enhanced% & %first_played_enhanced% to <ADDED_TIMESTAMP> & <FIRST_PLAYED_TIMESTAMP> similarly, but unfortunately it doesn't look like it's possible to fetch those values as timestamps that Playback Stats understands, and I have no idea if it's possible to take the dates returned by those fields and reformat them to timestamps some other way.
Instead, I'm trialling a new <ADDED> field. Upon reflection, it probably isn't too important for Playback Stats to reimport these dates once they're in a tag, as they are not going to be routinely modified. It's the other fields that are modified on every play of a song that represent far too much administration to bother synchronising manually. :P I guess I will cut my losses with those and hope I never lose them from the db.
Thanks once again for this component. I'm cautiously aware that Last FM may not be around for forever, what with the trend towards Spotify/streaming services, so definitely feel it's important to do this legwork pulling my data sooner rather than later.
Reply #351
I understand that this component works with the official statistics plugin.
Is there a way to import the scrobbled playcount to the official statistics plugin's data?
