Topic: Can't set CUETools 2.2.0+ as default app for cue files (Read 414 times) previous topic - next topic
I am using Windows 7 with CUETools 2.1.9 and recently i noticed that there were new updates available but any version from 2.2.0 onwards doesn't let me set .cue extensions to open with CueTools by default. Even tried using windows built in app via the control panel -> default programs -> associate a file type or protocol with a program, and that doesn't work either. The CUETools app only shows up with 2.1.9. What can i do to fix it since this is the only thing holding me back from using the latest version.
Re: Can't set CUETools 2.2.0+ as default app for cue files
Please check the following registry settings:
HKEY_CLASSES_ROOT\Applications\CUETools.exe\shell\open\command
HKEY_CLASSES_ROOT\cue_auto_file\shell\open\command
HKEY_CURRENT_USER\SOFTWARE\Classes\Applications\CUETools.exe\shell\open\command
HKEY_CURRENT_USER\SOFTWARE\Classes\cue_auto_file\shell\open\command
They probably still contain the initially assigned 2.1.9, e.g:
Value name: (Default)
Value data: "C:\foo\CUETools_2.1.9\CUETools.exe" "%1"
Thanks heaps c72578 !!. That did the trick.
