foo_playlist_attributes
Reply #98 –
At the moment I am using foo_playlist_attributes 0.2.2 [Nov 16 2009 - 20:33:31] with fb2k 0.9.6.9 on Windows XP Professional. Might I ask two questions:
1.
Are all plugin settings saved entirely in foobar's config file so that for example all playlist restrictions set by foo_playlist_attributes are removed from them when I delete the plugin and I tell foobar when it runs next time that the settings shall not be kept?
2.
Is it an intended behaviour that foo_playlist_attributes bookmarks even files which have been played completely? Steps to reproduce what I am meaning:- I am saving first-time foo_playlist_attributes in foobar's components folder.
- I run foobar, go to menu Playback, Playlist attributes -> Bookmark last playback position.
- I am playing an arbitrary audio track entirely. foobar's playback settings are: "Stop after current" and "Repeat (track)".
- Restarting the playback of the same file by pressing enter or the corresponding button foobar jumps nearly until the track's end and plays only approximately its last second.
If I should have misunderstood how this option is functioning I beg your pardon.
