Topic: Use the SDK implement a componet,which can fix the output Device (Read 4918 times) previous topic - next topic
There are a lot of devices Install in my PCs ,I wanna fix the Output Device with a implement of the Componet.
when I copy the foobar2000 folder from one to another PC I have to configure the Device like under graph:
https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_128677_bd7055ff55925031a4cafa5bdf29d5fc;topic=0
Re: Use the SDK implement a componet,which can fix the output Device
I have research the SDK code and basic componet for a whole day ,but seems the part function is  implemented by the foobar2000.exe by Peter Pawlowski.
https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_128677_6365678f5c01fe2117f7ef3573fded8a;topic=116867
If I really wanna hack it,what should I do,anyone can give me some advice?
You never need to touch the output device setting if you stick to the default DirectSound output device.
Actually I need to use the foobar to play a net stream,and point the output PCM data to a Virtual Sound Line cable,but there are a lot of Virtual Cable Line in the Windows system. Every time I deploy the foobar2000 to a PC enviroment I need to config it. It is an annoy thing .and when the machine shudown suddenly,then the foobar config files crashed, the foobar2000.exe will not start and autoplay. I must reconfig it. those things drive me crazy,but I love foobar.
Have you tried with VB-Audio's Voicemeeter BANANA as VAC (see the connectivity charts there on site and documentation)?
It is so alike the Virtual Audio Cable,I think I find a way to solve the problem.Thanks for your replies.
