Topic: windows installer error (Read 1493 times) previous topic - next topic
I installed FB2k version 0.9.4.3 today and encountered an annoying error.  When trying to change from the default install location
  • [/size], the "Browse for Folder" dialog appears.  Then if I click on any directory the error dialog will immediately appear titled There is no disk in the drive.  Please insert a disk in drive \device\harddisk1\DR2.  (Yes, drive C: does exists.)  I then have to click on Cancel.  Navigating to another branch, either by clicking or using the arrows produces the same error.  Once I got through all the clicking and placed fb2k where I wanted, it installed and runs fine. (I also got this when starting to install the previous 0.9.4.2 version before I downloaded the newer one.)
    I suppose this needs to be entered as a bug, but I don't know where to do that.
    I tried searching this site, but couldn't find any reference to this.  Also, I tried to search for a string as in "there is no disk in the drive", but this apparently does not work. The site reports:
    The error returned was:
    One or all of your search keywords were below 3 characters or you searched for words which are not allowed
    I tried many other phrases.  The quotes are being ignored.  Am I doing it wrong?
    winXP Home
    1G RAM
    * - I don't install anything in "Program Files"
The installer has a lot of checking stuff, I'm not surprised.
An example, which happened to me once. It will check if you have an old foobar2000 0.8, if you do, it will tell you to choose another folder, good, then I choose a folder with foobar2000 0.9 and installing over. Bad news, it will delete everything in that folder, no questions asked. It still think you placeed it in a folder with 0.8, which it shouldn't, cause it only warned you when you selected the 0.8 folder and not on the 0.9 one.
Long story short, I had to download all components again.
Now I don't trust it anymore and just unzip it with 7-Zip.
The installer should really need a seriuosly recode. Maybe it has, never tried it again.
