Topic: Windows Explorer "Enqueue in Foobar" weird issue (Read 2623 times) previous topic - next topic
So this is the setup:
I have a folder of mp3's, and i got to select them all to "enqueue into foobar".  After i select them all, the only options are for windows media player.  However when I only select 15 or less mp3's i can use the foobar option.  As i select the 16th mp3, i can see the "Play All" toolbar change from foobar to windows media player.  Really weird issue, i dont know if it is windows explorer, foobar, or windows media player.
I would like to use foobar for all my music.
With 15 Selected:
With 16 Selected:
As you can see, when the 16th one is selected the toolbar changes and so does the right click menu.
Notice the Top Toolbar change from foobar to media player, and also the right click menu.
Anyone know a fix for this?
First no such issue here. So try go in Preferences -> File Types unselect Directory Context Menus check box apply then select it again apply.
I tried that, and it didnt work.
Thanks for the input though, got anything else that could possibly work?
If you don't use WMP, you could try removing access to it via
Control Panel >Add/Remove Programs > Set Program Access and Defaults -> Custom -> Uncheck "access to Media Player
elevatorladylevitateme
