Topic: foobar2000 v0.9.5.2 beta (Read 24170 times) previous topic - next topic
Visualisations look sweet.
Looking forward to see more native DUI elements. Sadly a track-info element doesn't seem to be on the to-do list...
... with two bug fixes ...
Any infos about what has been fixed? Does foo_fileops now "see" empty flash-drives?
( http://www.hydrogenaudio.org/forums/index....st&p=548050 )
beta1 + beta2: Spectrum showing 160 bands in full screen mode the visualization is strangely stretched vertically so that the bottom axis with the frequencies is beyond the screens edge and thus invisible.
(...) the bottom axis with the frequencies is beyond the screens edge and thus invisible.
It is not displayed because there is not enough horizontal space for all frequency numbers.
This happens for any number of bands if the width of the element is small enough.
So lowering the screen resolution would give the same effect for less bands?
Maybe you could just ommit every n-th frequency number in such cases?
I noticed a WMA Pro file in Beta 1 that showed up as "WMA 9" under properties.  Perhaps this could be changed to "WMA Pro 9"?  It caused me no end of trouble debugging the rockbox WMA Std decoder looking to figure out why it wouldn't play the file properly.
Finally, finally, FINALLY an oscilloscope! Thank you!
Reply #32
no problems with the beta so far! it's greaaattt
I must admit that following suggestion is very pedantic, however: when bottom axis dissappears because of too much bands the display of "-60db" is cutted - could it be hidden completetly?
And a request for spectrum visualization: bars mode and maybe custom colors like in spectrogram.
Reply #34
foobar2000 v0.9.5.2 beta has been released.
  • Ability to auto-resize playlist columns to match playlist view size.
    Right-click on the column headers and enable the option in the "Columns" submenu.
does foobar remember the playlist that has been auto-resized ? if i switch to a different playlist or facet selection does that have the same width etc as the auto sized playlist?
q: is there a way to do thinner lines between framed windows?
i'd like to see this as well
Reply #37
Context sub-menus get "swooshed" away in the oscilloscope visual.
Reply #39
Yea, as of now it just looks poor:
Reply #40
@Redoubts: Wrong visualization. I meant the descriptions for the bands in "spectrum". But yeah the 16384 point FFT looks odd in linear scaling, but much better than 8192 in logarithmic scaling.
Reply #41
do the new visualisations work in ther UI than DUI ?
Reply #42
You can access them from the menu. UI independent.
Reply #43
Quite, although there is currently a nicer plugin for foobar, if you can't wait.
Reply #45
I recently noticed that last beta takes much more time to write tags, but ONLY if tagging files (FLAC), which were added to the database.
Example:
My database is on path: D:\Music\Song.flac
(this path is specified in Media Library Music Folders: D:\Music)
- Writing tags to the file Song.flac OUTSIDE this directory (D:\Song.flac) is immediate and without any delay.
- Writing tags to the same file Song.flac INSIDE this Media Library folder takes much more time (sometimes about 10 seconds, but sometimes even more).
I can't remember that I experienced such behavior with previous versions.
My database is broad, but it is all the time the same.
Anyone have the same problem or am I missing something?
Thanks for the response!
Is there a difference between yes and no?
Reply #46
that's cool, what about if i wanted to use oscilloscope instead of spectrum analyser in my layout ?
Reply #47
No, Squeller was ambiguous.
You can't integrate them into a columnsUI or panelsUI layout, they can only be integrated into the DUI.
You can however look at them in their own window, UI independent.
elevatorladylevitateme
Reply #48
Do you use autoplaylists, Facets, album list or similar components that display the media library contents in one way or another and update automatically?
Reply #49
Yes, I use facets and album list. But I used them with previous versions too.
And new observation (but I think it refers to the same problem): using "remove dead entries" command from right click drop-down list in Facets have significant delay too.
