Topic: My PC's Sound Card Driver Got Missing (Read 435 times) previous topic - next topic
Hello everyone. I am facing this strange issue since yesterday evening. All of a sudden, my PC sound card driver got missing. Can anyone tell me what could be the issue behind it? Kindly help me to solve the issue.
Re: My PC's Sound Card Driver Got Missing
Microsoft had patch Tuesday happen yesterday.
"Life's the same, I'm moving in stereo
Life's the same except for my shoes"
I did not understand what you were trying to say. Is there a chance that the issue could be resolved if I follow the solution number 6 from here, which is to perform a System Restore? Kindly tell me.
You can try a System Restore.   :)
How do you know the driver is missing?    Have you tried re-installing it?   It should still exist on your hard drive and as long as the Windows update doesn't make it incompatible it should still work.   Or, you can probably download a new driver from the soundcard/motherboard/PC manufacturer.
If you are not sure that's the problem, it might be a security update...   Microsoft sometimes tries to keep people from hacking-in and listening to your microphone. In that case you'll just have to find the microphone security setting.
If you don't want to do a System Restore.
You could use CPU-Z to find out motherboard you have, lookup your motherboard on the internet, than download the latest audio drivers from motherboard manufacturer, that's if you are using the on-board audio.
Do a clean install.
First, let us do the simple things.
* Press the Windows logo key and type "device manager".
* Start that thing. If it prompts you for password, type password.
* Look under Sound, video and game controllers - or whatever it is called nowadays. Does it show up? Is there some yellow warning sign or anything?
* If it isn't there: right-click and "Scan for hardware changes" will try to find it.
Last two months' worth of foobar2000.org ad revenue has been donated to support war refugees from Ukraine: https://www.foobar2000.org/
