Topic: My components (Read 35350 times) previous topic - next topic
Re: My components
Reply #50
I think you can if you use the decoding panel, though. I keep Highly Experimental disabled and only enable it for sets that are rejected by AOPSF, such as Final Fantasy 10.
Re: My components
Reply #51
AOPSF also plays the Kingdom Hearts II set very badly. It also doesn't play the Silent Hill 2 set at all.
Re: My components
Reply #52
I see you have removed your components from official repo and your website. I hope it was not serious matter.
Re: My components
Reply #53
I wonder why?! I hope everything is ok with Kode54 and Peter...
Re: My components
Reply #54
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA512
Jesus christ, I take one little break over some private issues, and everyone starts thinking that one of my friends drove me to suicide.
No. This is related to toxic behavior I've just finally grown tired of, first from the public IRC channel, then the private alpha channel. I really should be calling the people responsible out for it to their faces, in the venues I described, instead of just vacating silently.
I also should have realized that taking down my components from everywhere they're normally available for, and delisting them (not removing them) from the official repository, would only send a message to my followers, and a bad one at that.
Sheesh, please people, stop overreacting. You're only serving to hurt people, as I guess I've hurt you in this action.
I'll likely end up putting everything back the way it was, and rejoin the private chat at least, and poke some people to try to keep their "silly" comments to a minimum.
I'll continue operating the forum as an administrator, as I have been doing almost daily for years now. Sorry if I ignored some of you in personal messages, I was kind of mad at the whole situation before I found out that some anonymous person on 4chan was accusing one of my friends of driving me to suicide. That person can kindly hecc off.
-----BEGIN PGP SIGNATURE-----
Version: Keybase OpenPGP v2.1.0
Comment: https://keybase.io/crypto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=RszW
-----END PGP SIGNATURE-----
Re: My components
Reply #55
ooh, sry to bug u Kode54... I hope u are doing alright...
I am happy to see you are alive and well... please do relist your Foobar 2000 extensions... I will re-donate again on Pateron.com when I have more $ again... sry I haven't been able to up to this point..
Re: My components
Reply #56
Hey kode, I didn't find a thread specifically for foo_ac3, so I'm hoping this is the right place to ask. I've got a 7.1 setup with both side surround and back surrounds. They are configured correctly in Win10 which is outputting 7.1 sound. I'm using foo_ac3.
When I play a 5.1 ac3 file the rear surrounds are being used instead of the side surrounds. This seems wrong... or at least something that ought to be configurable.
With a 5.1 DTS file, the side surrounds are correctly used.
Do you know why this might be happening with ac3 files and if there's any way to change it? I can change to a 5.1 setup and then the side surrounds work, but that's no good for movie watching.
Re: My components
Reply #57
It uses the correct speakers for the AC-3 standard, which was not expanded to support side surrounds until E-AC-3, as far as I know. I do not support E-AC-3.
If I were ever to support E-AC-3, I would need to merge foo_ac3 with foo_input_dts, since that is already using a specialized version of FFmpeg to decode DTS and DTS-HD MA.
The side surrounds are used with DTS in foobar2000 because FFmpeg already decides that is the correct speaker mask to use for it.
I'll have to look into this in the future.
Re: My components
Reply #58
Can you please give link to the source of this information?
Because wikipedia says, that correct standard channel layout for Dolby (and DTS too, of course)  is 5.0 (5.1) SIDE - https://en.wikipedia.org/wiki/Surround_sound#Standard_speaker_channels (see Note 3 in header of column for 5.0 side).
THX site also say that side speakers are used for 5.1 - https://www.thx.com/faq/#set-5-1-surround-sound-speakers It is not called literally "side" there, but if you compare picture of 5.1 setup with 7.1 setup picture ( https://www.thx.com/faq/#set-7-1-surround-sound-speakers ), it is obvious that 5.1 uses side speakers, not back/rear.
As workaround to remap channels only for AC3 you can use foo_dynamicdsp ( https://hydrogenaud.io/index.php/topic,96094.msg956094.html#msg956094 ) together with matrix mixer ( http://skipyrich.com/wiki/Foobar2000:Matrix_Mixer )
Re: My components
Reply #59
no more components on your webpage?
Re: My components
Reply #60
The server was accidentally reset, and we decided not to bring back my personal components mirror.
The components link leads to the official repository, which has the latest components. I also have a mirror at https://keybase.pub/kode54/foobar2000/ but as there are no visible timestamps, and no index page, there is no way to know if any of them have been updated recently, possibly without sending a HEAD query to the server for the download links.
Re: My components
Reply #61
My components have been removed from the official repository over an issue that I will deal with soon enough. For now, they may be downloaded manually from my ever-present Keybase KBFS directory:
Re: My components
Reply #62
oook.... :(   :'(  :'(
I hope this all gets sorted out soon... because it sucks not having your addons on the official repo. for update checks...
I do weekly/daily...  Thx Kode54 for all these years  of your coding, without which I would not be able to listen to vgm...
Re: My components
Reply #63
Okay, everything that matters is back up on the components repository, with newly rewritten descriptions.
Re: My components
Reply #64
Huwayy! Thx Kode54...
but... you also removed the links to your repos and the commit change logs...  :'(  O:)
so how will I know what u changed and fixed?
Re: My components
Reply #65
By the way, TTA Audio Decoder constantly tries to update itself - its internal version is still 3.5.
Re: My components
Reply #66
Oops. That should be fixed now.
Re: My components
Reply #67
I can't find aopsf anymore, so is it considered obsolete?
Re: My components
Reply #68
It is less compatible than foo_psf, and the two components can conflict with each other. My components mirror dump on Keybase probably has it, but it hasn't been updated in years.
Re: My components
Reply #69
Seeking in raw dts files is broken in foo_input_dts 0.6.9. It just skips to next track instead of seeking.
Re: My components
Reply #70
Did you miss my report where I said it was horribly slow before and do nothing about it? Apparently I can't fix it either way, so either you get super slow seeking or no seeking at all.
Re: My components
Reply #71
Sorry, obviously i missed your report. But isn't slow seeking better than no seeking?
Re: My components
Reply #72
Yes, which is why I reverted the last release. You're welcome to blazing fast seeking if you remux your DTS streams into a container, like MKA.
Re: My components
Reply #73
I just wanted to let you know that some GENH audio files are muted in current vgmstream revisions sometimes (so in foobar's plugin too). I referenced the issue on their Github which was fixed in a pending commit. I don't know how long vgmstream takes to merge commits so I wanted to post it here just in case.
https://github.com/losnoco/vgmstream/issues/596
