Hi. I recently updated to version 1.183 and all KSS files [with timed playlists] will now only play for one loop with a brief fade. I created playlists for all the sets I have and timed therein for each track to play through completely twice then fade out for N seconds. I never actually set a loop count value because I never had to, it just worked that way (until the update that is). Anyway I read in the change log something about changes to generic format length handling and thought this may be the cause?
Besides reverting to 1.182 is there any change I can make in the settings or in my playlists to get these files to play the way they did before? Will it solve things to set a loop count value in the playlists? I tried changing the loop count in the settings but noticed this setting only affects VGM files and nothing else.
Sorry for the long post. I will include one of my playlists for reference. No loop count is specified but they always played as mentioned before. Thanks in advance for assisting.
# @TITLE D.A.S.S.
# @ARTIST MSX-Engine
# @COMPOSER Loek van Kooten
# @DATE 1993
# @RIPPER unspecified
# @TAGGER chevbe2403
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$00,BGM 00 (FM Sound),16,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$01,BGM 01 (FM Sound),9,1-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$02,BGM 02 (FM Sound),51,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$03,BGM 03 (FM Sound),51,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$04,BGM 04 (FM Sound),62,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$05,BGM 05 (FM Sound),175,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$06,BGM 06 (FM Sound),88,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$07,BGM 07 (FM Sound),84,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$08,BGM 08 (FM Sound),125,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$09,BGM 09 (FM Sound),92,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$0A,BGM 0A (FM Sound),15,0-,3
#D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$0B,BGM 01 (FM Sound),9,1-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$0C,BGM 0C (FM Sound),60,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$0D,BGM 0D (FM Sound),238,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8E,BGM 00 (PSG),16,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8B,BGM 01 (PSG),9,1-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$82,BGM 02 (PSG),51,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$83,BGM 03 (PSG),51,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$84,BGM 04 (PSG),62,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$85,BGM 05 (PSG),175,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$86,BGM 06 (PSG),88,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$87,BGM 07 (PSG),84,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$88,BGM 08 (PSG),125,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$89,BGM 09 (PSG),92,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8A,BGM 0A (PSG),15,0-,3
#D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8B,BGM 01 (PSG),9,1-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8C,BGM 0C (PSG),60,0-,3
D.A.S.S. (MSX)(1993)(MSX-Engine).kss::KSS,$8D,BGM 0D (PSG),238,0-,3
FWIW if loop specification is what is needed, I think I'll stick to 1.182 until the guys working on Portable/Console Music History do KSS, assuming they do at some point. After spending a lot of time timing and tagging playlists (250 give or take), I can't even look at another one just yet haha.
EDIT: Oops, I was also meaning to ask if reading of playlist files for .nsf files was implemented in the latest update? Thanks again
