Topic: do you lose quality when lowering a wav file volume then raising it up (Read 19676 times) previous topic - next topic
Thats what i'm wondering.. wheres the point where that data gets lost when i do -inf compared to -59db.. its getting lost somewhere. So wheres the point where stuff gets thrown out and if i go to raise the volume later are there things that'll be lost?
A regular WAV is sound represented as a huge series of samples with a certain value. If it's a 16-bit integer WAV, those values can only be whole numbers, just like these forum post can only contain whole characters. There's no such thing as half a character.
If you reduce the volume a lot, then at some point, the values will snap to 0. And there's no escape from 0, obviously.
But apparently somebody up there mentioned that file size doesnt have to do with that
A book with empty pages takes up just as much space as one with a story printed in it. Unless you compress it, and then you can write "this book is completely empty" on a scrap of paper. That's some space savings!
You guys got all that? and dont use any big words like attenuation or floating point format cause i dont know what that means. I didnt go to college for all this, like you guys ya know.
It's really advisable to learn about a few of those terms if you're going to do audio editing. Not kidding.
A few quick notes: Attenuation is making things quieter. Floating point is a notation system of representing a decimal number like 45.7958 in bits so that your computer can work with it. Integer, conversely is a whole number. A 16-bits WAV means the samples can have 2^16 different values.
Wikipedia is pretty good if you want more details.
This. None of these concepts are anything that require college, i.e require more than a few minutes and Google. You will learn far more if you make a basic effort to teach yourself instead of expecting everyone to spoon-feed you. Alleging that such elementary concepts are obscure and academic comes across as rather patronising.
Just IMO, etc., blah-blah-blah. Other members are welcome to walk you through this if they want to. I just personally don’t think they should be expected to, and I don’t think you’d be getting the most out of the experience if they did.
i guess nobody knows what goes on with wav files.... i guess i'll just have to hope that all the information is still in the wav files if i want to raise the volume later in the future.
Some seem to do know what goes on. Heck someone even explained that integers when they round to 0 will have lost all data. If a sample has a low amplitude to begin with, let's say 1 and you reduce volume 60% this becomes 0,4 which will round to 0. increasing 0 by 60% again is...you guessed it 0.
The higher the bit depth the less you'll notice this. With 32bit floating point (please just google this) there is a lot of headroom, so 2 volume changes likely won't affect too much. If you're using 16 bit and to a lesser degree 24 bit projects, you be losing dynamic range every time you do the 'volume up-down dance'.
Plenty of people know. You have been given a wealth of information and pointers to other sources from which you can obtain more. Please do not continue to patronise people by falsely equating an impatience with reading comprehension on your part to a lack of knowledge on theirs.
Reply #30
They will be more noisy. Maybe not audibly noisy, but technically, yes.
So basically, don't do it.
I posted a video in the previous page, I guess you didn't see it. If you don't want to learn any technical stuff then I can tell you, If you use 32-bit float format, you will not have AUDIBLE quality loss even if you change volume with a large range (e.g. over 80dB)
http://youtu.be/E_D6d83nVUE
naw i'm only using 44khz 16 bit like the good old days. Thats cd quality and i dont notice better sound quality difference with higher ratios. Anyways.. hope if i gotta raise the volume in the future i dont lose some data from having lowered the volume. Its not by much but sometimes if its really high pitched i have to lower it really small. Generally the file peak tops are about -8db so below the -6db line.. At least now its not hurting my ears when i'm editing. The original files are higher up like peaks of maybe -3db so i can hear any hiss on those then take that out and lower it. The -40 stuff i was talking about earlier was just tests to see if i'd lose data by lowering it then raising it. Stuff isnt that low.. D'ya guys get whats going on now? Its just a bunch of samples for the next project. Its crazy.. gonna take a year and a half and about 800-1000 hours for a 4min track and video.
Reply #33
I'm done here, you're obviously not getting it. Do the project and edits in 32bit floating point and export the end result in properly dithered 16bit.
Reply #34
I think you need to answer some questions, because though many people here understand how .wav files work at the lowest level of excruciating technical detail, what you're trying to accomplish is either really unclear to us or you appear to be trying to do something that doesn't make any sense.
So:
1. Where is the noise that you are trying to hear (and remove) located? If it's in the .wav file then lowering the level of the signal also lowers the level of the noise.
2. What are you doing to the file to edit it (other than change the volume)?
3. What program are you using to do this stuff?
4. What is your end goal/what are you trying to accomplish?
What you have to understand is that the answer to the questions you asked is often going to be "it depends", which may be why you are not getting as direct answers as perhaps you are looking for. In floating point, lowering/raising the volume will produce no audible difference. But under fixed point, it will introduce errors/noise/distortion, but the noise may or may not be audible. To further complicate things, your audio editing program may (very likely) process 16bit or 24bit fixed point files using 32bit (or 64bit) floating point math internally.
Reply #35
Any good volume control will attenuate all in-band frequencies the same.
I'd much prefer one that is fitted to my equal loudness profile, personally.
Would this be worth implementing?  It could be implemented.
I suspect that it has been implemented, more than once.
I suspect that this product includes such a thing:
http://www.audyssey.com/audio-technology/dynamic-eq
Reply #36
Anyone worries about losing quality after editing should backup the original files before editing. This should be the simplest answer. I was wrong to talk about floating point to confuse the OP.
Reply #37
A side note for audio software users playing around with WAV volume changes: For a quality loss to occur, you actually have to save the file as WAV and then re-import that WAV file between every volume change. It's not enough to lower the volume and raise it again without saving the file. If you do that, the volume change will always be lossless because the changes happen in-memory and the limitations of the WAV format won't come into play.
In short:
- Normalize to -90db, normalize back to previous volume = lossless
- Normalize to -90db, save as WAV, re-open WAV, normalize back to previous volume = quality loss (added noise)
At least this is what I observed using Audacity.
Reply #38
It depends on the software you are using. That's why I actually exported the wave file in 32-bit float in my video illustration (at 2:40). In Adobe Audition 1.5, if you don't explicitly convert the file to float before editing, then you will lose a lot of quality after reducing 90dB in a 16-bit file, even if you don't save and reopen the file.
Reply #39
Because Audacity is applying dither by default, check the Quality tab of the preferences.
Reply #40
Yes but why does it matter if dither is applied or not? I tested with and without dither and there was severe quality loss.
To clarify, I used WAV default settings (Microsoft 16-bit PCM). By the way, in Audacity advanced uncompressed WAV options, what's the difference between "signed 32 bit PCM" and "32 bit float"? Which is better? Both options produce the same file size.
Reply #41
Try to normalize a file to -190dB and save as  "signed 32 bit PCM" and "32 bit float" then normalize to 0dB again.
Reply #42
That has nothing to do with dither.  If you throw away most of the signal, of course there will be quality loss.
Reply #43
To bennetng: I just did it and can't hear any difference. But I'm on laptop speakers so I may not notice if the difference is subtle. What is the difference?
Reply #44
Signed 32 bit PCM encodes values between plus or minus one with a resolution of approximately one two-billionth.
32 bit float encodes values many orders of magnitude larger or smaller than that, but with a resolution of only approximately one sixteen millionth OF THE VALUE.
Both are complete overkill for audio data.
Reply #45
...like those tests i ran where i took a normal sounding wav and lowered it by -40db then raised it again.. sounded the same. You'd think doing that would add some kind of hiss or something.
But it didnt..
Try the experiment again at 8-bits.  By simply saving at 8-bits, you should be able to hear the quantization noise.  If you go through the process of reducing the volume, re-saving at 8-bits, and then re-boosting the volume, you should hear the quantization noise get worse.  (Maybe start with -12 or -20dB because  -40dB is going to be too much at 8-bits.)
With 24-bit integers, you can probably get away with a 40dB change.    At 16-bits, you might get away with it too, since at 16-bits your digital noise floor is more than 90dB down, and if you "throw away" 40dB of dynamic range, you still have more than 50dB of dynamic range remaining.    In many cases, your acoustic/analog dynamic range is worse than 50dB.    So a little quantization noise below -50dB might not be noticeable.
Volume reduction is done by division.    Volume boost is done by multiplication.
Let's say you have a sample value of 15123 from a 16-bit WAV file.    If you reduce it by 40dB (a factor of 100) and represent the result as an integer, you get 151.  If you re-amplify it, you now get 15100.    (You wouldn't actually hear an error of 23 out of 15000, but with smaller sample values the errors become proportionally larger.)
By the way, isn't floating point discarding accuracy as well? What about values like 5,3333333~?
Yes, but the errors/rounding are very small.   You can take any 24-bit (or 16-bit) integer, convert it to 32-bit floating-point, and convert it back with no change in the integer value.  So, converting to floating-point never makes things worse.
It gets a little weird, because like everything in the computer, the floating point values are in binary (base 2).  So, values like 1/10th are not perfectly represented either!  But that's OK.  These errors are so small that we don't have to worry about them.
And, the smaller the number (with a large negative exponent) the smaller the error.  It's kind-of nice when the size of the error (or rounding) is proportional to the number value...  If you are buying a Ferrari (or a Honda) and the price goes up $100, it's no big deal.    But if the price of a hamburger goes up by $100, it's a very big deal!
But really, we are talking about errors/rounding in the Ferrari price that are a tiny-tiny fraction of a penny.    When you convert the price back to dollars and cents, and display it on the computer screen, the errors way-way off to the right of the decimal point are truncated and what you see is perfect to the penny!
Reply #46
Maybe Audacity applied a limit to the normalize value so even if you enter -190 Audacity did not actually reduced 190. I can hear difference but the difference of reducing -190 and -300 are the same.
Try to use some quiet piano music and use headphone and reduce the volume again.
Reply #47
Reply #48
Yes, but I was thinking about the added noise he mentioned.
Reply #49
http://www.hydrogenaudio.org/forums/index....howtopic=100466
I posted a piano clip and the processed clips here
